Posted Saturday at 08:41 PM1 day Replacing a door sensor from Insteon with one from Yolink. Noticed in program I can set “Door State” to “Closed” but can’t set it to “Open”. “Open” is a choice in the drop down it just stays “closed”, doesn’t apply it.I set the line to “Door state is not closed” which works well just wondering about this. Edited Saturday at 08:48 PM1 day by drprm1
Saturday at 08:53 PM1 day Solution What version are you using?Can you send me a log with debug enabled - I looked in the code, and see no reason it would not workThe logic is really not in the node (it presets both values being possible) - it is interface not accepting it (I believe) - there should be no node action when creating the program. Do you see unknown as an option in the drop down?
Saturday at 09:35 PM1 day Author Using version 1.6.3Drop down options are open, closed, and unknown YoLink_11-1-2025_43441_PM.zip
Yesterday at 06:14 AM1 day I can see a lot of Errors - it is a device being offline - maybe try to press the SET buttonNothing else obvious - I believe the issue relates to the console code where something has changed - I doubt we can get them to fix it as they are working on a new version
Yesterday at 12:51 PM1 day Author No prob. Like I said “is not closed” is fine.Thanks for looking into it!
