November 1Nov 1 Replacing a door sensor from Insteon with one from Yolink. Noticed in program I can set “Door State” to “Closed” but can’t set it to “Open”. “Open” is a choice in the drop down it just stays “closed”, doesn’t apply it.I set the line to “Door state is not closed” which works well just wondering about this. Edited November 1Nov 1 by drprm1
November 1Nov 1 Solution What version are you using?Can you send me a log with debug enabled - I looked in the code, and see no reason it would not workThe logic is really not in the node (it presets both values being possible) - it is interface not accepting it (I believe) - there should be no node action when creating the program. Do you see unknown as an option in the drop down?
November 1Nov 1 Author Using version 1.6.3Drop down options are open, closed, and unknown YoLink_11-1-2025_43441_PM.zip
November 2Nov 2 I can see a lot of Errors - it is a device being offline - maybe try to press the SET buttonNothing else obvious - I believe the issue relates to the console code where something has changed - I doubt we can get them to fix it as they are working on a new version
16 hours ago16 hr Interesting ... I also ran into this problem. I installed a new Local Hub and went to update my programs so they used the status from that plugin, but in the process, I had to change all of the logic from options like "is Open" and "is Motion" to "is not Closed" and "is not No Motion". The "is not" option is a workaround, but not being able to specify status options like "is Open" and "is Motion" is kind of problematic. Would it help if we opened a ticket with UDI and asked that they take a look at what's happening on their end? I'm not in any rush, and can certainly wait for them to address things in the new UI, but it would be nice to have that function/capability back at some point.
13 hours ago13 hr That's very similar to the issue I have with the vibration sensor. The select list shows options, but doesn't apply some of the choices.
12 hours ago12 hr 43 minutes ago, Panda88 said:it is only when you create a program - correct?For me, yes. But I've only installed the plugin a few,weeks ago, and been trying this with 6.0.0, so no idea if it would be different with an older version.
