Not all lights responding to Alexa spoken word
I have two Insteon on/off lights in the same room. Using the admin console, I created a scene with both lights in it. In the notes section for the scene, I designated a spoken word.
Only one of the Insteon lights responds to an off or on command, spoken via Alexa (using with the set spoken word of course).
I do need both to respond.
Anything obvious I am missing? Do I need to refresh the Alexa app?
Thanks.
Edited by UD2)17rrh
19 hours ago, Guy Lavoie said:
Did you set up Alexa to control a scene (and select the scene name) in the portal?
Thanks for the reply.
At the moment, I only have the scene active in my IoX admin console. In my Alexa app, I’ve had the UD “ISY Optimized for Smart Home V3” skill enabled for years, I've also run the device discovery command. Not sure if that helped.
Voice control of the scene worked fine when it included just one switch. However, after adding a second switch, it's that second switch that does not respond, while the first continues to work as expected.
Since there’s usually a considerable gap between when I use the admin console or add new switches, I don’t always remember the optimal setup process.
Edited by UD2)17rrh
I'm referring to the portal, not Admin Console. When you defined the Alexa spoken in the portal, what did you click on at the top? "Device" or "Scene"?
You need to click on Scene, and then select the scene from the list (you'll see scene names instead of device names)
Thanks so much. Very helpful. So I have the scene set up in the portal and the spoken word identified. Now what I get from Alexa is "dining room is not responding. Please check its network connection". Nothing happens with the lights upon the spoken word. Frustrating as all the other spoken word command's function well.
Do you have any other Alexa devices set up as scenes? If yes, are they working? Post a picture of the Alexa scene device (as seen in the portal) here.
After you add a device or scene on portal you need tell Alexa to discover new devices. It is the same as if you physically added a new device, the device is there, but Alexa still needs to recognize it's existence. The portal "exposes" the device to Alexa, but Alexa still has to be made aware of it by discovery.
Edited by apostolakisl
4 minutes ago, apostolakisl said:
After you add a device or scene on portal you need tell Alexa to discover new devices. It is the same as if you physically added a new device, the device is there, but Alexa still needs to recognize it's existence. The portal "exposes" the device to Alexa.
Well in my case, they devices get automatically added, something that the UDI skill seems to do for me.
He should first check that the device appears in the Alexa app. It must, because he wouldn't get a "not responding" reply if it didn't exist. Instead it would be about there being no such device.
Make sure you don't have Alexa+ running on any devices. This has been an issue that sometimes gives this result/reply. You would need to review other threads about Alexa+ to see how they resolved it. If you do have it enabled you just need to go to each device it is enabled on and tell it to revert or disable (I'm not sure exactly what is done as I never enabled it, but have seen other posts about it).
For the last few years Alex would auto discover when items are added in the portal. Also, make sure the scene is correctly behaving to being activated from admin console rather than a switch/device. Alexa's control of a scene is as if the "ISY" is the control for the scene. Sometimes the scene is not programmed correctly to operate from admin console, but only when a certain control node us used.
Also, make sure the spoken names and node/device names on the UD Portal are unique. Duplicates can be confusing to Alexa.
That is odd. The UD skill on Alexa is the only way to have ISY and Alexa sync at all as far as I know. Unless there is some other Alexa skill you are talking about, i am only aware of the single UD skill. When I search Alexa for Universal Devices only one shows up. And after I expose a scene or device or variable or whatever on the portal, I always have to tell Alexa to discover new devices. I always do it from my phone and then 10 seconds or so later whatever I "exposed" shows up in the list of new things discovered by Alexa and it asks me what I want to do with those things. Those things are not on my Alexa until I do this discovery. Maybe I am just not waiting long enough.
I go to the 3 line setup menu icon at the bottom, then the "+" at the top right, then "device", then scroll down to the bottom and hit "other", then I select "can't match logo", then a few seconds later it tells me it discovered whatever I added.
If you have the Alexa app open on your phone, you'll sometimes see a popup saying that the new device you just define in the portal was added.
Also note what @Geddy is saying above: "For the last few years Alexa would auto discover when items are added in the portal"
So you are saying that Alexa is doing some periodic discovery process all on its own? Every time I added a device, nothing popped up immediately. I always ran discovery process never waiting long, perhaps 15 minutes, probably less. Perhaps if I just waited a few hours or a day it would have done it anyway?
Anyway, regarding @UD2)17rrh it certainly can't hurt to trigger Alexa into a discovery.
What I'm saying is that the UDI skill seems to be signaling Alexa that the new device has been added, automatically, right away.
Is this a new development? Last I added stuff about 6 months ago, I had to do a discover. I was using the Alexa app to discover, so if something was going to pop up on its own, I would have seen it.
Well I've only been a UDI user for about 16 months, but it's always been that way for me. The pop up appears only once, if you happen to be looking at your screen in the Alexa app. Otherwise you'll miss it. And I haven't seen it every time. But the device gets added every time.
I don't add many devices, and haven't added many to the portal, but last time I did add something to the portal I had an alert on my phone (iOS) near instantly that a device had been added to the Alexa system. I wouldn't need to run "Alexa, discover devices". It's just shown up as soon as I hit save on the portal system. I assume it was an update Amazon made in the Alexa/Echo environment as it began to support more and more "smart" devices. It auto discovered devices. I'm not sure if/how this would work in the Android world, but I know from my experience (and granted isn't much because I haven't added more than maybe 5 devices in the last 2-3 years) the discovery process seemed to become automated and near instant. Sure, I guess it might be different for other items/users/systems, but personal experience was that it was automatic. And it sounds like @Guy Lavoie experienced the same result.
Thanks for all the replies. I have tried the above ideas, tired renaming the scene too, re-ran discovery a few times and it just won't respond. However, I have three scenes and the two most recently added do not work. The oldest (+2 years) does. I think I'll just have to go old school and turn them off by hand.
One possible workaround might be to install the Virtual plugin, and create a simple on/off device, that you then configure as a switch in Alexa. Then create a IoX program that looks for the virtual switch being turned on or off, which turns the scene on or off accordingly.
But the initial problem must certainly have a solution.
Really there are only two things. 1) The scene isn't being discovered by Alexa, or 2) the "spoken" isn't being understand by Alexa to refer to the scene. First off, from your phone Alexa app, see is the scene is even there. If not, then it isn't being discovered. If it is there, try creating a routine in Alexa to control the scene and see if that controls the scene. If so, then there is some issue with the "spoken" not lining up. If the routine works, you can make some spoken words for controlling the routine and leave it like that.
Thanks again for your help.
The scene is in Alexa. The spoken word still did not work but I made a routine, and it worked as you suggested.
I just wish I knew why the spoken word is not working. I understand there were some changes that might have affected older Alexa's earlier this year. Our older devices all seemed to have poorer response to our voices around the middle of the year and practically overnight.
Update. Changed the spoken word from two words to one and it works fine.
