Monday at 04:44 PM3 days I know this is on here somewhere but I cant find it.I have a few light that are triggered by their device (SWL or Lamplinc) but are also turned on by a KPL button (not the load)I have the scene that has the device and the KPL button (as controller)How do I make the LED light up when the light is on and shut off when the light is off?I know I'm supposed to add it to the scene but when I try it says its already a member of the scene
Monday at 05:35 PM3 days @andrew77 , the SWL and Lamplinc also need to be CONTROLERS of the scene. If they are Responders, they will not send the On/Off/Dim commands to other scene members.
Tuesday at 01:26 AM3 days Author I put them both in as controllers now but the LED still doesn't light up when the device is on.I'm unclear what I'm doing wrong?
Tuesday at 01:37 AM3 days I have a program that watches the status of the light(s) in question, and have the program turn on the KPL appropriate LED.
Tuesday at 03:11 AM3 days 1 hour ago, andrew77 said:I put them both in as controllers now but the LED still doesn't light up when the device is on.If turned on/off by the keypad, or by the switch/module, the keypad button would reflect this status because of the scene. Is it possible that there is a program that is turning on the switch/module, or that the switch/module is a member of another scene?
Tuesday at 11:09 AM3 days To isolate which it is, you can try temporarily adding a 3rd nearby device to the scene as a responder. Switch the SWL - What happens, does the new device also come on?If the new nearby test device comes on, it's the keypad. Keypads can 'lose their way' after long periods of use. If updating the scene or restore device didn't work, factory reset it and restore device.
Tuesday at 03:29 PM2 days @andrew77 , my go to for troubleshooting problems of this nature is using the Event Viewer on Level 3. I generated a test Scene that contains a KPL, LampLinc, and a SWL Dimmer. All 3 devices are controllers. Any of the 3 devices will turn the scene On/Off and the KPL Button "A" will track the On/Off.I did this to show you what you "should" be seeing in the event viewer when you activate the scene devices. If you think you are seeing something different, you likely have a device link table error or communication issues. Post back and we can work through those. When you activate a "Device" in a scene it should communicate with group members through Group 01 (for simple devices) or Groups 1 - 8 for KPL's. This will show up in the event viewer as shown below.Request a group cleanup from group members to verify they received the command. This includes your PLM.In the following I am showing addresses for my devices:16.CE.23 is my SWL Dimmer (your dimmer address will be different. The Group # 00.00.01 should be present in your event viewer.My PLM is at Address 53.BC.3A (yours will obviously be different). The group 1 cleanup commands between your device and your PLM should be present.I used KPL button "A" as the controller for my Scene (6 button mode). This works out to be group 3 when the device activates the scene. If you use a different button (or are using 8 button mode) the group # will be different.TAP SWL Dimmer Off (Superfluous ISY Information Dim)SWL Dimmer @16.CE.23 Turning Group 1 offTue 01/20/2026 09:23:33 AM : [INST-SRX ] 02 50 16.CE.23 00.00.01 CB 13 00 LTOFFRR(00)Tue 01/20/2026 09:23:33 AM : [Std-Group ] 16.CE.23-->Group=1, Max Hops=3, Hops Left=2Tue 01/20/2026 09:23:33 AM : [D2D EVENT ] Event [16 CE 23 1] [DOF] [0] uom=0 prec=-1Tue 01/20/2026 09:23:33 AM : [ 16 CE 23 1] DOF 0Tue 01/20/2026 09:23:33 AM : [D2D EVENT ] Event [16 CE 23 1] [ST] [0] uom=100 prec=0Tue 01/20/2026 09:23:33 AM : [ 16 CE 23 1] ST 0 (uom=100 prec=0)Tue 01/20/2026 09:23:33 AM : [D2D EVENT ] Event [18 93 83 1] [ST] [0] uom=100 prec=0Tue 01/20/2026 09:23:33 AM : [ 18 93 83 1] ST 0 (uom=100 prec=0)Tue 01/20/2026 09:23:33 AM : [D2D EVENT ] Event [19 21 5C 3] [ST] [0] uom=100 prec=0Tue 01/20/2026 09:23:33 AM : [ 19 21 5C 3] ST 0 (uom=100 prec=0)SWL Dimmer @16.CE.23 Requesting PLM Cleanup @53.BC.3ATue 01/20/2026 09:23:33 AM : [INST-SRX ] 02 50 16.CE.23 53.BC.3A 41 13 01 LTOFFRR(01)Tue 01/20/2026 09:23:33 AM : [Std-Cleanup ] 16.CE.23-->ISY/PLM Group=1, Max Hops=1, Hops Left=0Tap SWL Dimmer On (Superfluous ISY Information Removed)SWL Dimmer @16.CE.23 Turning Group 1 onTue 01/20/2026 09:24:23 AM : [INST-SRX ] 02 50 16.CE.23 00.00.01 CB 11 00 LTONRR (00)Tue 01/20/2026 09:24:23 AM : [Std-Group ] 16.CE.23-->Group=1, Max Hops=3, Hops Left=2SWL Dimmer @16.CE.23 Performing cleanup on PLM@53.BC.3ATue 01/20/2026 09:24:23 AM : [INST-SRX ] 02 50 16.CE.23 53.BC.3A 46 11 01 LTONRR (01)Tue 01/20/2026 09:24:23 AM : [Std-Cleanup ] 16.CE.23-->ISY/PLM Group=1, Max Hops=2, Hops Left=1LampLinc OnLamplinc On @18.93.83 turning Group 1 OnTue 01/20/2026 09:31:09 AM : [INST-SRX ] 02 50 18.93.83 00.00.01 CF 11 00 LTONRR (00)Tue 01/20/2026 09:31:09 AM : [Std-Group ] 18.93.83-->Group=1, Max Hops=3, Hops Left=3Lamplinc On @18.93.83 Requesting PLM Cleanup @53.BC.3ATue 01/20/2026 09:31:09 AM : [INST-SRX ] 02 50 18.93.83 53.BC.3A 4A 11 01 LTONRR (01)Tue 01/20/2026 09:31:09 AM : [Std-Cleanup ] 18.93.83-->ISY/PLM Group=1, Max Hops=2, Hops Left=2Lamplinc OffLamplinc Off @18.93.83 turning Group 1 OffTue 01/20/2026 09:36:20 AM : [INST-SRX ] 02 50 18.93.83 00.00.01 CF 13 00 LTOFFRR(00)Tue 01/20/2026 09:36:20 AM : [Std-Group ] 18.93.83-->Group=1, Max Hops=3, Hops Left=3Lamplinc Off @18.93.83 Requesting PLM Cleanup @53.BC.3ATue 01/20/2026 09:36:20 AM : [INST-SRX ] 02 50 18.93.83 53.BC.3A 45 13 01 LTOFFRR(01)Tue 01/20/2026 09:36:20 AM : [Std-Cleanup ] 18.93.83-->ISY/PLM Group=1, Max Hops=1, Hops Left=1KPL Button "A" OffKPL @19.21.5C turning Group 3 (KPL Button A) OffTue 01/20/2026 09:38:09 AM : [INST-SRX ] 02 50 19.21.5C 00.00.03 CF 11 00 LTONRR (00)Tue 01/20/2026 09:38:09 AM : [Std-Group ] 19.21.5C-->Group=3, Max Hops=3, Hops Left=3Button "A" Off @19.21.5C Requesting PLM Cleanup @53.BC.3ATue 01/20/2026 09:38:09 AM : [INST-SRX ] 02 50 19.21.5C 53.BC.3A 45 11 03 LTONRR (03)Tue 01/20/2026 09:38:09 AM : [Std-Cleanup ] 19.21.5C-->ISY/PLM Group=3, Max Hops=1, Hops Left=1
Tuesday at 05:35 PM2 days Author Elapsed 00:00:34.277 : Loading VariablesElapsed 00:00:35.095 : Loading Node DefinitionsElapsed 00:00:35.988 : Loading NodesElapsed 00:00:36.190 : Creating WidgetsElapsed 00:00:40.132 : Creating Widgets CompleteTue 01/20/2026 12:29:03 PM : Starting SubscriptionTue 01/20/2026 12:29:04 PM : [4B 52 12 8 ] ST 255 (uom=100 prec=0)Tue 01/20/2026 12:29:04 PM : Completing initializationTue 01/20/2026 12:29:04 PM : U7 Rest: submitCmd([58 DF 82 1],[DOF],[<NULL>])Tue 01/20/2026 12:29:04 PM : Refreshing StatusTue 01/20/2026 12:29:04 PM : Refreshing ViewsTue 01/20/2026 12:29:05 PM : [4B 52 12 8 ] ST 255 (uom=100 prec=0)Tue 01/20/2026 12:29:05 PM : U7 Rest: submitCmd([58 DF 82 1],[DOF],[<NULL>])Tue 01/20/2026 12:32:00 PM : [INST-SRX ] 02 50 70.65.71 00.00.01 CF 11 00 LTONRR (00)Tue 01/20/2026 12:32:00 PM : [Std-Group ] 70.65.71-->Group=1, Max Hops=3, Hops Left=3Tue 01/20/2026 12:32:00 PM : [D2D EVENT ] Event [70 65 71 1] [DON] [0] uom=0 prec=-1Tue 01/20/2026 12:32:00 PM : [70 65 71 1 ] DON 0Tue 01/20/2026 12:32:00 PM : [D2D EVENT ] Event [70 65 71 1] [ST] [255] uom=100 prec=0Tue 01/20/2026 12:32:00 PM : [70 65 71 1 ] ST 255 (uom=100 prec=0)Tue 01/20/2026 12:32:00 PM : [D2D EVENT ] Event [70 9C CE 7] [ST] [255] uom=100 prec=0Tue 01/20/2026 12:32:00 PM : [70 9C CE 7 ] ST 255 (uom=100 prec=0)Tue 01/20/2026 12:32:00 PM : [INST-SRX ] 02 50 70.65.71 71.1B.2E 40 11 01 LTONRR (01)Tue 01/20/2026 12:32:00 PM : [Std-Cleanup ] 70.65.71-->ISY/PLM Group=1, Max Hops=0, Hops Left=0Tue 01/20/2026 12:32:00 PM : [INST-DUP 2 ] Previous message ignored.Tue 01/20/2026 12:32:00 PM : [INST-SRX ] 02 50 70.65.71 71.1B.2E 45 11 01 LTONRR (01)Tue 01/20/2026 12:32:00 PM : [Std-Cleanup ] 70.65.71-->ISY/PLM Group=1, Max Hops=1, Hops Left=1Tue 01/20/2026 12:32:00 PM : [INST-DUP 2 ] Previous message ignored.Tue 01/20/2026 12:32:00 PM : [INST-SRX ] 02 50 70.65.71 11.02.01 CF 06 00 (00)Tue 01/20/2026 12:32:01 PM : [Std-Group ] 70.65.71-->11.02.01, Max Hops=3, Hops Left=3Tue 01/20/2026 12:32:01 PM : [INST-INFO ] Previous message ignored.Tue 01/20/2026 12:32:11 PM : [INST-SRX ] 02 50 70.65.71 00.00.01 CF 13 00 LTOFFRR(00)Tue 01/20/2026 12:32:11 PM : [Std-Group ] 70.65.71-->Group=1, Max Hops=3, Hops Left=3Tue 01/20/2026 12:32:11 PM : [D2D EVENT ] Event [70 65 71 1] [DOF] [0] uom=0 prec=-1Tue 01/20/2026 12:32:11 PM : [70 65 71 1 ] DOF 0Tue 01/20/2026 12:32:11 PM : [D2D EVENT ] Event [70 65 71 1] [ST] [0] uom=100 prec=0Tue 01/20/2026 12:32:11 PM : [70 65 71 1 ] ST 0 (uom=100 prec=0)Tue 01/20/2026 12:32:11 PM : [D2D EVENT ] Event [70 9C CE 7] [ST] [0] uom=100 prec=0Tue 01/20/2026 12:32:11 PM : [70 9C CE 7 ] ST 0 (uom=100 prec=0)Tue 01/20/2026 12:32:11 PM : [INST-SRX ] 02 50 70.65.71 71.1B.2E 45 13 01 LTOFFRR(01)Tue 01/20/2026 12:32:11 PM : [Std-Cleanup ] 70.65.71-->ISY/PLM Group=1, Max Hops=1, Hops Left=1Tue 01/20/2026 12:32:11 PM : [INST-DUP 2 ] Previous message ignored.Tue 01/20/2026 12:32:11 PM : [INST-SRX ] 02 50 70.65.71 13.02.01 CF 06 00 (00)Tue 01/20/2026 12:32:11 PM : [Std-Group ] 70.65.71-->13.02.01, Max Hops=3, Hops Left=3Tue 01/20/2026 12:32:11 PM : [INST-INFO ] Previous message ignored.Tue 01/20/2026 12:32:26 PM : Create REST U7 [/rest/nodes/70%2065%2071%201/cmd/DON]Tue 01/20/2026 12:32:26 PM : U7 Rest: submitCmd([70 65 71 1],[DON],[<NULL>])Tue 01/20/2026 12:32:26 PM : [INST-TX-I1 ] 02 62 70 65 71 0F 11 FFTue 01/20/2026 12:32:26 PM : [INST-ACK ] 02 62 70.65.71 0F 11 FF 06 LTONRR (FF)Tue 01/20/2026 12:32:26 PM : [INST-SRX ] 02 50 70.65.71 71.1B.2E 2F 11 FF LTONRR (FF)Tue 01/20/2026 12:32:26 PM : [Std-Direct Ack] 70.65.71-->ISY/PLM Group=0, Max Hops=3, Hops Left=3Tue 01/20/2026 12:32:26 PM : [D2D EVENT ] Event [70 65 71 1] [ST] [255] uom=100 prec=0Tue 01/20/2026 12:32:26 PM : [70 65 71 1 ] ST 255 (uom=100 prec=0)Tue 01/20/2026 12:32:33 PM : Create REST U7 [/rest/nodes/70%2065%2071%201/cmd/DOF]Tue 01/20/2026 12:32:33 PM : U7 Rest: submitCmd([70 65 71 1],[DOF],[<NULL>])Tue 01/20/2026 12:32:33 PM : [INST-TX-I1 ] 02 62 70 65 71 0F 13 00Tue 01/20/2026 12:32:33 PM : [INST-ACK ] 02 62 70.65.71 0F 13 00 06 LTOFFRR(00)Tue 01/20/2026 12:32:33 PM : [INST-SRX ] 02 50 70.65.71 71.1B.2E 2F 13 00 LTOFFRR(00)Tue 01/20/2026 12:32:33 PM : [Std-Direct Ack] 70.65.71-->ISY/PLM Group=0, Max Hops=3, Hops Left=3Tue 01/20/2026 12:32:33 PM : [D2D EVENT ] Event [70 65 71 1] [ST] [0] uom=100 prec=0Tue 01/20/2026 12:32:33 PM : [70 65 71 1 ] ST 0 (uom=100 prec=0)Tue 01/20/2026 12:32:59 PM : Create REST U7 [/rest/profiles/ns/0/connection]Tue 01/20/2026 12:33:48 PM : [INST-SRX ] 02 50 70.9C.CE 00.00.07 CF 11 00 LTONRR (00)Tue 01/20/2026 12:33:48 PM : [Std-Group ] 70.9C.CE-->Group=7, Max Hops=3, Hops Left=3Tue 01/20/2026 12:33:48 PM : [D2D EVENT ] Event [70 9C CE 7] [DON] [0] uom=0 prec=-1Tue 01/20/2026 12:33:48 PM : [70 9C CE 7 ] DON 0Tue 01/20/2026 12:33:48 PM : [D2D EVENT ] Event [70 9C CE 7] [ST] [255] uom=100 prec=0Tue 01/20/2026 12:33:48 PM : [70 9C CE 7 ] ST 255 (uom=100 prec=0)Tue 01/20/2026 12:33:48 PM : [D2D EVENT ] Event [70 65 71 1] [ST] [255] uom=100 prec=0Tue 01/20/2026 12:33:48 PM : [70 65 71 1 ] ST 255 (uom=100 prec=0)Tue 01/20/2026 12:33:49 PM : [INST-SRX ] 02 50 70.9C.CE 71.1B.2E 4A 11 07 LTONRR (07)Tue 01/20/2026 12:33:49 PM : [Std-Cleanup ] 70.9C.CE-->ISY/PLM Group=7, Max Hops=2, Hops Left=2Tue 01/20/2026 12:33:49 PM : [INST-DUP 2 ] Previous message ignored.Tue 01/20/2026 12:33:49 PM : [INST-SRX ] 02 50 70.9C.CE 11.02.07 C3 06 00 (00)Tue 01/20/2026 12:33:49 PM : [Std-Group ] 70.9C.CE-->11.02.07, Max Hops=3, Hops Left=0Tue 01/20/2026 12:33:50 PM : [INST-INFO ] Previous message ignored.Tue 01/20/2026 12:33:51 PM : [INST-SRX ] 02 50 70.9C.CE 00.00.07 CB 13 00 LTOFFRR(00)Tue 01/20/2026 12:33:51 PM : [Std-Group ] 70.9C.CE-->Group=7, Max Hops=3, Hops Left=2Tue 01/20/2026 12:33:51 PM : [D2D EVENT ] Event [70 9C CE 7] [DOF] [0] uom=0 prec=-1Tue 01/20/2026 12:33:51 PM : [70 9C CE 7 ] DOF 0Tue 01/20/2026 12:33:51 PM : [D2D EVENT ] Event [70 9C CE 7] [ST] [0] uom=100 prec=0Tue 01/20/2026 12:33:51 PM : [70 9C CE 7 ] ST 0 (uom=100 prec=0)Tue 01/20/2026 12:33:51 PM : [D2D EVENT ] Event [70 65 71 1] [ST] [0] uom=100 prec=0Tue 01/20/2026 12:33:51 PM : [70 65 71 1 ] ST 0 (uom=100 prec=0)Tue 01/20/2026 12:33:51 PM : [INST-SRX ] 02 50 70.9C.CE 71.1B.2E 45 13 07 LTOFFRR(07)Tue 01/20/2026 12:33:51 PM : [Std-Cleanup ] 70.9C.CE-->ISY/PLM Group=7, Max Hops=1, Hops Left=1Tue 01/20/2026 12:33:51 PM : [INST-DUP 2 ] Previous message ignored.Tue 01/20/2026 12:33:52 PM : [INST-SRX ] 02 50 70.9C.CE 13.02.07 CB 06 00 (00)Tue 01/20/2026 12:33:52 PM : [Std-Group ] 70.9C.CE-->13.02.07, Max Hops=3, Hops Left=2Tue 01/20/2026 12:33:52 PM : [INST-INFO ] Previous message ignored.I pressed the SWL (non dimming) on and off,then asked Alexa to turn the light on and offthen pressed the KPL button on and off.(I'm sure you can figure that out from what it says above but I don't know what I'm looking atAs an aside I still see this when I open the GUI(its the latest device I added)
Tuesday at 07:34 PM2 days 1 hour ago, andrew77 said:then asked Alexa to turn the light on and offWhen you ask Alexa to turn it on, is it turning on the scene, or an individual device within the scene? If the latter, this could explain one way your devices are getting out of sync.
Tuesday at 07:48 PM2 days @andrew77 , thank you for the Log. Your devices are communicating very well.I pressed the SWL (non dimming) on and off,Your SWL @70.65.71 is communicating everything with the PLM correctly. It also has excellent communications (Max Hops =3, Hops Left =3)SWL Switch Off 70.65.71 Group 1 OnTue 01/20/2026 12:32:00 PM : [INST-SRX ] 02 50 70.65.71 00.00.01 CF 11 00 LTONRR (00)Tue 01/20/2026 12:32:00 PM : [Std-Group ] 70.65.71-->Group=1, Max Hops=3, Hops Left=3SWL to PLM Group CleanupSWL @ 70.65.71 Issuing cleanup to PLM @71.1B.2ETue 01/20/2026 12:32:00 PM : [INST-SRX ] 02 50 70.65.71 71.1B.2E 40 11 01 LTONRR (01)Tue 01/20/2026 12:32:00 PM : [Std-Cleanup ] 70.65.71-->ISY/PLM Group=1, Max Hops=0, Hops Left=0SWL Switch 70.65.71 Group 1 OffTue 01/20/2026 12:32:11 PM : [INST-SRX ] 02 50 70.65.71 00.00.01 CF 13 00 LTOFFRR(00)Tue 01/20/2026 12:32:11 PM : [Std-Group ] 70.65.71-->Group=1, Max Hops=3, Hops Left=3SWL to PLM Group CleanupSWL @ 70.65.71 Issuing cleanup to PLM @71.1B.2ETue 01/20/2026 12:32:11 PM : [INST-SRX ] 02 50 70.65.71 71.1B.2E 45 13 01 LTOFFRR(01)Tue 01/20/2026 12:32:11 PM : [Std-Cleanup ] 70.65.71-->ISY/PLM Group=1, Max Hops=1, Hops Left=1then asked Alexa to turn the light on and offYour Alexa command was processed correctly. However, it was directed to the SWL @71.1B.2E, not your scene. This command will only turn on that specific device.Alexa (Rest) SWL Command ONAlexa turning device 07.65.71 OnTue 01/20/2026 12:32:26 PM : Create REST U7 [/rest/nodes/70%2065%2071%201/cmd/DON]Tue 01/20/2026 12:32:26 PM : U7 Rest: submitCmd([70 65 71 1],[DON],[<NULL>])Tue 01/20/2026 12:32:26 PM : [INST-TX-I1 ] 02 62 70 65 71 0F 11 FFTue 01/20/2026 12:32:26 PM : [INST-ACK ] 02 62 70.65.71 0F 11 FF 06 LTONRR (FF)Tue 01/20/2026 12:32:26 PM : [INST-SRX ] 02 50 70.65.71 71.1B.2E 2F 11 FF LTONRR (FF)Tue 01/20/2026 12:32:26 PM : [Std-Direct Ack] 70.65.71-->ISY/PLM Group=0, Max Hops=3, Hops Left=3then pressed the KPL button on and off.Your KPL button appears to be button "G" on an 8 button KPL (group 7). It also performed correctly in communicating to the PLM and had excellent communications (Max Hops=3, Hops Left=3).KPL Button H On - 8 button KPL turning on group 7KPL Button G @70.9C.CETue 01/20/2026 12:33:48 PM : [INST-SRX ] 02 50 70.9C.CE 00.00.07 CF 11 00 LTONRR (00)Tue 01/20/2026 12:33:48 PM : [Std-Group ] 70.9C.CE-->Group=7, Max Hops=3, Hops Left=3KPL Button G to PLM Group CleanupTue 01/20/2026 12:33:49 PM : [INST-SRX ] 02 50 70.9C.CE 71.1B.2E 4A 11 07 LTONRR (07)Tue 01/20/2026 12:33:49 PM : [Std-Cleanup ] 70.9C.CE-->ISY/PLM Group=7, Max Hops=2, Hops Left=2In summary, your devices appear to be communicating correctly and well with the PLM. While it's possible that your SWL isn't communicating well with your KPL, that's unlikely.My guess would be that you have a link table error in one or both of your devices. Could your post The scene that you are using for these devices? It should look something like the following.Failing a scene membership issue, we'll need to look at the link tables in the devices themselves. We'll leave that for another post... Edited Wednesday at 12:23 PM1 day by IndyMike Corrected KPL button H to G (group7)
Tuesday at 09:01 PM2 days Author 1 hour ago, oberkc said:When you ask Alexa to turn it on, is it turning on the scene, or an individual device within the scene? If the latter, this could explain one way your devices are getting out of sync.I’m pretty sure Alexa triggers the device and not the scene. I thought there was an easier way of making the KPL Led light up when the light it triggers is lit
Tuesday at 09:16 PM2 days 11 minutes ago, andrew77 said:I’m pretty sure Alexa triggers the device and not the scene. I thought there was an easier way of making the KPL Led light up when the light it triggers is litAs @oberkc indicated, your Alexa command is turning on the SWL device ONLY - not the scene. Your KPL button will not change because you are commanding the specific device, not the scene.I an completely Alexa ignorant. I'm assuming there is a way to turn on your Scene rather than the specific SWL device.
Wednesday at 12:49 AM2 days Solution 3 hours ago, andrew77 said:I’m pretty sure Alexa triggers the device and not the scene. I thought there was an easier way of making the KPL Led light up when the light it triggers is litIt's not that hard. In the UDI portal where you defined the relationship with the Insteon switch, you move the entry for the switch, and add an entry for the scene instead of the switch. Login to the portal. Tool > Connetivity> Amazon EchoDelete the line for the switch and add the scene
Wednesday at 11:27 AM2 days 14 hours ago, andrew77 said:I thought there was an easier way of making the KPL Led light up when the light it triggers is litThere is. As IndyMike says, link the scene to Alexa, rather than an individual device within the scene. When linking, define the scene as a "light" to Alexa. If you happen to have any programs that turn this light on or off, make sure they command the scene, and not the individual device.One other possibility (but I doubt this is a factor unless you did this without knowing) is the scene definition itself. Yes...you have everything as controllers...which is correct. But, it is possible that devices within a scene can be commanded to turn OFF (or at a dimmed level) when a particular controller (including the ISY itself) commands the scene to turn ON. In your scene, select each of the controllers and observe the table to the right, making sure the "action" is on or default. Also, as near as I can tell, if a controller in a scene is a dimmer switch and one dims it to a relatively low level (say less than 50%) a responder keypad will not light up. Edited Wednesday at 11:31 AM2 days by oberkc
Wednesday at 01:40 PM1 day @andrew77 , after seeing your event viewer info, it appears you have 1 - 8 button KPL and 1 SWL relay in your scene. I reconfigured my test setup to be similar (1-8 button KPL + 1 SWL dimmer).Since your devices are sending the correct information to the PLM, and you have excellent communication, that leaves us with a link table problem. This will most likely be in the KPL since the "H" button is not following the SWL. Please perform a "Link table read" by right clicking on the KPL and the selecting "Diagnostics/Show Device Links Table" from the drop down list. See the graphic below.The ISY will take some time communicating with your KPL and will fill in the table on the far right.Once the process is complete, click on the "Compare" button toward to bottom right of the window. In response, the ISY will present a second table showing what it believes "should be" in the KPL link table. It will also highlight any errors.Please perform a screen copy of the tables and post to the forum.iXAddressFlagGroupDeviceD1D2Button0FF8A2053BC3AFF1F011FF0E2153BC3A100012FE8E2253BC3A100023FE0E2353BC3A100034FD8E2453BC3A100045FD0E2553BC3A100056FC8E2653BC3A100067FC0E2753BC3A100078FB8E2853BC3A100089FB0A25A53BC3AFF1F07AFA8E2716CE2310007BFA0A2116CE23FF1F07CF980000000I've created the table above from the data in my KPL. The items at address FA8 and FA0 are what allow the KPL to control and respond to my SWL @16.CE.23 Note: your KPL will likely have far more links. The addresses will be different. Your SWL address is also different @70.65.71. Even so, this information must be there in order for the KPL to control/respond to the SWL. Your KPL should have a record matching the following. The "E2" flag indicates that the KPL is a controller of the listed device (your SWL). The 7 in the last column indicates KPL Button GE2770.65.7110007The second link with the "A2" Flag indicates that the KPL is a responder to the listed device. This allows your SWL @70.65.71 to control button G on the KPL.A2170.65.71FF1F07Assuming things are incorrect, recovery may be as easy as deleting the device from the scene and re-adding. Worst case would be deleting the device and re-linking (painful for a KPL).The reason we are going through this somewhat painful exercise is to determine whether the link table is in fact Incorrect. If so, we'll know how to proceed.The other possibility is that your KPL cannot hear the SWL. We've established that both devices can communicate well with the PLM. That does not guarantee that they can communicate with each other (different phases, etc).
Wednesday at 01:51 PM1 day Author 13 hours ago, paulbates said:It's not that hard. In the UDI portal where you defined the relationship with the Insteon switch, you move the entry for the switch, and add an entry for the scene instead of the switch.Login to the portal. Tool > Connetivity> Amazon EchoDelete the line for the switch and add the sceneThank you Paul, this worked.
Wednesday at 01:56 PM1 day In my experience, these things usually are a link table error. Unless things are super complicated, I usually just delete the scene and recreate it. Next step is to delete the devices and readd. Finally, the admin console opening up showing the last device added every time is a bug in the recent firmware. You need to reboot your iox to get rid of it.
21 hours ago21 hr On 1/19/2026 at 8:37 PM, Guy Lavoie said:I have a program that watches the status of the light(s) in question, and have the program turn on the KPL appropriate LED.Same here. I have a similar situation at the house where I want a KPL button to control multiple lights in a room. Pushing the button turns them all ON and pushing again turns them all OFF. However, I want the KPL light to come on if I manually (either switch or Alexa) turn a subset of the lights on in that room. So I have the KPL control the ON/OFF for all the lights and a separate program to turn the KPL light ON if any subset of the lights are turned on. Took a while to get that right, but works as expected.
21 hours ago21 hr 21 minutes ago, slimypizza said:Same here. I have a similar situation at the house where I want a KPL button to control multiple lights in a room. Pushing the button turns them all ON and pushing again turns them all OFF. However, I want the KPL light to come on if I manually (either switch or Alexa) turn a subset of the lights on in that room. So I have the KPL control the ON/OFF for all the lights and a separate program to turn the KPL light ON if any subset of the lights are turned on. Took a while to get that right, but works as expected.Yes, that's exactly what I do too. One button for the ground floor, another one for the basement. I actually have two programs: one that turns on the button if any light is on (or, or, or), and a second program that turns it off if they're all off (and, and, and).
