5 hours ago5 hr Hi There,Im looking for a whole house water valve (AC Powered not battery) that can work with an Eisy. Any suggestions - is it a combo of the valve and a Insteon relay or is there something that is a package?Thank you for any suggestions (I saw Yolo and Zooz - but not seeing a built in AC powered valve - those are add ons to an existing valve)Alex
5 hours ago5 hr I have a Watercop valve, that I got as used, locally. It uses Zwave and has worked very reliably, even though it's a model that has been said to be a problematic early version. Maybe the fact that it's literally 24 inches away from my Zwave dongle helps. The previous owner had used it for irrigation.
5 hours ago5 hr I used a standard powered open/close valve and plug it into an insteon outlet for control. It's very handy for us because our main water shutoff is in a fairly inaccessible crawl space. We can turn on and off the house water using our phones.This is what we use but there are lots of options.Amazon.com: HSH-Flo 1/2" DN15 110-230VAC Normally Closed Stainless Steel 304/CF8 Motorized Electrical Ball Valve With U.S. Plug : Industrial & Scientific
