February 3Feb 3 I have a random event which starts when a motion sensor (2844-222) triggers a scene for basement lights, but (not related) my garage door (IOLinc) opens and a light (LampLinc) turns on.This is very rare event occurring once every 4 weeks ... The motion sensor is top of basement stairs and controls basement light scenes ... Post event, looking through LOG (Tools) the motion sensor, the garage door (IOLinc) or the LampLinc do NOT appear when this event log and when I look at the LampLinc status, it shows off state, and If I look at a scene containing the LampLinc, it shows OFF status, but a mini remote button (4 Scene) shows ON associated with the LampLincI have run Tools / Diagnostics / Event Viewer for weeks hoping to catch what triggers this event ... no luck ...Looking for direction on how to capture / diagnose this random event Cheers
February 3Feb 3 If the ISY has no knowledge of the event, and the Event Viewer isn't showing anything, this would appear to qualify as an "all on"event. Motion sensors and KPL's calling programs that in turn call scenes involving the triggering device are known instigators. The Wiki Guidance is below. There are also numerous posts on the forum.Smartlabs has removed the all-on command from some recently produced devices (V.45). Your IOLinc is probably susceptible. The second link below shows how to test for susceptibility. The 3rd link shows devices that have been tested for susceptibility and have passed.As a precaution, you should probably perform a "restore device" on your problem units to make sure no extraneous links have crept in over time.Wiki link on preventing all on eventshttps://wiki.universal-devices.com/INSTEON_Random_All_On_EventsYou can test for susceptible all on devices as shown here: Edited February 3Feb 3 by IndyMike
February 3Feb 3 Author 8 minutes ago, IndyMike said:If the ISY has no knowledge of the event, and the Event Viewer isn't showing anything, this would appear to qualify as an "all on"event. Motion sensors and KPL's calling programs that in turn call scenes involving the triggering device are known instigators.Appreciate the response and I think I understand what you are suggesting by "instigators", but there are no associations of my basement light control via programs, sensors or KPL's here to my garage door control or a standalone light .... I also discovered today, the garage light was also turned on ... which is new
February 3Feb 3 57 minutes ago, jim_ said:Appreciate the response and I think I understand what you are suggesting by "instigators", but there are no associations of my basement light control via programs, sensors or KPL's here to my garage door control or a standalone light ....I also discovered today, the garage light was also turned on ... which is newThe "Random" event is caused by a communication collision at the PLM. The result of the collision is an Insteon "All-On" command sent to all devices. Devices that have not had the command removed will be affected.
February 3Feb 3 Insteon MS and other Insteon wireless devices are near the top of the instigators list.Is the MS on batteries? In addition to the restore device suggestion, you can try factory resetting it and adding new batteries and then restore device. My experience is that lower the battery voltage gets on the MS, the more un predictable the behavior gets. I eventually put my MSs on a spring/fall battery rotation, ignoring the battery node from the device... and factory resetting them / restore device every time
February 3Feb 3 Author 1 hour ago, IndyMike said:The "Random" event is caused by a communication collision at the PLM. The result of the collision is an Insteon "All-On" command sent to all devices. Devices that have not had the command removed will be affected.learning enabled ... I understand a collision @ PLM, but not understanding "All-On" + "Devices that have not had the command removed will be affected" How does one remove the command "All-On" per device ?1 hour ago, paulbates said:Insteon MS and other Insteon wireless devices are near the top of the instigators list.Is the MS on batteries? In addition to the restore device suggestion, you can try factory resetting it and adding new batteries and then restore device. My experience is that lower the battery voltage gets on the MS, the more un predictable the behavior gets. I eventually put my MSs on a spring/fall battery rotation, ignoring the battery node from the device... and factory resetting them / restore device every timeMS is hardwired to 5v and was factory reset ~ 6 months ago, but days after this random event was still occurring. I'm not convinced it's the MS as root cause ... Since it's always the same devices affected (Lamp, Garage Door, and Garage Light (wife confirmed specifically these 3 only) and there is zero association with the MS / basement lights, we do know that when after 60 second-ish the MS is triggered, then these other 3 devices are affected. Since its not practical to share all my devices and related programs, but there are KPL's with control for this group of devices as well as others .... is it possible for data collision in a KPL ? (and yes the KPL(s) have been reset) .... Back to the question of tools ... should I expect to see messaging in event viewer or is there other tools that I should explore or I'm SOL from a logging perspective ?
February 3Feb 3 If it's workable, I'd pull the plug on the MS for the approximate amount of time it takes the ALL ON event to happen and see if it happens again. I had an MS 2 in my garage for a couple of years, on power not batteries. Worked perfectly during that time, ... until recently....It recently started having problems and I tried all of the suggestions I gave above and had problems changing parameters such that they would stick. It was sending A LOT of messages for its motion sense. Factory resetting, etc had no effect so I replaced it with something else.
February 4Feb 4 14 hours ago, jim_ said:learning enabled ... I understand a collision @ PLM, but not understanding "All-On" + "Devices that have not had the command removed will be affected" How does one remove the command "All-On" per device ?The All-On is a valid Insteon command. When a communication collision at the PLM occurs, a valid outgoing scene command is corrupted into an "All-ON or All-Off" scene command. All older Linked Units will respondIn recent years, Smartlabs began removing the "All-On/All-Off" command from individual devices. Many dimmers/relays with firmware newer than V.45 have had the command removed and will Not respond. One of the links I provided describes how to test for this.15 hours ago, jim_ said:lMS is hardwired to 5v and was factory reset ~ 6 months ago, but days after this random event was still occurring. I'm not convinced it's the MS as root cause ...Since it's always the same devices affected (Lamp, Garage Door, and Garage Light (wife confirmed specifically these 3 only) and there is zero association with the MS / basement lights, we do know that when after 60 second-ish the MS is triggered, then these other 3 devices are affected. Since its not practical to share all my devices and related programs, but there are KPL's with control for this group of devices as well as others .... is it possible for data collision in a KPL ? (and yes the KPL(s) have been reset) ....Back to the question of tools ... should I expect to see messaging in event viewer or is there other tools that I should explore or I'm SOL from a logging perspective ?While it's possible to have a data collision at the KPL, it shouldn't produce an "all-on". The reason are rather dry and technical.It is completely possible for the KPL to cause a collision at the PLM. This typically occurs when the KPL is a scene controller and also triggers a program.MS's are high on the list of instigators because they have the annoying of sending multiple communications to the PLM (increasing the likelihood of a collision).To your last question on messaging - is this is a true "all-on" event you will not see evidence in the event viewer. You may be able to isolate the trigger event through the process of elimination (as you are doing), the the event will look like a normal trigger.Having said the above, one of our forum members has noted communication errors between the PLM and EISY ( @kclenden ). Would you mind posting a level 3 event viewer capture? We could go through the PLM/ISY communications to see if errors exist.
February 4Feb 4 Author Thanks for the descriptive reply, this helps me understand .... 2 hours ago, IndyMike said:Having said the above, one of our forum members has noted communication errors between the PLM and EISY ( @kclenden ). Would you mind posting a level 3 event viewer capture? We could go through the PLM/ISY communications to see if errors exist.Just to clarify .... request to post L3 events log > would this be a general capture (normal MS activation of basement lights ) or specific to the random event ?
February 4Feb 4 @jim_ , a log that spans the actual event would be optimal. Since that may be difficult, a log spanning say 24 hours would help us to understand if there are errors occurring regularly (not all errors produce events).
February 6Feb 6 Author Hey @IndyMike ... 24 hours of Event Viewer L3 attached ... And as per Murphy's Law, the random event did NOT occur BTW, I understand standard IP protocol and use wireshark to isolate troubles, but was looking for an Insteon protocol cheat sheet ... the old UD wiki is to vague. Could you point me to any doc's ? (I have the original 2006 SmartLabs, Inc design doc, but there no procedure / state charts to review) 24 hour Event Viewer L3.txt
February 6Feb 6 @jim_ Generally speaking all on events will not show up in the ISY logs as the ISY is not aware of the events.
February 6Feb 6 @jim_ , no worries. We'll have a look and see whether errors are occurring.There's no "easy" doc to explain the communication protocol shown in the event viewer. What you are seeing is the Host to Modem communication + a lot of ISY notations and program diagnostics. If you are using PG3 (or whatever it's call these days), things get even more confusing.For understand the raw Host to Modem protocol, my favorite doc is the following: https://madreporite.com/insteon/Insteon2412s_modem_dev_guide.pdfThere are newer docs (written for the HUB) but the above does a nice job of explaining the protocol without adding too much fat. Many thanks to the Madreprite site for continuing to make this information available. There is other good Insteon information on the site as well.
February 6Feb 6 I have been watching this post with interest. My experience very much mirrors those of @jim_ , including being associated with motion sensors in the basement. I began to suspect motion sensors as an unexpected trigger for four other insteon devices. It was always the same four devices that responded, but not those particular footwear devices did not always turn on in response to a specific motion sensor. There were many times a suspected motion sensor would detect motion and not trigger the unexpected event.I have since replaced all all insteon motion sensors with yolink. For now, I have no more insteon motion sensors in service at this point. I am pretty confident that this would solve the oft stated problem of signal collisions at the PLM. Unfortunately, the problem persists. The only other culprit that I am suspecting now is is an iolink controlling a garage door. I am currently undecided How I am going to try to solve this problem. Whatever course of action I choose, it will certainly not happen until the weather warms up. For now, I am just choosing to live with the problem.
February 7Feb 7 @jim_ , no smoking guns in your event viewer. I have a python program that parses the event viewer looking for errors. It specifically looks for INST-TX communications from the ISY to the PLM followed by INST-ACK responses from the PLM. I modeled this after a description provided by @kclenden . He was the 1st (to the best of my knowledge) to observe ISY/PLM communication errors in the Event ViewerA normal TX/ACK for a scene looks like the following (on command to group 21:10039 Fri 02/06/2026 12:53:36 : [INST-TX-I1 ] 02 62 00 00 21 CF 11 00 10041 Fri 02/06/2026 12:53:37 : [INST-ACK ] 02 62 00 00 21 CF 11 00 06 LTONRR (00) A device direct command includes a response from the device itself. My program does not test the responses:9629 Fri 02/06/2026 12:51:08 : [INST-TX-I1 ] 02 62 42 D7 2C 0F 11 FF 9633 Fri 02/06/2026 12:51:08 : [INST-ACK ] 02 62 42 D7 2C 0F 11 FF 06 LTONRR (FF) 9634 Fri 02/06/2026 12:51:08 : [INST-SRX ] 02 50 42 D7 2C 71 1C 76 2F 11 FF LTONRR (FF) 9635 Fri 02/06/2026 12:51:08 : [Std-Direct Ack] 42 D7 2C-->ISY/PLM Group=0, Max Hops=3, Hops Left=3 Your event viewer contained 918 total I1 communications. There were no errors (an error is where the INST-ACK <> the INST-TX). There was one "Unknown" error, and 3 timeouts (modem did not respond with a ACK).Your event viewer did not contain any I2 communications.#'s: I1ackerr: 0 I2ackerr: 0 Timeout1: 3 Timeout2: 0 Unknownerr: 1 I1Good: 918 I2Good: 0The Unknown error came at a time when there wasn't a lot going on. No good explanation for the error. The ISY was attempting to turn on group 21. The line labeled with a "U" should have been an INST-ACK 02 62. This command did not go through. Not sure whether the ISY retried the command. There is another ON command processed 13 seconds later. 2419 Thu 02/05/2026 14:17:45 : [INST-TX-I1 ] 02 62 00 00 21 CF 11 00 U 2420 Thu 02/05/2026 14:17:45 : [UNKNOWN ] 02 00 The timeout errors also came at time where there wasn't a lot going on. The INST-TX command below should have been ACKnowledged within seconds (INST-ACK 02 62 00 00 1F CF 13 00 06). No communications were received by the ISY in 1:10 after the command. 8449 Fri 02/06/2026 12:25:39 : [INST-TX-I1 ] 02 62 00 00 1F CF 13 00 T1 8450 Fri 02/06/2026 12:26:50 : [INST-SRX ] 02 50 54 68 42 00 00 01 CF 11 01 LTONRR (01)I did see some areas where there was very high activity. In the section below 3 devices and 6 scenes are turned off in rapid succession. I've never seen that many INST-TX commands "stacked" without a response from the PLM. The PLM did eventually ACK all of these, I am truly surprised. This is most likely a program executing an OFF to multiple members (it could be an external REST command). You may want to look at adding some delays to prevent overloading the PLM.4898 Fri 02/06/2026 07:16:55 : [INST-TX-I1 ] 02 62 58 CA 24 0F 13 00 4899 Fri 02/06/2026 07:16:55 : [INST-TX-I1 ] 02 62 33 7A 65 0F 13 00 4900 Fri 02/06/2026 07:16:55 : [INST-TX-I1 ] 02 62 4E B1 E0 0F 13 00 4901 Fri 02/06/2026 07:16:55 : [INST-TX-I1 ] 02 62 00 00 1B CF 13 00 4902 Fri 02/06/2026 07:16:55 : [INST-TX-I1 ] 02 62 00 00 14 CF 13 00 4903 Fri 02/06/2026 07:16:55 : [INST-TX-I1 ] 02 62 00 00 12 CF 13 00 4904 Fri 02/06/2026 07:16:55 : [INST-TX-I1 ] 02 62 00 00 1C CF 13 00 4905 Fri 02/06/2026 07:16:55 : [INST-TX-I1 ] 02 62 00 00 16 CF 13 00 4906 Fri 02/06/2026 07:16:55 : [INST-TX-I1 ] 02 62 00 00 1E CF 13 00 4907 Fri 02/06/2026 07:16:55 : [ZW-TX-A 01253 2 0 ] [ZY002_1] Binary Switch Set val=0 duration=255 You have some scenes where the command is repeated. The below shows an ON command to group 11 being sent twice. Multiple commands to a scene can improve it's reliability but there should be some delay between the commands.3807 Thu 02/05/2026 17:21:25 : [INST-TX-I1 ] 02 62 00 00 1F CF 11 00 3808 Thu 02/05/2026 17:21:25 : [INST-TX-I1 ] 02 62 00 00 1F CF 11 00 3809 Thu 02/05/2026 17:21:25 : [INST-ACK ] 02 62 00 00 1F CF 11 00 06 LTONRR (00) In summary, this is mostly good news. You have good communication in general (Hops left = 3 in most cases) and 0 communication errors.If you happen to capture an "all-on" event in the viewer, I would be happy to look at it. Aside from that, I would suggest inspecting your programs from proper delays, particularly where motion sensors are being used.You can always post your programs as well. Many forum members with far more programming experience than myself.EDIT: I should have asked earlier - can you provide the addresses of the devices that are turning on? If many devices, you can provide a few. Edited February 7Feb 7 by IndyMike
February 7Feb 7 TL;DR: Bottom line: get rid of all the old Insteon devices that respond to ALL ON.I chased the phantom ALL ON event for years. Like the OP, it was also triggered when an Insteon battery-powered motion detector activated a program that turned on a scene. Most frequently caused LampLinc modules to turn on that had nothing to do with the scene that came on. It would also turn on older Insteon light switches (those that would show up with the tests mentioned earlier in this thread).So, I replaced all of my Insteon plug-in modules with Matter-based on/off and dimmer modules (at a fraction of the price!). I also replaced the old Insteon wall switches with units running newer firmware. These changes eliminated 95% of the phantom ALL ON events, but every once in a while, they would still happen. I am now using Eve Motion (Matter) sensors and moved all of my motion logic to Alexa as a temporary solution, while awaiting full Matter support for those sensors on EISY. See post here.During the holidays, I do use some of the old Insteon modules for holiday lights and get an occasional ALL ON that turns some of them on. So, the signal is still happening. I just removed the old devices that listen for that event.
February 7Feb 7 @jim_ , It looks like you have a motion sensor at address 54.68.42 that is used as a control in two programs (0033 and 005D).Motion sensors send out multiple communication for each trigger event. Yours is sending out 6 separate messages. 4 of the messages the ISY has recognized as duplicates and is ignoring.Unfortunately two of the messages are being processed causing your programs to re-trigger rapidly. The result is multiple scene 21 on commands. You may want to add a lockout to your programs (to prevent re-triggering) as well as a delay to prevent the ISY from trying to send out commands while the motion sensor is hammering the PLM with 6 separate communications.Thu 02/05/2026 11:04:58 : [INST-SRX ] 02 50 54.68.42 00.00.01 CF 11 01 LTONRR (01)Motion Sensor On #1 - ISY Triggers ProgramThu 02/05/2026 11:04:58 : [Std-Group ] 54.68.42-->Group=1, Max Hops=3, Hops Left=3Thu 02/05/2026 11:04:58 : [D2D EVENT ] Event [54 68 42 1] [DON] [1] uom=0 prec=-1Thu 02/05/2026 11:04:58 : [54 68 42 1 ] DON 1Thu 02/05/2026 11:04:58 : [D2D-CMP 005D] CTL [54 68 42 1] [DON] op=is --> trueProgram 005D Control Trigger 1Thu 02/05/2026 11:04:58 : [D2D-CMP 0033] CTL [54 68 42 1] [DON] op=is --> trueProgram 0033 Control Trigger 1Thu 02/05/2026 11:04:59 : [INST-SRX ] 02 50 54.68.42 00.00.01 CF 11 01 LTONRR (01)Motion Sensor On #2 - ISY Re-triggers ProgramThu 02/05/2026 11:04:59 : [Std-Group ] 54.68.42-->Group=1, Max Hops=3, Hops Left=3Thu 02/05/2026 11:04:59 : [INST-SRX ] 02 50 54.68.42 71.1C.76 40 11 01 LTONRR (01)Motion Sensor On #3 (ISY ignores)Thu 02/05/2026 11:04:59 : [Std-Cleanup ] 54.68.42-->ISY/PLM Group=1, Max Hops=0, Hops Left=0Thu 02/05/2026 11:04:59 : [INST-DUP 2 ] Previous message ignored.Thu 02/05/2026 11:04:59 : [INST-TX-I1 ] 02 62 00 00 21 CF 11 00Scene 21 OnThu 02/05/2026 11:04:59 : [D2D EVENT ] Event [54 68 42 1] [DON] [1] uom=0 prec=-1Thu 02/05/2026 11:04:59 : [54 68 42 1 ] DON 1Thu 02/05/2026 11:04:59 : [D2D-CMP 005D] CTL [54 68 42 1] [DON] op=is --> trueProgram 005D Control Re-Trigger Thu 02/05/2026 11:04:59 : [D2D-CMP 0033] CTL [54 68 42 1] [DON] op=is --> trueProgram 0033 Control Re-Trigger Thu 02/05/2026 11:04:59 : [INST-TX-I1 ] 02 62 00 00 21 CF 11 00Scene 21 On (repeat)Thu 02/05/2026 11:04:59 : [INST-ACK ] 02 62 00.00.21 CF 11 00 06 LTONRR (00)Modem ack scene 21 OnThu 02/05/2026 11:05:00 : [INST-ACK ] 02 62 00.00.21 CF 11 00 06 LTONRR (00)Modem ack scene 21 On (repeat)Thu 02/05/2026 11:05:00 : [INST-SRX ] 02 50 54.68.42 71.1C.76 43 11 01 LTONRR (01)Motion Sensor On #4 (ISY Ignores)Thu 02/05/2026 11:05:00 : [Std-Cleanup ] 54.68.42-->ISY/PLM Group=1, Max Hops=3, Hops Left=0Thu 02/05/2026 11:05:00 : [INST-DUP 2 ] Previous message ignored.Thu 02/05/2026 11:05:00 : [INST-SRX ] 02 50 54.68.42 11.01.01 CB 06 00 (00)Motion Sensor On #5 (ISY Ignores)Thu 02/05/2026 11:05:01 : [Std-Group ] 54.68.42-->11.01.01, Max Hops=3, Hops Left=2Thu 02/05/2026 11:05:01 : [INST-INFO ] Previous message ignored.Thu 02/05/2026 11:05:01 : Create REST U7 [/rest/profiles/ns/1/connection]Thu 02/05/2026 11:05:01 : Create REST U7 [/rest/profiles/ns/0/connection]Thu 02/05/2026 11:05:01 : [INST-SRX ] 02 50 54.68.42 11.01.01 CF 06 00 (00)Motion Sensor On #6 (ISY Ignores)Thu 02/05/2026 11:05:01 : [Std-Group ] 54.68.42-->11.01.01, Max Hops=3, Hops Left=3Thu 02/05/2026 11:05:01 : [INST-INFO ] Previous message ignored.
February 7Feb 7 Author @IndyMike WOW ... ok lots to digest, thanks for providing this analysis .... it will take a while for me to slowly walk through.But let me address this last elephant you identified re: "motion sensor at address 54.68.42 that is used as a control in two programs (0033 and 005D)."Yes [Basement Stairs Mot 54.68.42] is valid and the only "Insteon" motion in active deployment with one associated ACTIVE program.I cautiously respond saying ...I was about to ask how one finds a Program by ID, but I had a learning moment . Copy a program in text mode and in the first line of the program NAME and the program ID > Basement Stairs Light On - [ID 005D][Parent 005C] ... always wondered what that text was forQuestion ... 54.68.42 in two programs (0033 and 005D)54.68.42 was found in three programs, the current ACTIVE program and two others that are set DISABLED (my previous TEST samples)Many moons ago, I recall reading that ISY / EISY can still read the program entry set DIABLED, but doesn't execute / ignores ... something like that ???Based on your diagnostics, a program that is is clearly tagged "Disabled" / Basement Stairs Trigger - [ID 0033][Parent 0040][Not Enabled] COULD and is still be executing .... Is this not a bug ?Another educate me question un-relatedWhere program --- Basement Stairs Light On - [ID 005D][Parent 005C] Parent ID matches program ID of 5D ... meaning its standalone ?Where does "Parent 0040" come from in the disable program ... Basement Stairs Trigger - [ID 0033][Parent 0040] ... where Parent 0040 is also found on other disable programs, but there is no program ID 0040 on my ISY / EISY
February 7Feb 7 @jim_, now I need to back things up a bit:When a program is disabled, it will still show triggers in the event viewer. I find this rather frustrating.The disabled program WILL NOT execute then or else commands. Clear as mud, right?I see programs 0033 and 005D being triggered. If program 005D is disabled, the double trigger/ double scene call is coming from program 0033.As far as determining the program ID, I typically use the program summary - far right column is the program ID. I'm guessing that the "Parent" that you are referring to is the ID of the Folder the program is in.
February 7Feb 7 Author Thank you ... The information always seems to be right in front of you, you don't see it I deleted the disabled programs and re-ran a trace matching MS ON msg's as you did, down to 3 ON msg's. No idea if it helps, but like any protocol, any reduction in messaging helps in general 15:10:04 [INST-SRX ] 02 50 54.68.42 00.00.01 CB 11 01 LTONRR (01) > Motion Sensor On #1 - ISY Triggers Program15:10:05 [INST-SRX ] 02 50 54.68.42 00.00.01 CF 11 01 LTONRR (01) > Motion Sensor On #2 - ISY Re-triggers Program15:10:06 [INST-SRX ] 02 50 54.68.42 71.1C.76 46 11 01 LTONRR (01) > Motion Sensor On #3
February 7Feb 7 3 hours ago, jim_ said:I was about to ask how one finds a Program by ID, but I had a learning moment . Copy a program in text mode and in the first line of the program NAME and the program ID > Basement Stairs Light On - [ID 005D][Parent 005C] ... always wondered what that text was forYou can also use FIND in the programs area. If you right click on a program and see "Find/Replace" just before "Copy to Clipboard" (see image below). This will allow you to search for many things directly inside of IoX Admin Console. But copying the program to clipboard and searching the text that way is a good way to find things. That's often what is suggested for posting programs to the forums (if you select the individual program and paste it as text it's easier for people to help make edits). Also when you copy the root of the "my programs" folder to clipboard you can save it as text in case your programs become corrupt over time or during a firmware upgrade. These are great tools we've had in admin console for ages...hopefully they will be incorporated into eisy_ui so they can still be used in the future.
February 8Feb 8 2 hours ago, jim_ said:Thank you ... The information always seems to be right in front of you, you don't see itI deleted the disabled programs and re-ran a trace matching MS ON msg's as you did, down to 3 ON msg's. No idea if it helps, but like any protocol, any reduction in messaging helps in general15:10:04 [INST-SRX ] 02 50 54.68.42 00.00.01 CB 11 01 LTONRR (01) > Motion Sensor On #1 - ISY Triggers Program15:10:05 [INST-SRX ] 02 50 54.68.42 00.00.01 CF 11 01 LTONRR (01) > Motion Sensor On #2 - ISY Re-triggers Program15:10:06 [INST-SRX ] 02 50 54.68.42 71.1C.76 46 11 01 LTONRR (01) > Motion Sensor On #3Unfortunately, I don't think the changes you made had an effect on the Motion sensor communications. I'm not sure why you only saw 3 communications during your test. Rest assured, the 6 communication event will return.Delays in you sensor triggered programs are your friend. They can prevent collisions as well as retrigger events. Highly recommended.
February 8Feb 8 Author @IndyMike I will look in a few weeks if the messages have returned in the trace ... mean time, "Delays are your friend" which I completely agree onBut this program is about as generic as possible with consideration to humans wishing to descend the stairs ASAP preferably with the light ON. Motion is set to report "On Only" & timeout 10 seconds ... so I'm not sure where I could insert a delay here ? Basement Stairs Light On - [ID 005D]If 'Basement Stairs Mot 54.68.42' is switched On And $sBasement_Stairs_Light_Status is 0Then Set 'Basement Stair 3 Way' On Wait 2 minutes Set 'Basement Stair 3 Way' Off
February 8Feb 8 I agree that inserting a delay would not be appropriate for hallway or star lighting. Pretty much defeats the purpose.Rather than use a program, create a scene with the hall light as a responder and the Motion sensor as a controller. Set the Motion sensor to ON/OFF and duration of your liking. You could also change your program from "Control" on to "Status" on. This would not prevent the re-triggering. It will not prevent the ISY from trying to issue the stair light command While the PLM is being hit with multiple RF motion sensor transmissions.Also, in my previous post I mentioned that the ISY was tagging some transmissions as "duplicate" and ignoring them. That doesn't mean that these aren't a problem. The PLM is still servicing these transmissions, again while the ISY is trying to send it's own commands. This is where we believe the problem occurs.
7 hours ago7 hr Author The problem finally triggered today and I said it would post if the issue appeared again ... Attached are the L3 logs and screenshot of the logging. There appears to a a 2 second gap between the 2 logs types ... the event started as per :L3 = Sat 02/28/2026 10:57:51 : [INST-SRX ] 02 50 31.6C.35 00.00.01 CF 11 00 LTONRR (00)Log = Garage Door 31.6C.35-Sensor Status On Sat 2026/02/28 10:57:53***Historically, the garage door (IOLinc) or the LampLinc did not show up in the log, today the IOLinc does show, but not the LampLincWhile I agree to change things up in respect to the MD, I'm current working a kitchen remodel and as per the BOSS, the kitchen takes precedence. If there is anything notable, I would appreciate the feedback and I will change the MD soonishThu - Fri 02-27-2026 11.00.56 L3 trace.txt Edited 6 hours ago6 hr by jim_
