23 hours ago23 hr Michel K. sent out a new version announcement last month. How do I find what my current versions are? If I go to Help > About in the Admin Console all I can see is Firmware IOS v.6.0.0. I cannot find the other version numbers he describes anywhere (Michel I suggest when you send a release announcement you include a link to the installation instructions).I've spent the better part of an hour trying to find the other numbers in my system and browsing the forum for hints. Also, I cannot seem to find out how to upgrade the Firmware. I've done it in the past but cannot seem to remember how I did it. When I go to Configure > System the "Upgrade BIOS" button doesn't function (doesn't respond to clicks). I found a link to an old YouTube video describing the process but the video is way out of date and the screen images do not match my EISY Admin Console displays.Help!Copied from Michel's post:Hello All,I am happy to announce a set of updated software and OS for your eisy/polisy:OS v14.3p9UDX - v4.4.0_6IoX - v6.0.5_1eisyui - v0.10.1
21 hours ago21 hr The best one stop shop for version numbers is in eisy-ui. Set your browser tohttp://<eisy ip address>This should bring up a black login screen, where you enter your UDI account information. Once in, click on the three little lines at the top left, and then choose "System". You'll see all your version numbers. Edited 21 hours ago21 hr by Guy Lavoie
21 hours ago21 hr Author Thank you!I found them by clicking the three lines, then Settings, then System.Next question: Near the bottom of the list I see "Upgrade status: Inactive". What does that mean?Below that is a button labeled "Upgrade packages". Do I use that to update everything to the latest versions? I also find an "Upgrade packages" button in the Admin Console under Configuration > System. I assume that performs the same function?Sorry for the simple questions. I've been using Insteon + EISY (previously ISY994i) for 20+ years. I just don't look at this matter but maybe every couple of years. I get rusty.
21 hours ago21 hr I've never done upgrades from within eisy-ui but that's likely how you would do them, yes.
13 hours ago13 hr For the latest upgrade (v6.5.0), UD has advised to upgrade from the admin console. Got to the admin console, system configuration and select upgrade packages.
