13 hours ago13 hr i have a 994i. When i use the "start" program, i can see my devices but not my programs and thus cannot make changes. What do i do?I bought an eisy and tried to start it up but it does not recognize admin | admin.
13 hours ago13 hr @AGoldreich welcome to the UD Forums. The issue of not being able to see the programs indicates the UI and Firmware of your system do not match. This is common in the ISY994 line. When you're in the admin console look at Help -> About and confirm that the Firmware and UI match. If they do not then you'll need to clear the java cache - be sure you check ALL THREE boxes in this process. Then download a fresh start.jnlp from the UD site (on the homepage click on "My ISY" and save the start.jnlp locally). Then run start.jnlp and accept any Java alerts.If still having issues please let us know what firmware you are using. Please list the number you see in the "Help -> About" menu. 22 minutes ago, AGoldreich said:I bought an eisy and tried to start it up but it does not recognize admin | admin.When did you receive the eisy? If this is recent then it should accept these for login. Would need to have it connected to your network before IoX Finder (start.jnlp) will find the location. If it's an older device that you're just now setting up you might want/need to open a support ticket with UD to get it updated as some updates have bricked older devices that people have not kept up to date or updated since receiving.Let's fix one thing at a time so be sure you can get into the ISY994 first and see programs again. Then be sure you run a backup.
11 hours ago11 hr Author i have the same version - and i can only get the devices on the Cloud version - seems to hang on LAN version. also, i got a LIB error this time.
10 hours ago10 hr 1 hour ago, AGoldreich said:if i can get accss on teh eisy woudl that take care of htings?Not really….if the eisy hasn’t been setup how do you plan on setting it up? As a new system or migrating the ISY994 information to the eisy? If starting over then it might help, but most wont be willing to start over. I’m not familiar with the OADR part of the firmware in your picture. Do you have your device connected to your power company? Since the ISY994 is not longer supported by UD the forums are the best bet to getting that working again. Maybe others have an idea about that firmware and how to get the admin console to see the programs tab.
