Factory Reset?
I want to do a factory reset on my Eisy/Home to get ready to sell. I tried pushing the power button 10 times as the wiki says but did not reset. Is there another way?
If you're ok with doing a ssh session into it, here are some instructions to wipe things clean:
--- factory reset Polisy or eisy ---
-- Stop IoX and PG3
sudo service isy stop
sudo service pg3 stop
-- Remove the entire IoX configuration (devices, programs, Z-Wave/Insteon data, certs, etc.)
sudo rm -rf /usr/local/isy
-- Remove all Polyglot / node server data
sudo rm -rf /var/polyglot
-- Remove portal credentials and association
-- Reset network settings back to default DHCP
sudo rm -f /etc/wpa_supplicant.conf
sudo rm -f /etc/network/interfaces
