June 5Jun 5 The VUE plugin on my eisy has started to fail every few days. I can't download the log, the system says it can't be found. Pressing restart solves the problem and once it's running the log file is available. The file however only contains log info starting with the restart.Is this an eisy problem or a plugin problem?Thank you for any advice
June 5Jun 5 The plug-in debug log files are only active for 24 hours. At midnight, the eisy backs up the current log and then clears the active log.Likely whatever happens, happens before midnight so no data is being collected in the log from that point on. The previous daily log files are saved but the only way to access them is via the command line.Chances are the plug-in fails to re-authenticate when the current token expires or the server stops responding and plug-in needs to re-open the connection to get it working again. The latest version, 1.0.27, was supposed to try and address the server not responding issue. If authentication fails, the plug-in gives up. The assumption is that something is either wrong on their end or the credentials are wrong and retrying to authenticate won't fix either of those issues.Emporia tolerates third party software, like the plug-in, querying their servers as long as it doesn't cause issues or cause a noticeable load.
June 5Jun 5 Author Thanks Bob,I appreciate your explanation. I can look at the backed up log files. What is the path to them?
June 6Jun 6 The logs are in the plug-in's directory: /var/polygot/pg3/ns/<macaddress>_<slot#>/logsYou'll need to use sudo as admin doesn't have enough privilege to access the logs. Here's an example:[bpaauwe@polisy ~]$ sudo ls -lrt /var/polyglot/pg3/ns/000db94e3a44_7/logs total 16 -rw-r--r-- 1 000db94e3a44_7 polyglot 830 Feb 14 2024 debug.log.2023-09-11.gz -rw-r--r-- 1 000db94e3a44_7 polyglot 734 Feb 24 2024 debug.log.2024-02-14.gz -rw-r--r-- 1 000db94e3a44_7 polyglot 864 May 20 2024 debug.log.2024-02-24.gz -rw-r--r-- 1 000db94e3a44_7 polyglot 863 Feb 10 2025 debug.log.2024-05-19.gz -rw-r--r-- 1 000db94e3a44_7 polyglot 3591 Feb 10 2025 debug.log [bpaauwe@polisy ~]$ sudo gunzip /var/polyglot/pg3/ns/000db94e3a44_7/logs/debug.log.2024-05-19 [bpaauwe@polisy ~]$ sudo more /var/polyglot/pg3/ns/000db94e3a44_7/logs/debug.log.2024-05-19
June 7Jun 7 Author Hi @bpwwer ,I'm able to list the files using "sudo ls -lrt /var/polyglot/pg3/ns/000xxxxxxxxx_5/logs" but for some reason I can't "cd" to the directory and actually look at the files. I figured out a workaround, attached are the final entries of June 5. The log seems to end without an error. But at 12:07am on June 6 Vue fails. There is no June 6 log as I haven't restarted the plugin yet. So, I can't see the error which occurs between6/5/26 23:59 and 6/6/26 00:07Does re-authentication occur at midnight?end of June 5.txt Edited June 7Jun 7 by tmorse305
June 7Jun 7 Without any debug/errors shown for June 6, it's impossible to know what really happened.The last thing in the June 5 log shows the plugin executing a short poll event. When this event is executed, the plugin, via a third party library, makes a call to Emporia to get updated info for all devices. Unless there is some weird timing happening where the plugin tries to write to the log at the same time eisy is renaming the log file and that causes the plugin to crash.It might be interesting to see if the plugin was actually doing anything in the first few seconds of June 6 that would show up in the PG3x log or that may even have some details if the plugin crashed.Of course, since it's a new day, you'd have to do the same thing to look at the June 6 PG3x log. Those files are in /var/polygot/pg3/logs You may not need to use sudo to access these logs.
June 7Jun 7 Author I looked through the first 7 minutes of the 6/6 PG3x log but did not see any errors. I've included the first 30 seconds or so of the 7/6/26 PG3x log. Vue is PG3x plugin slot 5.Thanks Bob. start of June 6 PG3x.txt
June 8Jun 8 That's interesting. At least for the first 30 seconds, the plugin is sending data to IoX and appears to be working even though it's not writing anything to it's log.Is there a point in the PG3x log where the requests for slot 5 stop? The lines that look like this:IoX Request: [Try: 1] [00:21:b9:02:65:8a] :: - http://127.0.0.x/rest/ns/5/nodes/.....And are there any messages that would indicate why?Now I'm wondering if the daily log rotation is somehow causing the logging mechanism in the plugin to fail and after some amount of time, it finally hangs or blocks.You're polling every 10 seconds, right? It looks like in this case, that's happening at 0, 10, 20, 30, 40, 50 seconds and the daily log rotation happens at 0 seconds too. I believe the times it polls will depend on when the plugin is started so checking what times the poll is happening and see if the failure is only happening when the polling starts at 0 seconds.If there's a correlation there, this might be something UDI needs to look into.
June 9Jun 9 Author Hi Bob,Here are the first 8 minutes of the log file. I have it filtered on slot 5 activity, but the whole 8 minutes are there.For the first second or 2 it looks like a normal update, then nothing until minute 3:45.301. Then another big pause until 7:33.976 where it is reported as disconnected.PG3x log.xlsx Edited June 9Jun 9 by tmorse305
June 10Jun 10 The log doesn't show anything unusual. The plugin stops sending updates after about a minute and then after about 7 minutes it disconnects. There's nothing in the log to indicate why those two things happen.My best guess is still that something with the daily log rotation is causing the logging mechanism used by the plugin (well, all plugins really) to hang. Since the plugin can't write to it's log and nothing unusual shows up in the PG3x log, I don't really know what to try at this point.My development/debug environment is different from the production environment so I don't think I can even reproduce this in that environment.I'm not sure how UDI is doing the daily log rotation for the plugins but if they can have you turn that off for this plugin, we should know something in a couple of days. Either the plugin will not fail every few days, or if it does, the log my now have some information about why since it's not being rotated.
June 11Jun 11 Author Thanks Bob,I'll open a ticket. Keep you posted.Update:Benoit has a theory that maybe the log files are too big, so they're taking too long to process. I going to change short poll to 20 and see what happens. Edited June 11Jun 11 by tmorse305
Monday at 11:05 AM3 days Author Solution Hi Bob,Increasing the Short Pole time to 20 solved the problem. I made the problem worse by moving the poling level to 'debug' while I was troubleshooting the problem.I'm going to change the short poling interval back to 10, but change the logging level to 'error' which should achieve smaller files.Thanks for your help with this problem!
Monday at 03:50 PM3 days That seems to re-enforce the idea that something is going wrong with the plug-in logging when eisy rotates the log at midnight. By increasing the poll time or reducing the log level you just reduce the chance of it happening.With 10 second polling and debug log the plug-in does generate a lot of messages so Benoit's theory doesn't contradict the above.We (me/UDI) don't recommend normally running with debug level logging unless trying to actually debug an issue. But that can end up being a bit of catch 22. Having the debug log can really help if something does go wrong but having it on all the time can also use a lot of disk space and slow things down as Benoit says.
