Can't stop notifications from repeating
Here is the program I am running. The IF is true when it rains, and the THEN is executed correctly with the notification sent immediately... but then the same notification repeats anywhere from 2 minutes to 10 minutes later for at least 20 repeats. It does eventually stop but then it will start up again at some random time. How do I stop the repeating?
Gen Sump 1 - [ID 0002][Parent 0001][Not Enabled]
'WeatherLink' Daily Rain > 0.250 Inches
Enable Program 'Gen Sump2'
Run Program 'Gen Sump2' (If)
Send Notification to 'Brooke Text' content 'Rain for Gen Sump ON'
Note: Gen Sump 2 is a program that turns on a sump pump for a specified length of time and runs until manually disabled. It works well.
The problem is that your If statement will test true every time the value changes. So even though the rain value stays above 0.250 inches as it increases, the program will fire when it's 0.0251, again at 0.0252, etc. To avoid that, I would use two programs. One that sets another variable as a flag (that the rain is above 0.250 inches), and another program that sends your notification. Like this:
Then rain_flag = 1
Else rain_flag = 0
rain_flag = 1
The first program will keep setting the flag to 1 every time the rain value changes, but that doesn't matter. The second program will test true only the first time the flag is set to 1.
Edited by Guy Lavoie
Thank You Guy
I'll give it a try and test it this Thurs when it's supposed to rain.,
Guy,
I've never used variables so I'm not familiar with them. Here is what I fumbled through. Not sure how or what I've done with the "$Int" ? I just can't figure how to get simple "rain_flag = 1" using the variable input. I assume this will not work but can you guide me how to correct? Thank You
Test 1 - [ID 000A][Parent 0001]
$Int_1_rain_flag = 1
$Int_2_rain_flag = 0
Test 2 - [ID 000F][Parent 0001]
$Int_1_rain_flag is 1
For the purpose here, you need to use a status variable. Go into variables, click on Status at the top. Then add a variable, editing the name to what you want, then click on Save. I like to prefix the name with a "s" for atatus, such as s_rain_flag.
You should then be able to select the variable when programming, such as a If variable statement. Let me know if that works.
I can't find "status" at the top. Sorry to be such a pain. The only thing I see is Integer and State. Is state the same as status?
Hi Guy
Here is the final using "state". Tomorrow's rain should test it
$S_rain_flag = 1
$S_rain_flag = 0
$S_rain_flag is 1
Guy,
Early this morning, I started receiving text notifications as if it had rained. It had not rained at all. I checked Gen Sump2, and it was not engaged. I checked Weatherlink, and daily rain was 0. I got about 20 texts all at randon times. They stopped about 1 pm.
Any ideas what might be triggering the notifications when the IF statement is false?
Might it be a good idea to move the notification line to Then on Gen Sump2?
Interesting. Well what is in the Gen Sump2 program, and why is it run as a separate program? I have not really used Run statements like that so It might be a bit foggy as to what would happen, but I cannot see why you'd get those notifications if the "if" statement never triggered. You could also try putting the notification statement before the Run line.
Another thing: Send Notification is using a plugin, right? Are you able to send notifications ok and only once in other programs?
