1 hour ago1 hr I have the following program to turn a small device on 5 times a day. The program is NOT set to run at startup. Yet when I rebooted my EISY at 11:35AM, the device turned on and off. Why isn't the Run At Startup being honored? Also, in the Summary page, that column shows either ON or a dash. I assume the dash means OFF, so why didn't the developer just use OFF to make this more clear?Thanks.BSMT Deodorizer ON-OFF - [ID 002B][Parent 0058]If ( Time is 7:00:00AM Or Time is 10:00:00AM Or Time is 1:00:00PM Or Time is 4:00:00PM Or Time is 7:00:00PM ) And $sOnVacation is 0 Then Set 'Basement / BSMT Deodorizer / BSMT Sprayer Relay' On Wait 15 seconds Set 'Basement / BSMT Deodorizer / BSMT Sprayer Relay' Off Else - No Actions - (To add one, press 'Action') Turn the deodorizer on once at the top of the hour, several times a day.
1 hour ago1 hr On your main Configuration -> System screen, do you have the setting "Catch up on schedules at Restart" checked?
