Wednesday at 12:58 AM5 days I know this likely needs a ticket, so I'll open one in a bit, but thought others may have experienced the same or have some insight.I've got an EISY and am using the new GUI (not IOX). I upgraded a couple of nights back to all of the latest code releases. I have a Program that runs a couple of scenes every night, 30 minutes before Sunset. Its worked for years. After the upgrades it is not running. I have looked through a few of the logs, but don't see any errors and it seems like our list of logs has exploded. Anyone have a quick insight where to look for an error or what might have gone wrong?From the programs listing it shows a next run time for tomorrow at about 30 minutes before sunset, but there is no "Last Run Time" nor "Last Finish Time" documented in the EISY-UI.I've right clicked to copy the program and I get the next dialog box, but it won't paste, so maybe another GUI error?I have Alexa connected and have spokens set up for this Program, it will run and did last night, if I ask Alexa to run it. Any insights?
Wednesday at 01:07 AM5 days If you right click on the program name from the left hand screen and select "Run Then", does the program run?
Wednesday at 01:14 AM5 days Author Yes - runs perfect. I had avoided doing so tonight for troubleshooting, but did just as you note and all the lights came on as expected. So it appears the issue is the SUNSET trigger. The last Run Time and Finish Time also updated.
Wednesday at 01:18 AM5 days Is the date and time in eisy-ui correct?I have seen something similar happen to me, I think it corrected itself after several reboots.
Wednesday at 01:28 AM5 days Author Well oddly I'll have to say I can't find a time and date in the eisy-ui now that I go looking for it. I have to think that it is however, because that screen shot from after running the "then" updated to the current local time that I ran them at. Edited Wednesday at 01:49 AM5 days by gdntx
Wednesday at 11:36 AM5 days FWIW, I'm experiencing the same problem with programs that trigger on "SUNSET". I'll know in a couple of hours if my "SUNRISE" programs have the same issue.
Wednesday at 12:29 PM5 days I was having trouble with a sunset program also so I just set it for a specific time.
Wednesday at 02:51 PM4 days Author 3 hours ago, Bumbershoot said:FWIW, I'm experiencing the same problem with programs that trigger on "SUNSET". I'll know in a couple of hours if my "SUNRISE" programs have the same issue.Sunrise is working well, it's just sunset. Per other posts there are additional releases coming quickly to get the EISY UI engine and GUI up to speed.
Wednesday at 02:57 PM4 days if you haven't already, I'd suggest editing the program, selecting "sunset" again, clicking update and then saving the program. Some of my triggers stopped working after the upgrade, but this seemed to fix them.
Wednesday at 03:17 PM4 days Author I opened a ticket so it is documented. I tried updating - changed to Sunrise, the program wouldn't save. I change it back to Sunset and the save goes away, it recognized that is what I already have set. I know it's beta and they are working on updates, so it'll work out in the next release or two I'm sure. Just wanted them officially be aware.
Wednesday at 03:19 PM4 days 21 minutes ago, maxnorth said:if you haven't already, I'd suggest editing the program, selecting "sunset" again, clicking update and then saving the program. Some of my triggers stopped working after the upgrade, but this seemed to fix them.Thanks, I'll give it a try.2 minutes ago, gdntx said:I opened a ticket so it is documented. I tried updating - changed to Sunrise, the program wouldn't save. I change it back to Sunset and the save goes away, it recognized that is what I already have set. I know it's beta and they are working on updates, so it'll work out in the next release or two I'm sure. Just wanted them officially be aware.I saw the same thing. I use state variables in these programs, and I was able to increment the value, save, de-increment the value, and save again.
Wednesday at 03:27 PM4 days Author Got a reply to my ticket already, it is a known bug being worked on.
Thursday at 01:59 AM4 days Author Solution I was provided an update to an EISY component and can confirm the Sunset bug is fixed in the next release. My program ran fine tonight. I poked around at a few other things. I could now edit and save a program just fine, so quite a few updates coming in the next releases. Edited Thursday at 01:59 AM4 days by gdntx
