nucore-ai setting up
I've installed the newcor-ai project
Quick Start
git clone https://github.com/NuCoreAI/nucore-ai.git
cd nucore-ai
python -m venv .venv && source .venv/bin/activate
pip install -e .
Edited my config file
  "max_iterations": 20,
  "preferences_dir": null,
  "prompt_log_dir": null,
  "prompt_log_enabled": true,
  "history_token_budget": 20000,
  "nucore_runtime": {
    "default": {
      "provider": "llamacpp",
      "model": "gemma4.26b",
      "url": "http://192.168.2.88:11434/v1",
      "max_turns": 20,
      "temperature": 0.2,
      "max_tokens": 64000
Then tried to run
Omit --query to enter an interactive prompt loop:
python -m unified.run_unified_runtime   --runtime-config src/unified/runtime_config.ollama.json
I get a bunch of errors, but before that. Did I follow the basic steps for setup. Am I missing a config or something else. I'm Running it on a Rocky 9 machine. Just running the minimal no back end test.
Got it running, using
exec python -m unified.run_unified_runtime \
  --runtime-config src/unified/runtime_config.ollama.json \
  --backend-api-classpath "iox.IoXWrapper" \
  --backend-api-base-url "$BACKEND_API_BASE_URL" \
  --backend-api-username "$BACKEND_API_USER_NAME" \
  --backend-api-password "$BACKEND_API_PASSWORD" \
  --prompt_type "default" \
  --json-output "false" \
where user name is admin, not my email address. But after connecting I get WebSocket connection closed
[awysocki@qod nucore-ai]$ ./run_nucore.sh
Launching nucore-ai using Python 3.11.13 from /home/awysocki/nucore-ai/.venv...
2026-09-14 14:07:03 | INFO | main | Unified runtime initialized
Standalone Unified Runtime
Type 'quit' to exit
> status of yard lights
2026-09-14 14:07:20 | ERROR | iox.iox_wrapper | WebSocket connection closed
2026-09-14 14:07:21 | ERROR | iox.iox_wrapper | WebSocket connection closed
2026-09-14 14:07:22 | ERROR | iox.iox_wrapper | WebSocket connection closed
^C2026-09-14 14:07:23 | ERROR | iox.iox_wrapper | WebSocket connection closed
2026-09-14 14:07:24 | ERROR | iox.iox_wrapper | WebSocket connection closed
^C2026-09-14 14:07:24 | WARNING | main |
Interrupted. Exiting.
^C
