Yesterday at 12:45 AM1 day I am using eisy.ui 1.3.9 and IoX 6.1.2_7. I can access the admin console fine via start.jnlp launcher as always. There is an icon at the upper right hand corner of eisy.ui that downloads something calls admin.jnlp. When this is run the ac tells me that there is a version mismatch -- ac 6.1.1 vs IoX 6.1.2. No problem for me and quite possibly the glitch would go away if I cleared Java cache etc, but it seems a little weird to have this not work when the launcher does.
Yesterday at 01:08 AM1 day 20 minutes ago, stillwater said:I am using eisy.ui 1.3.9 and IoX 6.1.2_7. I can access the admin console fine via start.jnlp launcher as always. There is an icon at the upper right hand corner of eisy.ui that downloads something calls admin.jnlp. When this is run the ac tells me that there is a version mismatch -- ac 6.1.1 vs IoX 6.1.2. No problem for me and quite possibly the glitch would go away if I cleared Java cache etc, but it seems a little weird to have this not work when the launcher does.try this: log into admin console using IoX finder, but select "Admin Console (Cloud)" this time, which should upgrade your local copy of admin console on your controller, Then retry launching it from eisy-ui again.
2 hours ago2 hr Author I tried this and it did not change what version of admin.jnlp was being summoned by the icon at the upper right of eisy.ui. I always use the cloud rather than the lan option from the launcher). I usually use the url that allows the older ISY password to be used, rather than portal., but for this test I used admin console (cloud) from the standard (portal password) url. Not an issue for me personally but i could see that this behavior could be troubling for someone unfamiliar with the old ways.This is on a Windows laptop pc. Eisy-ui is version 1.3.10 and IoX is 6.1.2_8 Edited 2 hours ago2 hr by stillwater added my configuration
