October 14Oct 14 Hi @bpwwer ,After I updated IoX to 6.2.1 Vue will not start correctly. The error is below. I deleted the plugin and reinstalled it, but the error remains.Update:I just saw another thread regarding the Boto3 file. I had to reflash my eisy prior to doing the upgrade. I just installed the dev packages from the AC but the error is still there.Thanks for any advice.2026-10-14 14:11:17.461 MainThread udi_interface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30 2026-10-14 14:11:17.462 MainThread udi_interface INFO __init__:<module>: UDI interface initializing 2026-10-14 14:11:17.462 MainThread udi_interface INFO __init__:<module>: User=None 2026-10-14 14:11:17.462 MainThread udi_interface INFO __init__:<module>: Home=/var/polyglot/pg3/ns/0021b9026044_3 2026-10-14 14:11:17.462 MainThread udi_interface INFO __init__:<module>: Node Server Path=/var/polyglot/pg3/ns/0021b9026044_3 2026-10-14 14:11:17.462 MainThread udi_interface INFO __init__:<module>: PG3INIT=eyJ1dWlkIjoiMDA6MjE6Yjk6MDI6NjA6NDQiLCJwcm9maWxlTnVtIjozLCJsb2dMZXZlbCI6IkVSUk9SIiwidG9rZW4iOiJTaUQqTE5Sb3pkQiovVncqIiwibXF0dEhvc3QiOiJsb2NhbGhvc3QiLCJtcXR0UG9ydCI6ODg4Mywic2VjdXJlIjoxLCJpc1BHM3giOnRydWUsInBnM1ZlcnNpb24iOiIzLjQuMjYiLCJpc3lWZXJzaW9uIjoiNi4xLjIiLCJlZGl0aW9uIjoiRnJlZSJ9 2026-10-14 14:11:17.462 MainThread udi_interface INFO __init__:<module>: Loading interface module 2026-10-14 14:11:17.509 MainThread udi_interface INFO interface:<module>: Loading MQTT module 2026-10-14 14:11:18.018 MainThread udi_interface INFO interface:<module>: MQTT module loaded 2026-10-14 14:11:18.239 MainThread udi_interface INFO __init__:<module>: Loading udi_interface module 2026-10-14 14:11:18.239 MainThread udi_interface INFO __init__:<module>: Loading node module 2026-10-14 14:11:18.239 MainThread udi_interface INFO __init__:<module>: Loading custom module 2026-10-14 14:11:18.239 MainThread udi_interface INFO __init__:<module>: Loading isy module 2026-10-14 14:11:18.239 MainThread udi_interface INFO __init__:<module>: Loading OAuth module 2026-10-14 14:11:18.240 MainThread udi_interface INFO __init__:<module>: UDI interface initialized 2026-10-14 14:11:18.240 MainThread udi_interface INFO __init__:<module>: UDI Python Interface for Polyglot version 3 3.4.7 Starting... 2026-10-14 14:11:18.241 MainThread udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2026-10-14 14:11:18.242 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026044_3/vue.py", line 10, in <module> 2026-10-14 14:11:18.242 MainThread udi_interface ERROR udi_interface:write: import pyemvue 2026-10-14 14:11:18.242 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026044_3/pyemvue/__init__.py", line 2, in <module> 2026-10-14 14:11:18.242 MainThread udi_interface ERROR udi_interface:write: from pyemvue.pyemvue import PyEmVue 2026-10-14 14:11:18.242 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026044_3/pyemvue/pyemvue.py", line 8, in <module> 2026-10-14 14:11:18.242 MainThread udi_interface ERROR udi_interface:write: import boto3 2026-10-14 14:11:18.243 MainThread udi_interface ERROR udi_interface:write: ModuleNotFoundError 2026-10-14 14:11:18.243 MainThread udi_interface ERROR udi_interface:write: : 2026-10-14 14:11:18.243 MainThread udi_interface ERROR udi_interface:write: No module named 'boto3' 2026-10-14 14:11:49.530 MainThread udi_interface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30 2026-10-14 14:11:49.530 MainThread udi_interface INFO __init__:<module>: UDI interface initializing 2026-10-14 14:11:49.530 MainThread udi_interface INFO __init__:<module>: User=None 2026-10-14 14:11:49.530 MainThread udi_interface INFO __init__:<module>: Home=/var/polyglot/pg3/ns/0021b9026044_3 2026-10-14 14:11:49.530 MainThread udi_interface INFO __init__:<module>: Node Server Path=/var/polyglot/pg3/ns/0021b9026044_3 2026-10-14 14:11:49.531 MainThread udi_interface INFO __init__:<module>: PG3INIT=eyJ1dWlkIjoiMDA6MjE6Yjk6MDI6NjA6NDQiLCJwcm9maWxlTnVtIjozLCJsb2dMZXZlbCI6IkVSUk9SIiwidG9rZW4iOiJTaUQqTE5Sb3pkQiovVncqIiwibXF0dEhvc3QiOiJsb2NhbGhvc3QiLCJtcXR0UG9ydCI6ODg4Mywic2VjdXJlIjoxLCJpc1BHM3giOnRydWUsInBnM1ZlcnNpb24iOiIzLjQuMjYiLCJpc3lWZXJzaW9uIjoiNi4xLjIiLCJlZGl0aW9uIjoiRnJlZSJ9 2026-10-14 14:11:49.531 MainThread udi_interface INFO __init__:<module>: Loading interface module 2026-10-14 14:11:49.577 MainThread udi_interface INFO interface:<module>: Loading MQTT module 2026-10-14 14:11:50.084 MainThread udi_interface INFO interface:<module>: MQTT module loaded 2026-10-14 14:11:50.306 MainThread udi_interface INFO __init__:<module>: Loading udi_interface module 2026-10-14 14:11:50.306 MainThread udi_interface INFO __init__:<module>: Loading node module 2026-10-14 14:11:50.306 MainThread udi_interface INFO __init__:<module>: Loading custom module 2026-10-14 14:11:50.306 MainThread udi_interface INFO __init__:<module>: Loading isy module 2026-10-14 14:11:50.306 MainThread udi_interface INFO __init__:<module>: Loading OAuth module 2026-10-14 14:11:50.307 MainThread udi_interface INFO __init__:<module>: UDI interface initialized 2026-10-14 14:11:50.307 MainThread udi_interface INFO __init__:<module>: UDI Python Interface for Polyglot version 3 3.4.7 Starting... 2026-10-14 14:11:50.308 MainThread udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2026-10-14 14:11:50.309 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026044_3/vue.py", line 10, in <module> 2026-10-14 14:11:50.309 MainThread udi_interface ERROR udi_interface:write: import pyemvue 2026-10-14 14:11:50.309 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026044_3/pyemvue/__init__.py", line 2, in <module> 2026-10-14 14:11:50.309 MainThread udi_interface ERROR udi_interface:write: from pyemvue.pyemvue import PyEmVue 2026-10-14 14:11:50.309 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026044_3/pyemvue/pyemvue.py", line 8, in <module> 2026-10-14 14:11:50.310 MainThread udi_interface ERROR udi_interface:write: import boto3 2026-10-14 14:11:50.310 MainThread udi_interface ERROR udi_interface:write: ModuleNotFoundError 2026-10-14 14:11:50.310 MainThread udi_interface ERROR udi_interface:write: : 2026-10-14 14:11:50.310 MainThread udi_interface ERROR udi_interface:write: No module named 'boto3' Edited 9 hours ago9 hr by tmorse305
Saturday at 04:37 PM3 days It's working fine on my eisy, but I'm on the staging branch so have more updates on mine than on the production or beta branches.I do see in release notes that UDI has been adding python packages so it may be that the current production branch doesn't have that package yet.
Sunday at 12:17 AM3 days Author Thanks Bob,I actually have 2 eisy's running and I compared the configurations of the machines. See attached. The Pelham machine has the Vue that will not run. It runs fine on the Clermont machine. I queried the Clermont machine (works)and couldn't find any indication that boto3 is installed or running.
Sunday at 05:29 PM2 days May be an installation problem. Can you download the log package for the one that's not working and PM it to me?
9 hours ago9 hr Author Solution Final update and solution!I opened a ticket with UD. The boto3 file is included in the dev package but some of the items in that package must be compiled before use. Just downloading the dev packages was not enough. To get the needed file to be compiled I had to delete the plugin and reinstall it.I had to reflash my eisy because the IoX upgrade failed, then restore from backup. That's how i ended up with the plugin installed but no development packages Edited 9 hours ago9 hr by tmorse305
