eisy ai
On 10/17/2026 at 12:34 PM, SHM said:
Any instructions for configuring MK's eisy ai plugin?
There's a Help in the plugin itself, had a look at it. You have to copy and paste a json and insert your api key. Another instruction (maybe older) shows just identifying the AI model and inserting you api key.
It would be nice if there was a full example of the configuration.
@Michel Kohanim is the plugin ready to use or is it still work in progress?
Scroll down to the Readme section:
GitHub
No image preview
GitHub - UniversalDevicesInc/eisy-ai: eisy AI Companion!
eisy AI Companion! Contribute to UniversalDevicesInc/eisy-ai development by creating an account on GitHub.
The discrepancy you're seeing likely comes down to version drift: the plugin's built-in Help may reflect the current JSON-based config, while older forum posts describe the simpler model-plus-key setup from an earlier build. Since the Readme linked by mmb is maintained in the repo, I'd treat that as the source of truth and check it against your installed PG3x version. If the two still don't line up after that, that's a useful signal for Michel about whether the Help text needs updating or the plugin is mid-development.
