Node definitions/ addresses after PG3x depreciated
It is likely I have not found it yet, but were do I find the individual parameter addreses (able to copy them) in the new solution
I use this in messages - so send daily summaries etc. (by email)
e.g.
Total Net Grid delivery ${sys.node.n015_31966670.GV19} <BR>
Total House Consumption: ${sys.node.n015_31966670.GV15} <BR>
Total Solar Generation: ${sys.node.n015_31966670.GV16} <BR>
e.g. one can copy the node from below and insert
I've looked for this as well and hope it gets added to eisy-ui plugins to ensure the format is always done correctly.
If you know the format, I've noticed you can piece the parameters together from the node view, put a copy would be much appreciated.
Notice if you hover over a value, it shows you the specific parameter name, which is definitely helpful, but not a sufficient substitute.
