October 23Oct 23 54 minutes ago, dbwarner5 said:@Javi Sorting question: Within a Group, all the nodes are sorted alphabetically.However within the scene of the controller, they are not. They appear to be in the order added.Can this list also be alphabetical? I have many scenes with >20 nodes in them and the "random" sorting makes it more difficult to find the right one to adjust.thanks.Group in alphebetical order:Scene, not in alphabetical order:Nice use of Group and Scene!Will keep in mind this implementation is on my todo for rebuild. Likely after nodes page rebuild as they use the same shape of data.
November 18Nov 18 On 10/23/2026 at 10:34 AM, dbwarner5 said:@Javi Sorting question: Within a Group, all the nodes are sorted alphabetically.However within the scene of the controller, they are not. They appear to be in the order added.Can this list also be alphabetical? I have many scenes with >20 nodes in them and the "random" sorting makes it more difficult to find the right one to adjust.thanks.Group in alphebetical order:Scene, not in alphabetical order:My groups are not sorted alphabetically. I wish they were.On 10/20/2026 at 6:39 AM, oberkc said:Also, "scenes" are now "groups".That's what I told myself until I added a KPL today and EISY-UI created these by default:My next step is to figure out how to set them up and rename them....
November 18Nov 18 37 minutes ago, IndyUDIuser said:My groups are not sorted alphabetically. I wish they were.That's what I told myself until I added a KPL today and EISY-UI created these by default:My next step is to figure out how to set them up and rename them.... Sort from header.The KPL must have been added with a retain existing scenes, this is not recommend. It should be added by clearing all. Only users who have them connected to 2 controllers use this, and it will fail in some cases.
November 19Nov 19 On 11/18/2026 at 12:19 PM, Javi said: Sort from header.The KPL must have been added with a retain existing scenes, this is not recommend. It should be added by clearing all. Only users who have them connected to 2 controllers use this, and it will fail in some cases.Yes it was added with retain existing scenes, because I thought I could avoid having to reprogram all the buttons that are currently working through local links (or whatever you call the "set button" method of linking devices). I'll probably remove it from EISY entirely, factory reset, and then see if I can reprogram all the button links through EISY. KPL's are always a pain.
