October 24Oct 24 Also for some reason the deice has conflicting is Long Range is/isNot enabled logs. LongRange and isLR. The profile may need to be removed from eisy prior to adding again. So the steps would be remove profile from ZWave page which will present QR Scan, Factory Reset Z-Wave Device, then same steps to add again. Download log on failure
October 24Oct 24 Author 55 minutes ago, Javi said:Perfect, for some reason S2 Security is failing for this device, not sure of the reason. What is the MFG and model? Also if you have a link to purchase to verify that would be great.What is the dongle, Z-Matter?[2026-10-23 19:10:52.979] [D] [...] Security S2 inclusion timeout event...[2026-10-23 19:10:52.979] [W] [...] Node 300:0 CC SecurityS2: Security S2 key negociation with node 300 failed, KEX fail reason: Unknown Security S2 KEX failure reason (0)....[2026-10-23 19:10:53.011] [I] [...] Node 300:0 CC SecurityS2: SmartStart inclusion failed, trying to remove this deviceNice device, two separately controlled outlets...Yeah, I was going to suggest that you buy one from Amazon and, if you don't have good success with it, return it within 30 days. ZooZ double plug ZOOZ model Zen14 800LRSearch: USA link: outdoor double plug ZOOZ model Zen14 800LRFounf this link:https://www.amazon.com/Z-Wave-Outdoor-Required-Assistant-Hubitat/dp/B0BHC73DLB/ref=sr_1_1?crid=31HS6DJ2YWKL&dib=eyJ2IjoiMSJ9.wgFyIGxmzfquXbdXdGUNYktDfVv0N7gM7HOfhfjXC2NUYBD_br4cYdwj1U2w5B7unInSJ35CtKyiJKDunjmNRKvvSksJBio0ff0UMc73OeA.S-xthUsdjgOc6IbVtL199RaJCsucuQoaEnQEhUkQjWA&dib_tag=se&keywords=outdoor+double+plug+ZOOZ+model+Zen14+800LR&qid=1792812438&sprefix=outdoor+double+plug+zooz+model+zen14+800lr%2Caps%2C197&sr=8-1
October 24Oct 24 Author 7 hours ago, johnstonf said:I didn't have to check off the long-range option...The parameters seem to be inaccessible and grayed out, how did you do it? 1 hour ago, Javi said:Also for some reason the deice has conflicting is Long Range is/isNot enabled logs. LongRange and isLR. The profile may need to be removed from eisy prior to adding again. So the steps would be remove profile from ZWave page which will present QR Scan, Factory Reset Z-Wave Device, then same steps to add again. Download log on failureWhat is the procedure to remove the profile?
October 24Oct 24 10 hours ago, johnstonf said:The parameters seem to be inaccessible and grayed out, how did you do it?What is the procedure to remove the profile?
October 24Oct 24 Author 1 hour ago, johnstonf said:👍They went through the whole process again, same outcome. I ran this through Claude, and this is what it came back with. Does this help?
October 24Oct 24 Author To be honest, this whole Zwave (mesh and LR) has been a disaster on the EISY. I have had trouble tickets logged about my locks, and I don't 'reply in time' so the ticket gets closed... big waste of time to go thru the rigeramo when I'm nuts busy... this ain't supposed to be my full-time gig. I thought LR would be figured out. Anyways with my locks disaster (they were working fiine on my ISY994 (WTF?), I moved my two most critical locks over to a Raspberry Pi with a battery backup, running Home Assistant just on Wi-Fi. Just a simple test, a the time, and I've kept it that way because it works so pristinely. I just added this ZooZ LR, and it took me less than 60 seconds for it to be added. I can't believe the time it is taking on this EISY to get things set up. I'm a wee bit of a hacker, but this is getting ridiculous. Anyways, I have a couple of pictures up to show my quick little setup that I did two months ago that I've never stopped using because it works so well. It just sits on my dining room table and runs and runs and runs. Edited October 24Oct 24 by johnstonf
October 24Oct 24 Solution I understand your frustration. Technology is great, when it works. Just a thought (and something to try): try turning off "Secure Inclusion" in the Z-Wave screen, and retry adding it again to see if that succeeds.You could also try changing the Communication Speed and Interview timeout settings. Edited October 24Oct 24 by Guy Lavoie
October 24Oct 24 Author Thanks... but still dead-ended...(Have you actually added LR devices this way? }I'll try your other suggestions... Edited October 24Oct 24 by johnstonf
October 24Oct 24 Author 1 hour ago, Guy Lavoie said:I understand your frustration. Technology is great, when it works. Just a thought (and something to try): try turning off "Secure Inclusion" in the Z-Wave screen, and retry adding it again to see if that succeeds.You could also try changing the Communication Speed and Interview timeout settings.Yay, by setting the timeout to 3 minutes and the speed to 10, I was able to get it through, I don't know what other parameter values would work, but these did work. It actually went pretty fast, so I'm thinking maybe the speed helped. Thanks!
October 24Oct 24 Welcome to the LR camp!Now you can share your experiences in the LR thread I just started 🙂
October 24Oct 24 Author 21 minutes ago, Guy Lavoie said:Welcome to the LR camp!Now you can share your experiences in the LR thread I just started 🙂Maybe you can move this post over to there.
October 24Oct 24 6 minutes ago, johnstonf said:Maybe you can move this post over to there.No, the intent of the new thread is to discuss the performance of LR (once you get it working). My first post will give you the idea)
October 24Oct 24 2 hours ago, johnstonf said:Yay, by setting the timeout to 3 minutes and the speed to 10, I was able to get it through, I don't know what other parameter values would work, but these did work. It actually went pretty fast, so I'm thinking maybe the speed helped. Thanks!Perfect, I just noticed the communication speed was not at default in a previous screenshot. Was this changed for a specific reason previously?I'm also wondering if it would have worked in using default. I have not experienced any zwave inclusion failures since eisy-ui integration in my testing. I have only seen 3 others failures in our tickets that could not be explained by an external factor. A zwave lock (still open), a device that took over a minute to commission (if the commissioning window was left open for a few seconds longer it completed), and a user trying to use SmartStart without security (the reason we added the error you seen when trying to do the same).
October 25Oct 25 17 hours ago, johnstonf said:Yay, by setting the timeout to 3 minutesQuick note of commiseration: I've also had to set my Z-Wave interview timeout to 2min or 3min, NOT "default". In my case, I have some Z-Wave devices that partially-include, but may have had missing end-points or present-but-non-functioning endpoints. Implicated Z-Wave devices are:Zooz outdoor switched outletsZooz motion-sensorsEcolink motion sensorsLeviton plug-in outlet switchesLeviton wired-in dimmer switchesEven with this extended interview timeout, I've resigned myself to having to include - exclude - factory_reset - include a couple of times, for my Z-Wave stuff to work properly. But after all this, things seem solid.I am glad we both found that extending the interview timeout worked.And like Javi mentions - during my includes, once I see the device end-points appear, I must wait another several minutes for the actual inclusion to successfully complete. When the screen says something like "Timeout" and "Download Log" + "Skip", it's really not finished ... I go and make coffee or something, to give it an additional (5???) minutes to do whatever it's doing behind-the-scenes. Edited October 25Oct 25 by GPritchard
October 25Oct 25 9 minutes ago, GPritchard said:Quick note of commiseration: I've also had to set my Z-Wave interview timeout to 2min or 3min, NOT "default". In my case, I have some Z-Wave devices that partially-include, but may have had missing end-points or present-but-non-functioning endpoints. Implicated Z-Wave devices are:Zooz outdoor switched outletsZooz motion-sensorsEcolink motion sensorsLeviton plug-in outlet switchesLeviton wired-in dimmer switchesEven with this extended interview timeout, I've resigned myself to having to include - exclude - factory_reset - include a couple of times, for my Z-Wave stuff to work properly. But after all this, things seem solid.I am glad we both found that extending the interview timeout worked.And like Javi mentions - during my includes, once I see the device end-points appear, I must wait another several minutes for the actual inclusion to successfully complete. When the screen says something like "Timeout" and "Download Log" + "Skip", it's really not finished ... I go and make coffee or something, to give it an additional (5???) minutes to do whatever it's doing behind-the-scenes.Thanks, I think the dialog will need to be changed to match that timeout parameter. I could not replicate on my side as I have no test cases.Added issue to synchronize the user specified timeout with the dialog timeout. Z-wave inclusion dialog needs to match Z-Wave Timeout. ID /eisy-ui/issues/134
October 26Oct 26 On 10/25/2026 at 10:23 AM, Javi said:Thanks, I think the dialog will need to be changed to match that timeout parameter. I could not replicate on my side as I have no test cases.Added issue to synchronize the user specified timeout with the dialog timeout. Z-wave inclusion dialog needs to match Z-Wave Timeout. ID /eisy-ui/issues/134@Javi Another thing I noticed, which may or may not matter: When I upgraded the dongle firmware, I enabled both the "Long Range" and "Fast Communications (Fast UART)" features. @johnstonf didn't enable "Fast UART" (see his screenshot above). Do you think that this could be related to the timing issues that he experienced?
October 26Oct 26 Author On 10/24/2026 at 7:12 PM, Javi said:Perfect, I just noticed the communication speed was not at default in a previous screenshot. Was this changed for a specific reason previously?I'm also wondering if it would have worked in using default. I have not experienced any zwave inclusion failures since eisy-ui integration in my testing. I have only seen 3 others failures in our tickets that could not be explained by an external factor. A zwave lock (still open), a device that took over a minute to commission (if the commissioning window was left open for a few seconds longer it completed), and a user trying to use SmartStart without security (the reason we added the error you seen when trying to do the same).I did not set or change these options... I didn't even know they existed until @Guy Lavoie pointed them out Edited October 26Oct 26 by johnstonf
October 26Oct 26 4 hours ago, Guy Lavoie said:@Javi Another thing I noticed, which may or may not matter: When I upgraded the dongle firmware, I enabled both the "Long Range" and "Fast Communications (Fast UART)" features. @johnstonf didn't enable "Fast UART" (see his screenshot above). Do you think that this could be related to the timing issues that he experienced?I don't think so, only the basic firmware upgrade is needed everything else is set from eisy.2 hours ago, johnstonf said:I did not set or change these options... I didn't even know they existed until @Guy Lavoie pointed them outThank, odd that it was not default
Wednesday at 04:28 PM2 days @Javi Something is still not quite right with adding Z-Wave devices. I just obtained a second LR device, a Shelly i4 module (4 inputs). When I try to add it, it seems to be doing it but the interview always suddenly times out at about 65%. I tried setting the interview timeout to various values, up to 3 minutes. Including disabling and re-enabling Z-Wave, and rebooting the controller, but the timeout always occurs after less than one minute. It's as if it's igonoring the timeout setting. I tried this on both my eisy and my test Polisy (both have their own ZMatter dongles). The ZWAY log file ends like this:[2026-11-10 20:52:52.360] [I] [...] Adding job: Security S2 Encapsulation (S2 Authenticated), Configuration Get to node 258[2026-11-10 20:52:52.525] [D] [...] Secure payload: ( 70 05 04 )[2026-11-10 20:52:52.526] [D] [...] SENDING (cb 0x2e): ( 01 17 00 13 01 02 0F 9F 03 1E 00 B7 5D 51 D8 32 26 3D 49 31 DD 35 25 2E A4 )[2026-11-10 20:52:52.532] [D] [...] RECEIVED ACK[2026-11-10 20:52:52.533] [D] [...] RECEIVED: ( 01 04 01 13 01 E8 )[2026-11-10 20:52:52.533] [D] [...] SENT ACK[2026-11-10 20:52:52.534] [I] [...] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), Configuration Get to node 258): Response received - transfered to encapsulated jobs[2026-11-10 20:52:52.534] [D] [...] Delivered to Z-Wave stack[2026-11-10 20:52:52.534] [D] [...] Delivered to Z-Wave stack[2026-11-10 20:52:52.548] [D] [...] RECEIVED: ( 01 1D 00 13 2E 00 00 01 00 D8 7F 7F 7F 7F 03 03 01 00 00 00 00 04 01 00 00 FA B7 FA CD B5 CD )[2026-11-10 20:52:52.548] [D] [...] SENT ACK[2026-11-10 20:52:52.549] [I] [...] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), Configuration Get to node 258): Callback received - transfered to encapsulated jobs[2026-11-10 20:52:52.549] [I] [...] Job 0x13 (Configuration Get to node 258): Delivered[2026-11-10 20:52:52.549] [D] [...] SendData Response with callback 0x2e received: received by recipient[2026-11-10 20:52:52.549] [D] [...] Job 0x13 (Configuration Get to node 258): success[2026-11-10 20:52:52.549] [I] [...] Waiting for job reply: Configuration Get from node 258[2026-11-10 20:52:52.549] [I] [...] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), Configuration Get to node 258): Delivered[2026-11-10 20:52:52.549] [D] [...] SendData Response with callback 0x2e received: received by recipient[2026-11-10 20:52:52.549] [D] [...] SETDATA devices.258.data.lastSendInternal = **********[2026-11-10 20:52:52.549] [D] [...] SETDATA devices.258.data.lastSend = 39593791 (0x025c273f)[2026-11-10 20:52:52.549] [D] [...] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), Configuration Get to node 258): success[2026-11-10 20:52:52.549] [D] [...] Security S2 send timer cleared[2026-11-10 20:52:52.549] [I] [...] Removing job: Security S2 Encapsulation (S2 Authenticated), Configuration Get to node 258[2026-11-10 20:52:52.560] [D] [...] RECEIVED: ( 01 1D 00 04 00 01 02 14 9F 03 03 00 BB 60 32 F0 95 D8 D1 DB D6 D7 BB DA 36 53 5D B9 D8 00 09 )[2026-11-10 20:52:52.561] [D] [...] SENT ACK[2026-11-10 20:52:52.561] [D] [...] SETDATA devices.258.data.lastReceived = 0 (0x00000000)[2026-11-10 20:52:52.561] [I] [...] Node 258:0 CC SecurityS2: passing S2 Authenticated decrypted packet to application level: [ 70 06 04 01 00 00 00 00 ][2026-11-10 20:52:52.561] [D] [...] Received reply on job (Configuration Get to node 258)[2026-11-10 20:52:52.561] [D] [...] SETDATA devices.258.instances.0.commandClasses.112.data.4.size = 1 (0x00000001)[2026-11-10 20:52:52.561] [D] [...] SETDATA devices.258.instances.0.commandClasses.112.data.4.val = 0 (0x00000000)[2026-11-10 20:52:52.561] [D] [...] SETDATA devices.258.instances.0.commandClasses.112.data.4 = Empty[2026-11-10 20:52:52.561] [I] [...] Node 258:0 CC Configuration: Parameter 0x0004 = 0 (size = 1)[2026-11-10 20:52:52.562] [I] [...] Adding job: Security S2 Encapsulation (S2 Authenticated), Configuration Properties Get to node 258[2026-11-10 20:52:52.725] [D] [...] Secure payload: ( 70 0E 00 69 )[2026-11-10 20:52:52.726] [D] [...] SENDING (cb 0x2f): ( 01 18 00 13 01 02 10 9F 03 1F 00 86 D5 00 2A D9 B8 A2 B3 FB F2 77 AD 25 2F B4 )[2026-11-10 20:52:52.732] [D] [...] RECEIVED ACK
Wednesday at 05:40 PM2 days My Z-Wave stuff was also doing this, but despite what the screen showed, it was actually still doing something important behind-the-scenes.What ultimately worked for me: Wait. A lot. Like, go make coffee, check mail, wash dishes, etc. At least 5min, perhaps even 10min. After this, all the Z-wave nodes appeared correct, and functional. If (when!) I was was impatient, and click-exited after the 65% timeout, nothing was right. Waiting worked (for me).I wonder if this may help your situation? I had quite a few Z-Wave devices, and after migrating from ISY994i to Eisy, all had to be deleted and re-added. It took me a few days, especially with long waits. Oh, I also commonly had to: Remove Z-Wave device, factory-reset Z-Wave device, Add Z-Wave device, Remove Z-Wave device, another factory-reset, then final Add Z-Wave device with a tremendous dose of patience. In the end, I am happy with the functional results. Edited Wednesday at 05:41 PM2 days by GPritchard
Wednesday at 05:53 PM2 days 1 hour ago, Guy Lavoie said:@Javi Something is still not quite right with adding Z-Wave devices. I just obtained a second LR device, a Shelly i4 module (4 inputs). When I try to add it, it seems to be doing it but the interview always suddenly times out at about 65%. I tried setting the interview timeout to various values, up to 3 minutes. Including disabling and re-enabling Z-Wave, and rebooting the controller, but the timeout always occurs after less than one minute. It's as if it's igonoring the timeout setting. I tried this on both my eisy and my test Polisy (both have their own ZMatter dongles). The ZWAY log file ends like this:[2026-11-10 20:52:52.360] [I] [...] Adding job: Security S2 Encapsulation (S2 Authenticated), Configuration Get to node 258[2026-11-10 20:52:52.525] [D] [...] Secure payload: ( 70 05 04 )[2026-11-10 20:52:52.526] [D] [...] SENDING (cb 0x2e): ( 01 17 00 13 01 02 0F 9F 03 1E 00 B7 5D 51 D8 32 26 3D 49 31 DD 35 25 2E A4 )[2026-11-10 20:52:52.532] [D] [...] RECEIVED ACK[2026-11-10 20:52:52.533] [D] [...] RECEIVED: ( 01 04 01 13 01 E8 )[2026-11-10 20:52:52.533] [D] [...] SENT ACK[2026-11-10 20:52:52.534] [I] [...] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), Configuration Get to node 258): Response received - transfered to encapsulated jobs[2026-11-10 20:52:52.534] [D] [...] Delivered to Z-Wave stack[2026-11-10 20:52:52.534] [D] [...] Delivered to Z-Wave stack[2026-11-10 20:52:52.548] [D] [...] RECEIVED: ( 01 1D 00 13 2E 00 00 01 00 D8 7F 7F 7F 7F 03 03 01 00 00 00 00 04 01 00 00 FA B7 FA CD B5 CD )[2026-11-10 20:52:52.548] [D] [...] SENT ACK[2026-11-10 20:52:52.549] [I] [...] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), Configuration Get to node 258): Callback received - transfered to encapsulated jobs[2026-11-10 20:52:52.549] [I] [...] Job 0x13 (Configuration Get to node 258): Delivered[2026-11-10 20:52:52.549] [D] [...] SendData Response with callback 0x2e received: received by recipient[2026-11-10 20:52:52.549] [D] [...] Job 0x13 (Configuration Get to node 258): success[2026-11-10 20:52:52.549] [I] [...] Waiting for job reply: Configuration Get from node 258[2026-11-10 20:52:52.549] [I] [...] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), Configuration Get to node 258): Delivered[2026-11-10 20:52:52.549] [D] [...] SendData Response with callback 0x2e received: received by recipient[2026-11-10 20:52:52.549] [D] [...] SETDATA devices.258.data.lastSendInternal = **********[2026-11-10 20:52:52.549] [D] [...] SETDATA devices.258.data.lastSend = 39593791 (0x025c273f)[2026-11-10 20:52:52.549] [D] [...] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), Configuration Get to node 258): success[2026-11-10 20:52:52.549] [D] [...] Security S2 send timer cleared[2026-11-10 20:52:52.549] [I] [...] Removing job: Security S2 Encapsulation (S2 Authenticated), Configuration Get to node 258[2026-11-10 20:52:52.560] [D] [...] RECEIVED: ( 01 1D 00 04 00 01 02 14 9F 03 03 00 BB 60 32 F0 95 D8 D1 DB D6 D7 BB DA 36 53 5D B9 D8 00 09 )[2026-11-10 20:52:52.561] [D] [...] SENT ACK[2026-11-10 20:52:52.561] [D] [...] SETDATA devices.258.data.lastReceived = 0 (0x00000000)[2026-11-10 20:52:52.561] [I] [...] Node 258:0 CC SecurityS2: passing S2 Authenticated decrypted packet to application level: [ 70 06 04 01 00 00 00 00 ][2026-11-10 20:52:52.561] [D] [...] Received reply on job (Configuration Get to node 258)[2026-11-10 20:52:52.561] [D] [...] SETDATA devices.258.instances.0.commandClasses.112.data.4.size = 1 (0x00000001)[2026-11-10 20:52:52.561] [D] [...] SETDATA devices.258.instances.0.commandClasses.112.data.4.val = 0 (0x00000000)[2026-11-10 20:52:52.561] [D] [...] SETDATA devices.258.instances.0.commandClasses.112.data.4 = Empty[2026-11-10 20:52:52.561] [I] [...] Node 258:0 CC Configuration: Parameter 0x0004 = 0 (size = 1)[2026-11-10 20:52:52.562] [I] [...] Adding job: Security S2 Encapsulation (S2 Authenticated), Configuration Properties Get to node 258[2026-11-10 20:52:52.725] [D] [...] Secure payload: ( 70 0E 00 69 )[2026-11-10 20:52:52.726] [D] [...] SENDING (cb 0x2f): ( 01 18 00 13 01 02 10 9F 03 1F 00 86 D5 00 2A D9 B8 A2 B3 FB F2 77 AD 25 2F B4 )[2026-11-10 20:52:52.732] [D] [...] RECEIVED ACKPlease leave open after time-out. The timeout is UI only, needs to be adjusted to match the users selected timeout. Issue was created but not yet worked.On 10/25/2026 at 8:23 AM, Javi said:Added issue to synchronize the user specified timeout with the dialog timeout. Z-wave inclusion dialog needs to match Z-Wave Timeout. ID /eisy-ui/issues/134
