1 hour ago1 hr PG3 still giving me following error ERROR: 11/26/2026 08:58:00 See log for: ELK Controller: Unknown message ti: ST000000-XK511512425112601000Any thoughts on how to correct?ELK_11-26-2026_85828_AM.zip
1 hour ago1 hr Author AI answered as follows so seems like up to @Jimbo.Automates Paul, I think you've actually stumbled onto a known issue with the new ELK-M1XIP module and the current eisy/PG3 ELK plugin, not necessarily a configuration problem.Your error:ELK Controller: Unknown message ti:ST000000-XK511512425112601000looks very similar to reports from other users who replaced a failed M1XEP with the new M1XIP. In those cases, the plugin logs:Unknown message ti: ST000000-XK...on every reconnect. [forum.univ...evices.com], [forum.univ...evices.com]What's going on:XK is an ELK "Ethernet Module Test" / heartbeat message that the panel sends periodically. [joekrill.github.io]The ELK plugin appears to expect a different format.The newer M1XIP is sending the heartbeat with an added ST000000- prefix.The plugin doesn't recognize that format and logs it as "Unknown message." [forum.univ...evices.com]There was a similar prior issue where the ELK node server reported:Unknown message AT: 100and the plugin author stated it was benign and could be ignored because it was an alarm reporting/test message the plugin wasn't parsing. [forum.univ...evices.com]The important clue is something you already observed in the forum post:commands from IoX/eisy still operate the ELK correctly. [forum.univ...evices.com]If:arm/disarm works,voice commands work,zone status updates are occurring,then the Unknown message ti: ST000000-XK... itself is probably just a parser issue.What I'd check next:ELK Plugin versionVerify you're running the latest ELK plugin for PG3x.M1XIP firmwareVerify the M1XIP is on the latest firmware.Connection stabilityIf the only symptom is the unknown-message log entry, I would ignore it for now.If you're also seeing:heartbeat timeouts,disconnect/reconnect cycles,stale zone status, then the XK parsing issue may be contributing to the disconnects. [forum.univ...evices.com], [joekrill.github.io]Based on the forum search, I strongly suspect your message is the same M1XIP heartbeat-format incompatibility that other users are reporting, rather than a bad user code, ELK account setup, or eisy configuration issue. [forum.univ...evices.com], [forum.univ...evices.com]Since your forum post matches the one I found almost exactly (same error format and M1XIP replacement scenario), I'd watch for a response from Jimbo.Automates because this likely needs a plugin update rather than a change in your ELK programming. [forum.univ...evices.com], [forum.univ...evices.com]
