General questions...
jmed999
-What does it mean if my device names are in italics? Sometimes they are and sometimes they aren't.
-What does it mean to "Query Insteon Engine"?
-What does "Show Device Links Table" mean?
-What does "Show ISY Links Table" mean?
I may be able to help with a couple of these:
I understand that this causes the ISY to query a particular device and display all the links stored in that device.
As opposed to
I understand that this displays the links that the ISY thinks is associated with a particular device. Both should be identical, but can diverge for various reasons. I believe that the ISY uses these two results in the "compare" function.
In the evolution of devices over the life of Insteon, the Insteon protocol has evolved. Starting with I1 (Insteon 1), followed by I2 (Insteon 2), followed by the latest I2CS (I2 Checksum). Depending on when the device was manufactured it will have been built around one of these three protocols. This is known as the device engine. The Query Insteon Engine refreshes the information the ISY has recorded for what engine each device contains. The device engine dictates how the ISY interfaces with each device.
Where do you see devices in Italics? In the upper section of the My Lighting tree where all the device nodes are listed or the lower section where the Scenes and related device nodes are listed? Are the device nodes a different color when in Italics?
Both. Seems like they are the same color.
Don't know. In Scenes Controllers and Responders are differentiated that way but they are also Blue versus Red so they tend to stand out more by color then font.
Post an image of the Italics in the main Node area. Include all the nodes for the device in question as well as a few nodes before and after.
Use the print screen command on you keyboard (hold the blue "fn" key and the "print screen" button). This turns the contents of your screen into a picture and holds it in memory. Then paste (control v) the picture into a photo program and save it. Then you can upload the photo to a web hosting service and put the link into your post.
What operating system and what level Java?
As you can see below my Nodes are not in Italics. I suspect a difference in Java level.
I am running Java 6 as there were problems with Java 7. In the case of the selected item the Italics give it some additional visual difference. The Italics have no meaning to the ISY.
It's not only the selected item that is in italics. Other items go to itlalics depending on what device is selected.
I see that Landscape Lights are not Italics, Fish Pump is Italics. Also the Primary KeypadLinc node of Upstairs - Main is not in Italics, Downstairs - Main is. Also the Primary Nodes are Blue which would indicate a Responder only which they are not. Abscent other information I take this to be an issue with Java 7.
Under membership the primary stat nodes say "responder to" only. The heat, cool and fan control all say "responder to" and "controller for". Is that correct?
Membership shows the Scenes if any the node is associated as a Responder or as a Controller. I do not have the words "responder to". What level ISY firmware is being used? If 3.2.6 run Help | About and verify Firmware and UI lines both say 3.2.6.
It means the node is a Responder to the Scene. A SwitchLinc, which is a Controller/Responder, can be assigned to a Scene as a Responder. When defined as a Responder the SwitchLinc does not function as a Controller for the Scene even though the SwitchLinc has Controller capability.
The posted image has no Scenes listed under "Is Responder to".
All-
FWIW, on my Mac with Java 6 I see Red Italic for controllers of a scene and Blue Normal for responders of a scene. Outside of a scene definition no Italics at all.
I have seen red italics in mine also. In my case I believe they where RemoteLincs.
Windows XP SP3 and all the updates. Java Version 6 Update 33.
      378.4k
