Isy notification to iPhone.
Hi Plau,
The service you are sending the notification to requires authentication (i.e. userid/password). You are not providing it the correct userid/password.
Hi Michel-
Prowl does not use user/pass but simply the API key for auth. I have many network resource rules configured for prowl that all work fine (after the first test fails usually). Here is what they look like for ref:
EDIT: Re: my comment about the first test usually failing, I haven't created any new rules on 3.3.3 or 3.3.4 so don't know if the first test fail is still an issue. Not that it was a big issue to begin with.
Hi Xathros,
Thanks so very much for clarification.
Hello firebladeRR1k,
Yes, absolutely. It just requires a lot of noise from our customers!
Yelling!
:P
