Insteon program with no If conditions
If I create an Insteon program with no if conditions, does the ISY periodically run the program's then clause? On what schedule?
The Program does not run unless invoked from another ISY Program
I might also add that if the program has run at startup enabled it will also run whenever the ISY is rebooted, whether manually or due to a power failure.
Sent from my SPH-D710 using Tapatalk 2
I always assumed that RunAtSartup meant RunIf-at-Startup. Will it actually run the then clause if there is no If evaluating to true ?
Yes. A null If section if considered True
Hi Xathros,
RunAtStartup will evaluate to TRUE if there are no If conditions.
Tanks Lee and Michel. Good to know. I don't think my assumption has had any effect on my configuration but I like to know exactly what to expect.
