mad_scot Posted December 4, 2012 Posted December 4, 2012 Having an issue generating a self signed cert on iSY99i Model: ISY 99i 256 IR Platform: ISY-C-99 Version: 3.2.6 I have no issue accessing externally via http or https but get the pop up warning about certificate. I can access the java app and request self signed cert but all I get is the Win 7 spinning circle. I cleared Java cach (using Java 7) - same issue. Tried on Chrome and IE8 with same result. It seems others have the issue too: viewtopic.php?f=27&t=7817 Also, I cannot generate a self signed cert or request for a CA, as the cursor just sits there spinning, and it never goes anywhere... Anyone have any advice for me. I'm new to certs but am well versed otherwise. Thanks mad_Scot viewtopic.php?f=27&t=7817
Michel Kohanim Posted December 4, 2012 Posted December 4, 2012 Hi mad_scot, Are you local to your ISY? With kind regards, Michel
mad_scot Posted December 4, 2012 Author Posted December 4, 2012 Yes - both PC and ISY99 were on local network, albeit PC was connected wirelessly and ISY99 is directly hooked into router port - same subnet, router for wireless and ethernet networks.
Michel Kohanim Posted December 5, 2012 Posted December 5, 2012 Hello mad_scot, Is this a 99 or 994? Are you using https://www.universal-devices.com/ssl/insteon? Are you certain that you have accepted the security warning for Bouncy Castle library? With kind regards, Michel
mad_scot Posted December 5, 2012 Author Posted December 5, 2012 from original post - take from help-about in admin console Model: ISY 99i 256 IR Platform: ISY-C-99 Version: 3.2.6
Michel Kohanim Posted December 5, 2012 Posted December 5, 2012 Thanks. Did you accept the security warning for Bouncy Castle library? With kind regards, Michel
mad_scot Posted December 5, 2012 Author Posted December 5, 2012 bouncy castle library warning - no - never saw anything like that.
mad_scot Posted December 5, 2012 Author Posted December 5, 2012 Here's sequence. Log onto 99i. Click Admin console Log into admin console. Then get pop up with titel "security warning", "ISY is currently configured with the default SSL cart." Two buttons - Disable Internet access and Request/manage SSL certs. Click Request/Manage SSL cert New browser window opens Then get popup "Warning - security", "Java has discovered application components the could indicate a security concern. Name: com.universaldevices.isy.keygen.ui.S ... "Block potentiall unsafe components being run?" CLICK No ISY Config util opens - log in again CLICK SSL Cert. management CLICK generate / install new self signed cert Cert parameters dialog opens I enter my Dyndns address Then guess what it worked!
badman85283 Posted April 14, 2014 Posted April 14, 2014 I am trying to manage SSL certs on 99i. Have firmware 3.3.10 and latest Java version. When I try to request SSL certs, i get the following error - Can you hep Java Plug-in 10.51.2.13 Using JRE version 1.7.0_51-b13 Java HotSpot Client VM User home directory = C:\Users\Praveen ---------------------------------------------------- c: clear console window f: finalize objects on finalization queue g: garbage collect h: display this help message l: dump classloader list m: print memory usage o: trigger logging q: hide console r: reload policy configuration s: dump system and deployment properties t: dump thread list v: dump thread stack x: clear classloader cache 0-5: set trace level to ---------------------------------------------------- Resource http://crl.globalsign.net/Root.crl has future expires: Sun Apr 27 19:37:49 PDT 2014 update check skipped. Resource http://crl.globalsign.net/primobject.crl has future expires: Sun Apr 27 19:37:49 PDT 2014 update check skipped. Resource http://crl.globalsign.net/ObjectSign.crl has future expires: Mon Apr 21 06:49:07 PDT 2014 update check skipped. Missing Application-Name manifest attribute for: https://www.universal-devices.com/ssl/sslmgr.jar
Michel Kohanim Posted April 15, 2014 Posted April 15, 2014 Hello badman85283, I am so so very sorry. Since 99 was discontinued, the application that allowed one to generate SSL certificates also expired. I am so so sorry. With kind regards, Michel
jlokanis Posted April 19, 2014 Posted April 19, 2014 Wait, are you saying that we can no longer access the admin console on our 99i units? I can understand that you discontinued the unit and are not offering any new features or bug fixes, but I expect the unit to continue to work as before without losing all ability to manage it. This is unacceptable. I suggest you find a way to correct this ASAP or start sending all 99i owners a free 994i unit.
Michel Kohanim Posted April 20, 2014 Posted April 20, 2014 Hi jlokanis, Apologies for not being clear. I didn't say that you can no longer access the Admin Console for 99. You can always use: http://isy.universal-devices.com/994i/4.1.2/ or http://isy.universal-devices.com/994i/4.1.2/admin.jnlp The main issue is whether or not you can create SSL certificates for 99 and, unfortunately, that's no longer possible. With kind regards, Michel
badman85283 Posted April 22, 2014 Posted April 22, 2014 Do you have an exchange program for 99i now that it is not supported?
LeeG Posted April 22, 2014 Posted April 22, 2014 badman85283 There have been some upgrade programs since the 99i was frozen more than a year ago. Click the Buy tab on the UDI web site. Select Universal Devices, scroll to the bottom of the page for the 99i to 994i upgrade options. .
