Admin Console
Hi
Through many releases I have a question regarding the admin console. Prior to being able to select different themes the console would revert back to a full screen display even though it had come up several times with the size that I had re-sized it to. After being able to select different themes it now after several times coming up correctly will not only go back to full screen display but also revert back to the default color blue.
Any suggestions?
Windows7
Isy99i now at 3.3.9
Always have cleared Java after each upgrade.
Gary
Hi Gary,
Please note that windows size settings are stored in your Windows temporary folder. Do you clean temporary files regularly?
Thanks Michel
That would explain it. My security software deletes temporary files as part of PC tune up.
Thanks Gary
