Event Viewer Level 0 - None?
In playing with the ISY this afternoon, I noticed that the event viewer has an option "0 - None" as opposed to "1 - operational events" or "3 - Device Communiction Events"
I selected "0 - None" just to see what it would do and the event viewer continues to show traffic and variable changes as they occur.
What is the intended purpose for this log level ?
That is odd. I changed level from the default 1 to 0. At level 0 the event viewer did not show Insteon traffic. Changed it to 3 and see all the Insteon traffic. Changed it to 0 and Insteon traffic stopped. Did not try variable updates.
This is what mine looks like after setting to 0 and hitting clear:
Wed 01/16/2013 04:22:13 PM : [VAR  2    6 ]       262962142
Wed 01/16/2013 04:22:19 PM : [VAR  2   23 ]       0
Wed 01/16/2013 04:22:31 PM : [VAR  2   11 ]       1250
Wed 01/16/2013 04:22:42 PM : [VAR  2   23 ]       1
Wed 01/16/2013 04:22:43 PM : [VAR  2    6 ]       262962229
Wed 01/16/2013 04:23:13 PM : [VAR  2    6 ]       262962249
Wed 01/16/2013 04:23:19 PM : [VAR  2   23 ]       0
Wed 01/16/2013 04:23:21 PM : [VAR  2   11 ]       1245
Wed 01/16/2013 04:23:41 PM : [VAR  2   23 ]       1
Wed 01/16/2013 04:23:43 PM : [VAR  2    6 ]       262962319
Wed 01/16/2013 04:24:10 PM : [VAR  2   10 ]       667
Wed 01/16/2013 04:24:10 PM : [VAR  2   11 ]       1239
Wed 01/16/2013 04:24:13 PM : [VAR  2    6 ]       262962409
Wed 01/16/2013 04:24:15 PM : [  11 A7 ED 1]      DON   1
Wed 01/16/2013 04:24:16 PM : [  11 A7 ED 1]       ST 255
Wed 01/16/2013 04:24:16 PM : [VAR  2   23 ]       0
Wed 01/16/2013 04:24:39 PM : [MOD  2  2  1  8] 298800.000000  Weather - Pressure = 29.88 inches
Wed 01/16/2013 04:24:39 PM : [MOD  2  2  1 18] 0.000000  Weather - Light = 0 %
Wed 01/16/2013 04:24:39 PM : [MOD  2  2  1 19] -6000.000000  Weather - Light Rate = -0.6 %/h
Wed 01/16/2013 04:24:41 PM : [VAR  2   23 ]       1
Wed 01/16/2013 04:24:43 PM : [VAR  2    6 ]       262962439
Wed 01/16/2013 04:25:00 PM : [VAR  2    9 ]       631
Wed 01/16/2013 04:25:10 PM : [  11 A7 ED 1]      DOF   1
Wed 01/16/2013 04:25:10 PM : [  11 A7 ED 1]       ST   0
Wed 01/16/2013 04:25:12 PM : [VAR  2    6 ]       262962459
Wed 01/16/2013 04:25:20 PM : [VAR  2   23 ]       0
Wed 01/16/2013 04:25:20 PM : [VAR  2    9 ]       636
The Insteon traffic is from a motion sensor that triggered during that capture.
Tried to post a screen shot but the attachment limit issue still seems to be a problem.
Hi Xathros,
It's quite possible that some other client is changing the level back to 3. 0 = no traffic whatsoever.
Hi Michel-
While I do access the admin console from 3 different machines, I don't think I've ever been connected from two or more simultaneously and certainly was not when I posted that yesterday. By "other client" do you mean another instance of the console? If not, then what? Also, the trace I posted doesn't look like a level 3 trace to me. As I recall, level 3 has more info than this one.
Thanks.
Another client would be something like MobiLinc, the DSC support, etc that is setting the level to 1 from the looks of the posted trace.
Thanks Lee-
I do use Mobilinc extensively but had no idea that it did anything with the event viewer. And I agree that it looks like level 1. I have noticed that if I set the event viewer to 0 then close and reopen the event viewer it is back at level 1 but I just assumed that 1 was the default. In testing just now I find that if I set level 3, close and reopen, it is still at level 3 however if I set 0 then close and reopen, its at level 1 so something is forcing a minimum of level 1 on my event viewer. During this testing the only things in contact with the ISY were the admin console on my laptop and caiwc running on my pogoplug. I don't think caiwc is doing anything to change the event viewer log level but I will suspend it's operation and see if it makes a difference.
EDIT: Stopping the caiwc connection makes no difference. My event viewer seems to be stuck with a minimum of level 1
I doubt the cai stuff is changing the event viewer unless it has ISY specific support. I have assumed the Admin Console insures the event viewer starts off active. Either at level 1 or something higher if previously set to a higher level (2 or 3). I would expect the event viewer to stay at level 0 so long as the event viewer remains active and another client is not used.
Thanks again Lee.
That makes perfect sense. Today, the log seems to be staying empty with level 0 selected unlike yesterday. I don't think anything aside from my upgrade to 3.3.10 has changed. It now behaves as you describe.
