Theme settings & MAC
Hi Michel-
Can you tell me how the choice of Admin console Theme is stored on the MAC? I set mine to "Desert" and it remembers it for a day or two but then reverts back to the default blue theme. I'm sure I am doing something to make it forget, just don't know what that something is...
Thanks.
Hi Xathros,
It's stored in Java temp directory. So, if you clear Java cache or your system clears the temp, it goes away.
Or simply restart the MAC. At least on 10.8 Didn't realize until I did some testing today as I don't frequently restart.
Hi Xathros,
Are you saying that every time you restart MAC, it clears the temp Java memory.
If that's the case, we have to think of a better solution.
Michel-
Every time I restart (3 systems running OS X 10.8.2 / Java 1.7.11), I lose the theme setting. Not sure if the Java temp is different than the Java cache. I am NOT clearing the cache unless doing a FW upgrade. I have been through all of the Java settings and see nothing that would clear the temp at restart. I can't say for but I think I've seen the same on a OS X 10.7 / Java 1.7.11 system.
This is not a major problem - just an annoyance. Happy to help with any testing if you need.
Michel-
Thanks.
-Xath
Hi Xathros,
Just verified that we do indeed keep everything in Java's temp folder. Are you sure you have Keep temporary files enabled for your Java?
We also discussed storing in ISY but soon realized that it would then make the theme dependent on the last person who changed it regardless of the computer.
Hi Michel-
I believe I do but maybe I missed something. I will double check. I like the idea of storing the setting in the ISY myself. I can't speak for others but I know that I am the only one that logs into my admin console. I wonder how many MultiUser ISY installs there are out there. Maybe when the ISY gets multiple username logins with unique permissions, storing the theme in the ISY will make more sense but I don't really see that as being a big stumbling point right now either.
Here are my Java Settings: https://www.dropbox.com/s/gp6yn4oswp5xyl2/Java_Temp_Settings.jpg
Sorry - the board attachment limit thing is still an issue. Is that a per user setting or global across the board?
Michel-
After every restart. If I just sleep the system and resume the next day, the setting remains just fine.
-Xath
Michel-
A full shutdown then startup or a simple restart - either way same result.
-Xath
