Guy Lavoie
Everything posted by Guy Lavoie
  1. Hmm, I don't think so. I only had a Google Home mini and my eisy, neither of which has a border router. Then I added the 4th gen Echo just to have a border router in vicinity, but still started by adding the Thread bulb (the Nanoleaf) to Google Home and then sharing to eisy. I'd be happy to be proven wrong... I was just experimenting. Interesting that the other Matter experimenter has chimed in! I think we're becoming due for another round of testing.
  2. Well I mostly experimented with Matter last spring, as a learning experience, when UDI was adding Matter support in IoX. I'd have to redo my tests because they apparently have improved the implementation. At the time it was difficult to directly configure a new Matter device directly in IoX. It was easier to first configure the device in Google Home or some other platform, and then use a share code to add it to IoX. Another thing is that I was mostly experimenting with a test Polisy, and it is now considered not to officially support Matter on the Polisy. It's ipv6 is an issue. But I still do have a light bulb (Thread too) that's configured on my eisy. I'll redo my tests eventually. These days I'm just more involved with eisy-ui, eisy-ai, etc. Installing a Matter over Thread device isn't any different from a Matter over wifi one. It's totally transparant, as long as you have a border router installed.
  3. A Thread border router is an "invisible" device. No configuration, settings, none. You just put it there, plug it in, and it works. I have a Amazon Echo 4th generation that does this. I also have a Eero 6 router setup that has this built-in. I guess UDI saw no value in reinventing the wheel. See the list of devices that have this functionality here: Matter AlphaThread Border Routers: The complete list of what you can...Although Thread doesn't need a "hub" in the traditional sense, you will still need another piece of hardware—a Border Router—to take advantage of its benefits. Here are all the Thread Border Routers o
  4. Leave it a couple of hours or overnight. Tell us if it fixes itself. I'd like to know what causes this.
  5. Yes, I don't think there is an easy way to migrate customizations and favorites. Good question.
  6. One workaround could be to assign a fixed ip address to the eisy. It needs to be left as dhcp, but you can assign it an alias address that is fixed. You could also put it's own name in it's /etc/hosts file with it's ip address. See here about setting an alias: https://forum.universal-devices.com/topic/47335-eisy-connectivity-due-to-dhcp/#comment-408818
  7. I haven't seen anything. I'm assuming that the game plan is to rely on a border router for Thread functionality.
  8. Both should work. I personally use the IP address because it skips any problem with local name resolution.
  9. A new eisy usually comes with a free 1 year portal subscription. If you have lots of time left on your Polisy portal subscription and don't need it anymore, you might try asking UDI if they can stack the remaining time with your subscription of your new eisy.
  10. I'm kind of surprised that no one has brought this up (or I haven't noticed it) but when editing a command where you choose a variable from your list of defined variables, they're listed in index number order. It kind of defeats the advantage of being to give variables meaningful names. You need to either memorize the index number of the variable you're working with, or search for it in the long list, which has it's text center justified, making the snaking beginning of the variable name even harder to find. Could they either be in ASCII order (like in admin console) or have a sort order button allowing us to choose? Having the names left justified would also make it easier to read through. I've never seen a programming tool with a list box showing center justified values.
  11. These are the controller's own calculated values (the same ones its schedules use), read from the contoller's /rest/time once a day and converted to the controller's local time zone. Minutes are truncated (5:43:41 shows as 5:43). The plugin needs access to the controller for this (Allow API Access), which is enabled in its registration. After enabling API access, the plugin must be restarted, then up to a minute may be required for the values to appear.
  12. The time between the restart and when you reconnected is probably all it needed. I'll add a note to the documentation.
  13. And then restart the plugin. And wait a few minutes.
  14. I've seen that happen too. And yes, it fixes itself after some time. I wanted to create a startup program that querys the devices but you really need to let it take it's time to recover.
  15. Guy Lavoie replied to DennisC's topic in eisy
    He just wants to see who religiously reads the release announcements! 🤣
  16. Guy Lavoie replied to DennisC's topic in eisy
    Hah, same here. I was tantalized by "99+% parity with the Admin Console". But I watched the udx log file as it upgraded and saw no eisy-ui update. After reboot, still seeing 1.4.13 too.
  17. Have you tried selecting the "Use a static IP address" checkbox? Then make sure the address, netmask and gateway displayed in the box remain as displayed.
  18. General programming is also somewhat slower. Contrary to Admin Console, you cannot "transform" a program line to another type of command. Even switching a line from testing for Status to Control for the same device requires you to delete the line and rebuild it from scratch, including selecting the node, etc all over again. then dragging it back to where you deleted the original line. Another thing is adding lines to a long program, you need to scroll back up to be able to click on "Add" for every new line.
  19. A few of us have seen this. Seems to have just gone away, possibly after a reboot or two. It's been a while.
  20. Sounds more like a IP connection issue. If you have a telnet client program, such as putty, try connecting to that address and port, and see if you get a connection. The port is configured as unsecure in the M1XIP, right?
  21. I've moved these over without issue: VenstarCT Hue Somfy ELK I'm running into an issue with one plugin (Virtual) because my installed version is from the beta store. Switching over to the production store isn't working because the version number in the production store is lower than my beta version. Hopefully that gets resolved when the production version at least matches the beta version I have.
  22. Ah yes, looks like my key is expired. That explains the odd response.
  23. "Hub" is what AI calls the controller. Doesn't do the eisy justice... but that's easy to modify in the README file. I'll change that to "controller" I was trying to find where you assign the plugin and/or nodes an icon and can't seem to find it. Hint?
  24. Another big missing piece is the Find/Replace function.
  25. If you can get your eisy to get it's date and time from a Julian date timer server, I'll look into it! 😀 For the sunrise/sunset time, you need to go into the "Configuration" tab for the plugin and slide "Allow API Access" to the right. Click on Save, then restart the plugin. Epoch is normally the number of seconds since Jan 1, 1970, in Unix anyways. Having an ever incrementing number of days value could be handy for doing math, so I'll look into adding that. In the meantime you can use the number of days since the beginning of the year for that, though it would require a reset when the year rolls over. The integer division thing works well for odd timer intervals, making good use of the modulo function. I'll have to check the icon thing. I wasn't aware we could define an icon. I'm still a total noob with plugins. Hey, that's the whole idea: throw it out there and let the suggestions come in 🙂
