Everything posted by Walt N
ZMatter USB Firmware Update 7.32 to 7.46
wmcneil Good to know that you made it to 7.46. I made it to 7.45 after multiple failed attempts and decided stop there. I would have kept at it,but noticed that all of my z wave mesh and long range are working correctly. If I find myself with some spare time, I will give it another go.
How to add old X10 devices to EISY-UI?
What a GREAT product and forum user group. Its good to know that some of the hardware that I have stored away in boxes somewhere can still be used. Its also good to know that there are folks on this forum willing to help make it useful again. Thank you EISY and forum users! 1980 hardware still functional, UNBELIVEABLE in any other place but here!
Z-Wave LR testing and observations
On my end, all of my everything seem to be working without issue. The long-range z wave stuff is playing nice with the z wave mesh stuff. I do not believe that the long-range items benefit the mesh but I'm only guessing and not having any issues. I know absolutely nothing about the Shelly devices but for the price I am thinking about ordering one to experiment with. They have a lot of interesting items. When I have had issues installing z wave devices changing the communication speed did not seem to help one way or the other. My best installation results happen when the new device is close to the dongle, then moved to location. Best of luck with your project.
Sunrise/Sunset Off w/ Time Change
So, Even though sunrise and sunset times are out of wack as stated earlier, all of my sunset triggered programs ran correctly. If I had not been paying attention, I would not have known that there was an issue. I am confident that this "non-issue" will clear up without a trip into a rabbit hole. Thank you all!
I just noticed the sunrise sunset times early and off different increments in my Eisy. Sunrise is one hour early, sunset is one hour 27 minutes early. The time change did occur correctly. I have not ever noticed this before but was not paying attention. I am happy to wait a day or two and look for it to magically correct. Thank you all for posting.
COULD NOT RESIST THE TEMPTATION! Updated the dongle to 7.45 using multiple steps. Deleted a Zooz multi relay out of mesh and re installed it into LR using a picture of the QRcode. Extremely easy from what I have come to expect with Zwave. I think it also picked up all of the device's attributes. I saw the LR options and used it. It appears to have installed correctly in the first LR position. ZY256, and nothing else has released smoke (yet). As before, I did install close to the dongle. I will be moving it far away to see how it performs. So far, I like what I'm seeing.
Edit Programs
Questions are a good thing. It works just like Guy indicates as long as you are in Automations/ Programs. Speaking for myself, I did not pick up on that the first time I looked.
I had the same experience. The higher the dongle, the better the results. Now the dongle is basically in the attic at the end of a usb cable, things appear to be going well. (Single story wood framed house and outbuildings.) I did install a range extender, spread zwave devices out and around the property to leverage the mesh. I also think that it's best to do a temporary install of a new z wave devices close to the dongle, activate them and watch status change in Eisy , move them to their intended location, Eisy activate and verify. Easy to do with plug in devices. Built in devices slightly more complicated. For them I do the temp install in a metal outlet box with grounded cord. This may be extreme, but it does avoid the issue I was having with messed up device additions. I am using mostly LR rated devices and believe that I installed them in mesh instead of long range. I recently came across the across the "getting it to work" thread and am in the process of building up the courage to update UD matter dongle and re-install the zwave devices as long range. I also feel that the Eisy-ui is making the process easier, seems to make more sense.
2876DB Icon turns it's self on.
Thank you Guy and TFJ1960! I ended up using the Admin console find/replace and found a really odd DON request for the switch in question. I have no idea how it ended up in that program. Thank you both.
I am dealing with a 2876db Icon dimmer that turns itself off every morning at 1:00 am. When I look at the log It shows a DON at 1:00 am with a 4 and 5 in the last two columns, I have looked at the other logs and don't see any potential causes. I have also looked over all programs and don't see commands asking it to DON. I have tried several hard resets, removed and installed it back into the system. I don't believe that any one is turning it on with that consistency every day. Could the switch be failing? Could there be any other place to look for a cause? Otherwise, I am extremely happy with Eisy-ui and will not have an issue removing this switch. I don't believe it has ever been part of a program or scene. Thanks for listening!
Upgrading Eisy from 5.8.4
It sounds like you are looking at administrative console, look at the top bar far right "HELP" Look at the bottom of the box. Mine says "MANAGE MODULES". When I left click on it, "YOUR MODULES ARE UP TO DATE" returns. I believe that it would indicate "MANUAL UPDATE" instead of "MANAGE MODULES" if there are updates available, but don't quote me on this. Does everything appear to be working? If so, reboot for good measure and use it, keep your eyes open. I also find the wiki to be my best first look when I have questions. https://wiki.universal-devices.com/Main_Page Best of luck!
Next scheduled run time defaults to tomorrow
Hello All, I am happy to report that since version 1.3.11 sunset and sunrise triggers are working flawlessly. The next program runtimes also in agreement with the time requested in the programs "if Statement" Thank you UDI support and FORUM
This morning I looked and saw eisy UI 1.3.8 was available so I went for it. After the upgrade and reboot, I still found the next run time statements were advanced by 2 hours. I changed the start times in a programs "if statements" IE: 2 hours earlier, and then the next run time statement was correct in the EISY display. I gave it a shot. When I checked this evening, the programs were actually running two hours earlier than the next run time indicated, exactly the time I requested in the programs "if Statement". So at this point it is my conclusion that the next run time statement for whatever reason is advanced by 2 hours and does not make a difference. The program will actually run at the time stated in the programs "if statement" (I think?). Since I was home before sunset, I did try a sunset trigger in a program's "if statement" and it did appear to work correctly. So far everything else seems to be working correctly. Thank you ALL!
I did see the staging repository with attached request from UDI "Please do not use the Staging repo unless requested by UDI Support." They said please, so I elected not to go there. I wouldn't want to create any additional problems for UDI or myself. I'm happy to wait unless someone from UDI tells me to go for it. Thank you all!
Speaking of "next scheduled run". I was believing that a reboot was correcting my program issues. As it turns out not exactly. I did temporarily move away from "sunset and sunrise " triggers and use fixed times in all of my programs. What I have discovered is that the run time in my "if statements" and the "next scheduled run time" listed in "Programs>Summarys" are not the same. The "next scheduled run times" are two hours later than my "if statements". If I edit and save a program, the next scheduled run time will be correct for one day. I am at IOX 6.1.2_3 using beta repo. I see that some are using 6.1.2_6. How were you able to get it? Thank you all!
Needing to authenticate daily
Good morning, For what it's worth. I am not using the ring plugin, but I do find myself having to reboot EISY-UI daily to keep my programs running. I believe that my issue is related to UD moving away from IOX and Java. I have started to use EISY-UI with the understanding that it is still a work in progress; problems are a "FEATURE". I have noticed that after reboot a program's next runtime looks good, then after that program event occurs, it's next runtime is out of whack or non existant. Again, after a reboot, the next run time is correct. I am using the beta versions and enjoy looking daily for newer versions. I believe that my issues will clear up in time. Hopefully you will benefit as well. I was comfortable with IOX, but the more I use EISY-UI the more I like it. After this issue clears, I will look into the ring plugin. Best of luck!
Presently UI 1.3.6 has not corrected this minor issue for me. I have a group of sunset related programs behaving oddly unless I reboot every day. Some of involve instion, others zwave. I am confident that this issue will be resolved with future updates. Good Times! Thank you all!
For what it's worth, I have also discovered that programs where sunset is used will run for one night after eisy reboot. They will not run the next night unless I reboot eisy. To mitigate this situation, I am currently rebooting once a day and then checking for updates!
Garage Motion detector battery died, replaced
@Mav2019 It sounds like you need to wake the motion detector up and then query it at the IOX. Another issue that I have had is that if it is a model with a 9 v battery, the connector may require re-tensioning. The connectors get bent out of shape when the battery is removed. I have replaced the batteries in all of my instion motion detectors with external power supplies because I got tired of the battery issues. I have had better luck with ZOOZ motion detectors, their batteries seem to last a long time. Congratulations on the new house and ISY. Enjoy the learning curve, it is definitely worth it in my opinion.
My Eisy-ui sent me down the same rabbit hole. After making a mess of things, I decided to not pay any more attention to it. Presently all of my programs seem to be running on time. I also notice that the last run times and finish times are out of whack and some programs that I know ran are not posting any last run times. I believe that a future upgrade is going to correct this issue. I like Eisy-ui and am looking forward to using it exclusively.
zooz motion sensor
danncas My experience with Zwave has always been interesting and mostly successful. The instructions that are given are hard to read but all the information should be there. As Techman indicated, put the sensor in linking mode and all of those green 1011 arrows should go away. After you do that, look at the instructions that came with the device and start to experiment. After you introduce the parameters you query the device and they should take effect. I think that I may have had to manually put the device back in link mode for the parameters to take hold. Zwave devices all are supposed to adhere to a standard and I believe that I was able to get more useful online from Zooz , It is as always a GREAT IDEA to backup everything prior to making any new additions or changes. Zwave is worth the effort in my opinion. I started using it do deal intermittent instion issues, so far I am happy. Best of luck
fl.ops setup.nvme boot error mesage
apnar, When I try the recreation I get the following. [admin@eisy ~]$ sudo gpart destroy -F nvd0 gpart: arg0 'nvd0': Invalid argument [admin@eisy ~]$ sudo gpart create -s nvd0 gpart: Invalid number of arguments. [admin@eisy ~]$. I will go back over everything again and see where I messed up. Thank you for your help. This is fun! Walt N
Good morning sudo gpart show nvd0 gpart: No such geom: nvd0. sudo dmesg | grep nv GEOM: nvd0: the primary GPT table is corrupt or invalid. GEOM: nvd0: using the secondary instead -- recovery strongly advised. This was the last two lines of about 1.5 screens of text. I did not want to over load my reply. I will be happy to post more of it if necessary. Thanks for your attention. Walt N
Hello, When I run sudo fl.ops setup.nvme boot I get the following response. executing from /usr/local/etc/udx.d/static gpart: No such geom: nvd0. nvme0: WD Blue SN580 1TB nvme0ns1 (953869MB) gpart: No such geom: nvd0. Mon Mar 11 15:18:15 PDT 2024|/usr/local/etc/udx.d/static/fl.ops: adding GPT partition to nvd0 ... gpart: geom 'nvd0': Operation not permitted Mon Mar 11 15:18:15 PDT 2024|/usr/local/etc/udx.d/static/fl.ops: error: failed creating gpt partition ... I did use the "SIMPLE" take over the whole disk method. All of the steps prior to "sudo fl.ops setup.nvme boot" seemed to complete correctly. I'm thinking that I need to delete the first ZSF pool that I created on nvme0 and start over. I only know enough to be dangerous! Any advise will be appreciated. Walt N
Portal license renewal issue
DennisC I was trying to renew on my smart phone ud mobile. I was able to renew using isy portal just now. Thanks for your response. Walt N
