Brian H
Everything posted by Brian H
  1. I have also used similar devices to sense when a device is drawing current.
  2. Does the eisy still have a Replace PLM function? When you install a replacement PLM and then reboot so the controller knows you have a new PLM. You had to use the Replace PLM function. To go out to all the modules and replace the old PLMs six digit ID with the replacement PLMs six digit id. If the replacement PLM sends commands with the new id to a module with the old PLMs id It will not respond.
  3. I also found my 2440 original RemoteLinc. Would not link if close to the PLM. I had to put it into the linking mode located at the other end of the home. So the PLM had use a different Insteon dual band device using that devices RF.
  4. Battery data from old Smarthome site. The part where I thought there was no protection board was incorrect. It did have a protection board on the battery. Battery.pdf
  5. FCC Database: https://apps.fcc.gov/oetcf/eas/reports/GenericSearch.cfm Grantee SBP: Product Code: 23422 Details.
  6. Yes there was a post on the old Smarthome forums on changing the battery. I may have a archived copy. If memory is correct. The exact battery was not available when I looked. There are internal and external photos and original users manual in the FCC Database web site.
  7. I feel it is more like the battery is near end of life and the charger is preventing over charging. As I believe the red led was never flashing in a remote even the original units. The finding that if you use it for awhile and then try charging it and the red led is not flashing but then again flashing again. Sounds like the battery is above the normal full charge voltage and the charging circuit is stopping an over charge voltage. Try Insteon support. They should have a more definite answer. https://support.insteon.com/#gsc.tab=0 Forum. https://forum.insteon.com/forum
  8. v1.7 is an older revision. The date code looks like week 50 of 2014. My 2342-232 (4 scene) is a v2.05 date code 1631 week 31 of 2016. My thoughts are the battery is getting weak and the charging circuit is not seeing the battery voltage high enough to trigger the fully charged sensor. So its always trying to charge the battery. The battery has an over charge & over current circuit so it should not be effected too much. As a test. Try seeing how long the remote works after a few hours charging. To see how long the remote works before needing a refresh charge.
  9. I use a 5VDC 1000mA(1A) cell phone charger. After checking your chargers ratings. You may want to see if a different charger may give you different results. As I have seen some of the new ones have multiple outputs and hand shake with the device being charged for it's output. Though it should default to 5VDC. Remote chance the remote is is defective or near end of life. After many charge discharge cycles we occasionally see battery failures or diminished capacity. The label on the back of the remote. Could give you something to check on its revision number and maybe age.
  10. Charge LED on the lower right side inside the case. On mine near the USB charging port. Is solid red when charging and turn off when charged. Is this a newly purchased remote? I doubt they changed the way it works. Maybe see what other have found for a better understanding if it is changed or defective.
  11. One thing I forgot. The PLM both 2413S and 2413U. Use a HEX message for receiving and sending data. Get Version should get a reply back with the PLMs information. 02 60 Cartridge return. Should send back 02 60, the PLM's data and end in an 06 ACK. The serial 2413S also had serial port interface chip problems occasionally. Rev 2.3 changed the chip for one with better ESD protection. V2.4 and above. Have a new serial port daughter board that also has a protective on the serial in and out signals from the PLM.
  12. Wrong serial settings. 19,200 8 Bit No Parity 1stop bit. Bad caps frequently. Caused things like 0 or few links in it. Restoring it so the link count is more normal but then eventually is again 0 or very low link count. Runs for a short while after a power cycle. Are you running windows and a serial port? There are a few programs to access it but are more for folks that can use the low level commands to see what it is doing.
  13. If you want to use the2413S serial PLM on an EISY you need the UDI USB to serial cable they sell. The EISY does not do serial communications to the PLM. If you try a USB to Serial port adapter. It will not work. The serial signals are not correct for a standard adapter.
  14. Powered down for awhile and working for a short time after power up. Was one of the known problems when the PLM was failing. The ISY994i only checks for the PLM Status Info. When it is booting up. If you disconnected the PLM and the ISY994i was not rebooted. It will still be reported as connected. Even though it is not connected or has gone off line.
  15. It did a Query of all the modules in the setup. To find their status and see if any of them where not reachable. Mine was 3:00 AM. I do not know how important it is these days of almost all dual band devices. Can't say about Eisy as I am still on an ISY994i.
  16. Brian H replied to matapan's topic in ISY994
    Glad you got it working. The information may assist someone with similar issues.
  17. Brian H replied to matapan's topic in ISY994
    I would not remove or insert an SD Card with the powered on ISY994i. Asking for damage and most of the ISY994i firmware is on the SD card.
  18. Brian H replied to matapan's topic in ISY994
    In the ISY994i. Only a small loader is in the processor on the board. Most of the remaining operating system is on the SD card now formatted but with out needed firmware. The link in the SD card replacement. Gets you access the ISY994i Administrative Console. You then have to use a backup to add the rest of the needed firmware, and others like your stored programs etc.
  19. Brian H replied to matapan's topic in ISY994
    Did you follow step 3 and start the program to add the firmware to the ISY994i? As the SD card does not have the needed firmware in it to be successfully started normally. Then you pick the backup you want to use in it. The telnet format was supposed to get you a slightly better performance. I too had it look like it didn't give the last expected ending but seem ed to work fine.
  20. Good information. It does have a rely and bypasses the dimmer section.
  21. I would do an eisy or eisyR2. The Polisy is no longer sold and I recently received a UDI update email. The Polisy is now in the Maintenance phase.
  22. Possibly age may make a difference. If the 2423S is an earlier revision than the 2413U. Though recent revisions seem to have the problems resolved.
  23. Brian H replied to Techman's topic in eisy-ui
    I don't think an All Insteon Command can be directly sent. Like TJF1960. I created a scene with every device in the system.
  24. No I have not seen any schematics except the 2412 and 2413 PLM On the revision you are showing. The 30V Zener is under the horizontally mounted 470uzf cap. I had one of the diodes short killing the whole thing. One thing I did find out. Both revisions have the +5VDC logic supply. Directly connected to the Line hot AC input and regulation is on the - supplies side.
  25. That photo is for the later revision units. With the 24VDC relay. The earlier versions in the schematic had a 120VAC relay and a real small solid sate device to put a120VAC signal on the relay. Also had the two small bypass caps in series as a snubber. Across the relay contacts. They eventually shorted and the load tried to go through them. Magic smoke. Your model has a better snubber network in it.
