Brian H
Everything posted by Brian H
  1. One of the symptoms of a failing PLM was the Link Database having no or very small entries. It does not sound like yours had the issues.
  2. I also have seen older power line only devices have X10 issues. Especially the I1 devices that take 8 messages to program one line in a link database.
  3. Good to see you are again working.
  4. Now they want to mess with keeping Daylight Saving time. Every time some politicization tries to do what they think I need the short end of the stick is all get. ☹️
  5. I would also try a replacement power supply. I have similar issues with both my ISY99i and ISY994i. Try to boot,supply shut down tried to start again in an endless cycle.New supply fixed the issue.
  6. Brian H replied to johnmsch's topic in ISY994
    Even when a 2477D is set to 100%. There is a short time near zero crossing. There is a time before it conducts. If the fan is inductive. That short no conduction can also lead to issues. Can't say about a I3 paddle. 2477S is also an on-off style.
  7. I agree it maybe the power supply. Though your post seems to point more to the SD card. Maybe it got slightly corrupted at power loss or the accidental incorrect ZWave file messed something up. I have had a few over the years. One was weak and my ISY994i was fine until the power went out and then it refused to start. Just a loop of trying to boot, supply shut down and then it tried again.
  8. Just some information. The Z Wave board was an option and not all versions ISY4i had Z Wave as sold but we could add one if we wanted too. Most electronics are now much more expensive. Even big vendors have chanced prices. Even Apple. Data centers are sucking up RAM and causing price changes upward.
  9. Docs are also here but some maybe duplicates with different revisions. https://github.com/pyinsteon/pyinsteon/commit/2533494a8b13b30b2d0938c9a18afe782b740410
  10. A new 2413U probably would be best. Even if stored for a backup. The 2413S serial PLM used by older ISY controllers has been discontinued by Insteon so older users may need to find a new way to replace the PLM or a rebuild.
  11. Thank you for the information. We have seen other posts indicating caps didn't always correct things. 2.4 should have the updated serial port daughter board with the better serial interface chip and a surge protection network on the serial signals to the outside world. Along with the better caps. The 2413S serial PLM is now discontinued on the Insteon sales site.
  12. All the way back the Joe Dada Smarthome Insteon days. New module issues where fixed many times with a factory reset before use. Some did not get reset in manufacture. Many users always did a factory reset before use.
  13. There was for a short tine a five amp version. After examining both version. Only thing I found was a different fuse and a higher price for the 10Amp model. 10Amp, fast blow, 5mmX20mm axial leads, ceramic body. There was a post here a long time ago. Where a member found bad solder joints on the heavy coil leads and re soldering them to the PC board made them operational again.
  14. I still have a pair of Access Points in use. You may want to check the date on them. Rev 2.0 and newer are built on the base 2413 PLM board and have the same failed capacitors we see in the 2413S PLM. I had to rebuild a pair myself. The 4 tap/communications builtin test, May give you some added data.
  15. I have a few I rebuilt and a spare new one myself.
  16. The Insteon web site now says the 2413S serial PLM is discontinued and no longer supported. This should only effect the users still using a ISY994i. InsteonSerial Modem Interface (PLM)This item has been discontinued. Please see our USB Modem Interface.
  17. Correct . The Insteon sales site. Says the 2413S PLM is discontinued and no longer available.
  18. If I remember correctly. The add on IR Module was needed for the IR module to work. After I got my IR module. UDI had to download something to my ISY994i.
  19. A factory reset before installation has fixed issues for some users. Some had test stuff in them and not reset before sales.
  20. Bright LED is only one symptom. It can still be bad with a bright LED. Best to do what you thought. Ticket so UDI can help you troubleshoot.
  21. Did you power cycle the Eisy also? The PLM is most likely only checked for a boot up. Is the LED on the side of the PLM on at about its normally brightness? Sounds like the PLM has failed or is almost completely failed. How old is it? Sticker on the back should give you information.
  22. Brian H replied to hspindel's topic in eisy
    Thank you for the update.
  23. Brian H replied to hspindel's topic in eisy
    The SH10A is receive only and will not send an acknowledge back. You probably are seeing the PLM acknowledging the command. Since the PLM sends the command back to verify it was valid and sent.
  24. Brian H replied to hspindel's topic in eisy
    The X10 commands require a short delay between commands. Like the address has to be sent and then a short (not much but don't have exactly known) time the bright or dim command. I am not a programing type so if the slight delay maybe needed. I can't say how to do it. That maybe but not for sure your problem. The ISY controller that worked maybe running slower than the eisy that doesn't work. With the short delay long enough with the ISY controller.
  25. Brian H replied to hspindel's topic in eisy
    The small siren. Need the X10 address sent and then the bright or dim command. Did you send the address than a small pause to the dim or bright? Do you have any other X10 devices that are still OK? If others also stopped working then I would suspect something changed power line problems.
