Everything posted by sdynak
Gmail “tls error” message
The default with ISY is intermittent and over the years I have had similar instances so resorting to gmail and Pushover was the resolution until now where Pushover is still solid. I am still seeing the default working at times but again is inconsistent. For example, most of the day yesterday it was not working and come late evening it started working again. I do not know what is going on when it doesn't and when it doesn't, there is an error when running a test (did not capture my bad) but if it were due to changes, I would expect it to be not working at all. That is not the case and wonder if eisy users see this as well. I do not have any complex use with the ISY which is why it still works well for me on the latest version aside from this. I even pay the higher portal fees over the eisy as the benefit to me is not there to go with eisy at this time. Maybe in the future, but it's like getting a new car when yours is fine and still has low miles serving the purpose getting you where you need to be. Remaining optimistic as I don't need a new car just yet. Able to catch when the ISY default doesn't work error. Interesting thing is it worked and just a minute later did not.
Priority 2 Pushover Alerts Fail to iPhone
Hi Paul, You nailed it again. In the Pushover app there is a setting for enabling the Critical Alerts for Emergency which apparently are #2. I enabled this and have the red alert now and the sound comes through. Honestly, never knew the volume was adjustable on Critical alerts. If this doesn't get my attention, my wife's or anyone around us on the deafening setting if there is a smoke or CO alert nothing will. So in summary.. you need to add the "retry" & "expiry" settings as well as ensure the Pushover app is enabled for Emergency Alerts. I changed the 60 seconds to 30. That seemed like the minimum. I tried 20 and under and it failed. I do see these settings on the Pushover site and not sure how I missed it before. Thanks for your guidance and all you do here as always! You could have saved a life or my pets (2 birds & 2 dogs) in the future. Best, Stan
Many thanks Paul.. I’ll check more into that and might reach out to Pushover if nothing obvious turns up. You got me further than before :). Thank you
Thanks Paul.. Although I don't get an error when including those changes now I lose the sound and the alert changes to time sensitive losing the red exclamation. Here is a screenshot of my home screen showing both the priority 1 in red and the priority 2 that looks plain. I'm not as concerned as the exclamation but no alert tone bypass would be an issue. I did try changing orders like putting the sound right after priority and after the retry/expire and didn't seem to change that. Here is my last test line: token=XXXX(replaced for forum)&user=XXXX(replaced for forum)&priority=2&retry=60&expire=3600&sound=persistent&device=Stan_iphone&message=Home Fire Alert!!
Hi Paul.. Apologies for any confusion.. I made assumptions based on my use of Pushover as I only use it with network resources for Pushover alerts on my iPhone. The screen capture is a result running a test for the network resource. I don't know how resource uses the Pushover backend such as the email error that is displayed. I am doing this on my ISY and was not sure what other section would be more suitable but happy to move it there if there is a better place to create it. It will work fine until I change the priority to 2. Config in Network Resources: POST /1/messages.json HTTP/1.1 Host: api.pushover.net:443 User-Agent: Mozilla/4.0 Connection: Close Content-Type: application/x-www-form-urlencoded Content-Length: 145 token=XXXX(replaced from actual)&user=XXXX(replaced from actual)&priority=1&sound=persistent&device=Stan_iphone&message=Home Fire Alert!!
Hi there everyone! I have not attempted to enable a Priority 2 Pushover alert to date and have used Priority 1 till now. I just installed a Zooz DC signal sensor tied into my linked smoke/CO detector system. Everything works well with Priority 1 but if I try to use Priority 2 I get an error for TCP Client. I assume this is a iPhone limitation but just wanted to see if others might have been through this or have a workaround. I did try to do some searches and did not come up with anything related. Thanks as always for your thoughts! Best, Stan
Does anyone know of an Email Service for ISY994?
Might sound strange but try to put something in the From* field (Edit.. I see Geddy also mentioned this above). I recall I had an issue and that resolved it for me and it still works (not using default myself as that had issues some time ago). Likely gmail rejecting if blank. I also do not fill out the full @gmail.com and only use my user ID and it works fine. Doubt that is it but worth a try if you still have issues. As you already mentioned do make sure you use the App PW. It will not work without that for sure.
AT&T texting alternative for wife
2nd Pushover.. ever since e-mail to text got spotty some years back with T-Mobile I finally took the plunge about a year ago. Rock solid and the customizations are great with the critical alert in those needed situations. More reliable than a text or e-mail trust me. It never fails.
Can no longer send notifications to tmobile phones
Ok, I'm not familiar with the Gmail workspace and if it functions the same. Are you using a "App Password" for Gmail? I believe you need this to make it work as a more secure environment. Not sure that will work with your domain setup. You could always just try a standard Gmail account and test. This could help also -
Doesn't the user need to be a gmail account or did you not update the SMTP server settings? Seems you are using a gmail SMTP but a ID for sandbergweb.com.
Had the same with T-Mobile over some time and finally switched to Pushover about a year ago now. Works way better and reliable with customization like Critical override. Worth the $5 if it is still that price.
Geofence Default Notifications
Thanks Javi.. good to know I wasn’t missing something. I’ll look into the plugin.
Sorry if this has been answered already but searching did not seem to have a clear answer. Are there default notifications for the UD Geofence when crossing in/out like Locative does? I believe the answer is "no" but before I look at other options, I just wanted to be sure I was not missing something. Thanks in advance.. Stan
Pushover with variables possible?
Awesome.. guess I have been living in a cave.. LOL
Thanks again Maxnorth.. Just wanted to share the entire message is working just as it was with e-mail. I thought maybe it could create a limit issue but doesn't seem that way. I should have done this a long time ago!
You Sir are awesome!! I didn't think to just put it right in the message like that!! Just have to see if I can make one message or need to make all individual.. regardless it is possible !! Thank you!!
Hi there everyone!! Yes.. I am way behind the times with notifications and at the end of trying to keep e-mail to text working with any carrier (currently T-Mobile). So I have started to finally convert to Pushover after dabbling with it some 7 years ago and not following through. So far I have most of my notifications working with Pushover the way I like, but my old notification from e-mail I used for the leak sensor / on-off modules status alerts. I searched for answers but didn't seem to find what I'm looking for and the Pushover API options didn't seem to offer more insight or I'm just not advanced enough. Is it possible to have a variable customization sent using Pushover? Here is the e-mail customization I'm looking to use with Pushover: A problem has been detected with a leak or on-off sensor. Details below: Basement Leak: ${var.2.7} Bath Down Leak: ${var.2.8} Bath Down Leak Sink: ${var.2.9} Kitchen Sensor Leak: ${var.2.10} Laundry Sensor Leak: ${var.2.11} Master Bath Leak: ${var.2.12} Master Sink Leak: ${var.2.13} Bath Up Sink Leak: ${var.2.14} Bath Up Leak: ${var.2.15} Kitchen Water Heater Leak: ${var.2.29} Furnace Heater System Leak: ${var.2.28} Utility Sink Leak: ${var.2.3} Refrigerator Leak: ${var.2.25} Water Cooler Leak: ${var.2.26} Washing Machine Leak: ${var.2.27} Furnace Water Heater Leak: ${var.2.30} On Off Basement French Door: ${var.2.17} On Off Dining Room Slider: ${var.2.18} On Off Family Room Slider: ${var.2.19} On Off Front Door: ${var.2.20} On Off Side Garage Door: ${var.2.21} On Off Small Garage Overhead Door: ${var.2.22} On Off Basement Door: ${var.2.23} On Off Hallway Closet Door: ${var.2.24} ---Status Key--- 1 = Heartbeat OK (normal status) 2 = Heartbeat missed 3 = Heartbeat check program not running 9 = Leak detected ---------------- Note 1: It may take up to 36 hours for a "heartbeat missed" signal to clear. Note 2: Status Code 3 indicates the "Variable Control 2" program is not running for some reason.
Isy 994i starting to die??
If it had something to do with the end of life it would have stopped working last year. That's all I meant. Oh ok.. the link didn't indicate anything like that and that was not what I was trying to insinuate. Apologies for any misunderstanding. As mentioned in the article you can have a transfer from one unit to another for $125 and paid support ends June 1st this year so might want to get a transfer now before that ends. That was what I was trying to help with as it was in the article I linked and posted below now so you can see. I would reach out to support and open a ticket before it is too late if you want to keep the 994i going for a bit longer and suspect yours if failing. Hope you can get it resolved. Free technical support will cease for any issues relating to ISY994 Series. Paid support will remain available till 06/01/2024. You can no longer add modules to your existing ISY994s. All requests for transfer from one 994 to another 994 will require a $125 transfer fee.
I'm not sure what you mean about working for a year but it has some references to your questions and some Q&A at the end which is why I linked it. Thought it might be helpful. I still use the 994i also.
Maybe this is helpful if you did not see it. https://www.universal-devices.com/finalbye994/
OAuth error showing devices
Yes.. working here again!! Thanks!!
Updated to 1.1.61 and still get error. Hoping this can be resolved.
Hi Javi, Yes, local works.
Same issue here as of this morning. Synchs fine and remote connection test successful. Just my devices in UD mobile don’t update itself. Web portal fine and can login ok.
New Insteon 8-button keypad not recognized by UD admin console
Also.. make sure you enter the address exactly as shown.. I have errored this myself more than I would publicly admit 😀
