iOS 7 Home Screen Shortcut to ISY994i Hangs On Load Config
Whenever I try to use an iPhone HomeScreen Shortcut to access the default web interface of my ISY994i (v4.0.5), under iOS 7.x, the shortcut hangs.
I didn't have any problems under iOS 6.x.
For example, on my iPhone 5, using iOS 7.0.2:
- use Safari to access my ISY994i by going to http://10.0.2.202
- Safari will resolve to http://10.0.2.202/WEB/INDEX.HTM'>http://10.0.2.202/WEB/INDEX.HTM'>http://10.0.2.202/WEB/INDEX.HTM
- tap the middle button at the bottom of the Safari screen to "Add To Home Screen"
- a Home Screen Shortcut will be created to access http://10.0.2.202/WEB/INDEX.HTM
If I tap on that newly created Home Screen Shortcut, the Universal Devices logo appears, but the page gets hung up on "Load Config" and doesn't display anything else. (screenshot attached)
If I use Safari on my iPhone and manually enter http://10.0.2.202/WEB/INDEX.HTM it works fine.
Any suggestions for getting Home Screen Shortcuts to my ISY994i working under iOS 7.x?
Thanks for any help.
Patrick
Hi Michel:
Unfortunately the button to 'Add to Home Screen' doesn't present itself until after the web page has been loaded in Safari. (i.e. until after the URL is resolved as http://10.0.2.202/'>http://10.0.2.202/WEB/INDEX.HTM'>http://10.0.2.202/WEB/INDEX.HTM'>http://10.0.2.202/WEB/INDEX.HTM'>http://10.0.2.202/WEB/INDEX.HTM)
Also, there is no way to edit the URL used by a Home Screen shortcut.
Creating a Safari bookmark, on my iPhone of either http://10.0.2.202/ -or- http://10.0.2.202/WEB/INDEX.HTM works fine.
On an iPad, running iOS 7.0.2, the results are slightly different:
- a Home Screen shortcut accessing http://10.0.2.202/WEB/INDEX.HTM still doesn't work (same as iPhone)
- using a a Safari bookmark, of either http://10.0.2.202/ -or- http://10.0.2.202/WEB/INDEX.HTM results in an "Authentication Required" dialog. Entering acct/pswd of admin/admin allows access to the web page. Subsequent use of either bookmark does not require authentication, just direct access to the web page.
Patrick
Hi Patrick,
Thank you. Can you do me a favor?
Please:
1. Go to Tools | Clear Error Log
2. Go to Tools | Diagnostics | Event Viewer, change the level to 3
3. Try those bookmarks on your Safari (on iPad and then iPhone) on the homescreen
4. Go to Tools | Error Log ... copy/paste the contents back here
Hi Michel:
Here are the results.
Patrick
Time User Code Message
Mon 2013/09/30 05:08:55 PM System -170001 [HTTP] 10.0.2.16:53197->80
Mon 2013/09/30 05:09:44 PM System -170001 [HTTP] 10.0.2.19:51739->80
Mon 2013/09/30 05:09:44 PM System -170001 [HTTP]: GET-->/WEB/INDEX.HTM
Mon 2013/09/30 05:09:44 PM System -170001 [HTTP]: GET-->/WEB/itouch.css
Mon 2013/09/30 05:09:44 PM System -170001 [HTTP] 10.0.2.19:51740->80
Mon 2013/09/30 05:09:44 PM System -170001 [HTTP]: GET-->/WEB/udi.css
Mon 2013/09/30 05:09:44 PM System -170001 [HTTP]: GET-->/WEB/jtemp.js
Mon 2013/09/30 05:09:44 PM System -170001 [HTTP]: GET-->/WEB/jquery.js
Mon 2013/09/30 05:09:44 PM System -170001 [HTTP] 10.0.2.19:51741->80
Mon 2013/09/30 05:09:44 PM System -170001 [HTTP]: GET-->/WEB/cookie.js
Mon 2013/09/30 05:09:44 PM System -170001 [HTTP]: GET-->/WEB/isyajax.js
Mon 2013/09/30 05:09:44 PM System -170001 [HTTP]: GET-->/WEB/camTypes.js
Mon 2013/09/30 05:09:45 PM System -170001 [HTTP] Closing socket normally
Mon 2013/09/30 05:09:45 PM System -170001 [HTTP] 10.0.2.19:51742->80
Mon 2013/09/30 05:09:45 PM System -170001 [HTTP]: GET-->/WEB/jjson.js
Mon 2013/09/30 05:09:45 PM System -170001 [HTTP]: GET-->/WEB/common.js
Mon 2013/09/30 05:09:45 PM System -170001 [HTTP] 10.0.2.19:51743->80
Mon 2013/09/30 05:09:45 PM System -170001 [HTTP]: GET-->/WEB/jstorage.js
Mon 2013/09/30 05:09:45 PM System -170001 [HTTP]: GET-->/WEB/flot.js
Mon 2013/09/30 05:09:45 PM System -170001 [HTTP] 10.0.2.19:51744->80
Mon 2013/09/30 05:09:45 PM System -170001 [HTTP]: GET-->/WEB/hashch.js
Mon 2013/09/30 05:09:45 PM System -170001 [HTTP]: GET-->/WEB/udlogo.png
Mon 2013/09/30 05:09:45 PM System -170001 [HTTP]: GET-->/rest/config/
Mon 2013/09/30 05:09:45 PM System -170001 [HTTP]: GET-->/WEB/bg_menu.gif
Mon 2013/09/30 05:09:45 PM System -170001 [HTTP] 10.0.2.19:51745->80
Mon 2013/09/30 05:09:46 PM System -170001 [HTTP]: GET-->/apple-touch-icon-152x152-pr
Mon 2013/09/30 05:09:46 PM System -170001 [Auth] 10.0.2.19:51745->80, Num=3
Mon 2013/09/30 05:09:46 PM System -170001 [HTTP]: GET-->/apple-touch-icon-152x152.pn
Mon 2013/09/30 05:09:46 PM System -170001 [Auth] 10.0.2.19:51745->80, Num=4
Mon 2013/09/30 05:09:46 PM System -170001 [Auth] 10.0.2.19:51745->80, Num=5
Mon 2013/09/30 05:09:46 PM System -170001 [HTTP]: GET-->/apple-touch-icon-precompose
Mon 2013/09/30 05:09:46 PM System -170001 [Auth] 10.0.2.19:51745->80, Num=6
Mon 2013/09/30 05:09:46 PM System -10108 Check log
Mon 2013/09/30 05:09:46 PM System -170001 [Auth] 10.0.2.19:51745->80, Num=7
Mon 2013/09/30 05:09:46 PM System -170001 [HTTP]: GET-->/apple-touch-icon.png
Mon 2013/09/30 05:09:46 PM System -170001 [Auth] 10.0.2.19:51745->80, Num=8
Mon 2013/09/30 05:09:46 PM System -170001 [Auth] 10.0.2.19:51745->80, Num=9
Mon 2013/09/30 05:09:46 PM System -170001 [HTTP] Closing socket normally
Mon 2013/09/30 05:10:01 PM System -170001 [HTTP] 10.0.2.18:55280->80
Mon 2013/09/30 05:10:01 PM System -170001 [HTTP]: GET-->/WEB/INDEX.HTM
Mon 2013/09/30 05:10:01 PM System -170001 [HTTP]: GET-->/WEB/itouch.css
Mon 2013/09/30 05:10:01 PM System -170001 [HTTP] 10.0.2.18:55281->80
Mon 2013/09/30 05:10:01 PM System -170001 [HTTP]: GET-->/WEB/udi.css
Mon 2013/09/30 05:10:01 PM System -170001 [HTTP]: GET-->/WEB/jtemp.js
Mon 2013/09/30 05:10:01 PM System -170001 [HTTP]: GET-->/WEB/jquery.js
Mon 2013/09/30 05:10:01 PM System -170001 [HTTP] 10.0.2.18:55282->80
Mon 2013/09/30 05:10:01 PM System -170001 [HTTP]: GET-->/WEB/cookie.js
Mon 2013/09/30 05:10:01 PM System -170001 [HTTP]: GET-->/WEB/common.js
Mon 2013/09/30 05:10:01 PM System -170001 [HTTP]: GET-->/WEB/camTypes.js
Mon 2013/09/30 05:10:01 PM System -170001 [HTTP] Closing socket normally
Mon 2013/09/30 05:10:01 PM System -170001 [HTTP] 10.0.2.18:55283->80
Mon 2013/09/30 05:10:01 PM System -170001 [HTTP]: GET-->/WEB/jjson.js
Mon 2013/09/30 05:10:02 PM System -170001 [HTTP]: GET-->/WEB/flot.js
Mon 2013/09/30 05:10:02 PM System -170001 [HTTP] Closing socket normally
Mon 2013/09/30 05:10:02 PM System -170001 [HTTP] 10.0.2.18:55284->80
Mon 2013/09/30 05:10:02 PM System -170001 [HTTP]: GET-->/WEB/hashch.js
Mon 2013/09/30 05:10:02 PM System -170001 [HTTP]: GET-->/WEB/isyajax.js
Mon 2013/09/30 05:10:02 PM System -170001 [HTTP] 10.0.2.18:55285->80
Mon 2013/09/30 05:10:02 PM System -170001 [HTTP]: GET-->/WEB/jstorage.js
Mon 2013/09/30 05:10:02 PM System -170001 [HTTP]: GET-->/WEB/udlogo.png
Mon 2013/09/30 05:10:02 PM System -170001 [HTTP]: GET-->/rest/config/
Mon 2013/09/30 05:10:02 PM System -170001 [Auth] 10.0.2.18:55285->80, Num=10
Mon 2013/09/30 05:10:02 PM System -10108 Check log
Mon 2013/09/30 05:10:02 PM System -170001 [HTTP]: GET-->/WEB/bg_menu.gif
Mon 2013/09/30 05:10:02 PM System -170001 [HTTP] 10.0.2.18:55286->80
Mon 2013/09/30 05:10:02 PM System -170001 [HTTP]: GET-->/apple-touch-icon-120x120-pr
Mon 2013/09/30 05:10:02 PM System -170001 [Auth] 10.0.2.18:55286->80, Num=11
Mon 2013/09/30 05:10:02 PM System -170001 [Auth] 10.0.2.18:55286->80, Num=12
Mon 2013/09/30 05:10:02 PM System -170001 [HTTP]: GET-->/apple-touch-icon-120x120.pn
Mon 2013/09/30 05:10:02 PM System -170001 [Auth] 10.0.2.18:55286->80, Num=13
Mon 2013/09/30 05:10:02 PM System -170001 [Auth] 10.0.2.18:55286->80, Num=14
Mon 2013/09/30 05:10:02 PM System -170001 [HTTP]: GET-->/apple-touch-icon-precompose
Mon 2013/09/30 05:10:02 PM System -170001 [Auth] 10.0.2.18:55286->80, Num=15
Mon 2013/09/30 05:10:02 PM System -170001 [Auth] 10.0.2.18:55286->80, Num=16
Mon 2013/09/30 05:10:03 PM System -170001 [HTTP]: GET-->/apple-touch-icon.png
Mon 2013/09/30 05:10:03 PM System -170001 [Auth] 10.0.2.18:55286->80, Num=17
Mon 2013/09/30 05:10:03 PM System -10108 Check log
Mon 2013/09/30 05:10:03 PM System -170001 [Auth] 10.0.2.18:55286->80, Num=18
Mon 2013/09/30 05:10:03 PM System -170001 [HTTP] Closing socket normally
Hi Patrick,
Here's the issue ... it seems that your device is requesting for things that cannot possibly be in ISY:
ISY file names are 8.3 and thus what is being requested is definitely something that your device is adding on its own. It's quite interesting and, at the same time, I am not sure how we can fix it.
  • 3 weeks later...
I have an isy99i running 3.3.10 and I have the exact same problem.
While I understand that this may be caused by a change that Apple implemented in iOS7, that does not mean that a workaround on UD's part is impossible. Also, since this affects all users of your product that run iOS devices (which I suspect is a large group of users), I suggest it would be a good idea to see if you can find a solution. We would all greatly appreciate it.
thanks,
-John
Hi John,
I am not sure what you are suggesting. ISY, just like any web server, is responding as it should for a request to a resource that DOES NOT EXIST. Are you suggesting that we should go find all the apple-specific URLs out there in the world, trap them in ISY, and randomly return images that we like?
I must say that from our inception Apple has been nothing but a nightmare for us. From MAC to iPhone/iPad, Airport, Airport Extreme, etc. A good portion of our tech support calls is to address Apple issues. This has led us to believe that Apple does have territorial mentality and pretty much forces everyone to use their native features: a) see above as an example and B) for the longest time, Apple had its own Java implementation which were never up-to-date with the latest versions. Mind you, ISY's html interface is HTML and Javascript (AJAX) which 99% of other browsers and mobile devices support. But, of course, Apple has to inject its own images and we have to change the firmware to "ignore" apple!
Quite frustrating to say the least.
I figured just for fun I'd check to see if it works for me. I'm on iOS 6 still. It DOES work perfectly fine for me. Here's the interesting bit:
Wed 2013/10/23 01:24:26 AM	System	-170001	[Auth] 192.168.1.129:51478->80, Num=3
Wed 2013/10/23 01:24:26 AM	System	-170001	[Auth] 192.168.1.129:51478->80, Num=4
Wed 2013/10/23 01:24:26 AM	System	-170001	[Auth] 192.168.1.129:51478->80, Num=5
Wed 2013/10/23 01:24:26 AM	System	-170001	[Auth] 192.168.1.129:51478->80, Num=6
Wed 2013/10/23 01:24:26 AM	System	-10108	Check log
Wed 2013/10/23 01:24:26 AM	System	-170001	[Auth] 192.168.1.129:51478->80, Num=7
Wed 2013/10/23 01:24:26 AM	System	-170001	[Auth] 192.168.1.129:51478->80, Num=8
Wed 2013/10/23 01:24:26 AM	System	-170001	[Auth] 192.168.1.129:51478->80, Num=9
Wed 2013/10/23 01:27:42 AM	System	-170001	[HTTP] 192.168.1.23:57854->80
Wed 2013/10/23 01:27:42 AM	System	-170001	[HTTP]: GET-->/desc
Wed 2013/10/23 01:27:42 AM	System	-170001	[HTTP] 192.168.1.23:57855->80
Wed 2013/10/23 01:27:42 AM	System	-170001	[HTTP]: GET-->/services.wsdl
Wed 2013/10/23 01:27:42 AM	System	-170001	[HTTP] 192.168.1.23:57856->80
Wed 2013/10/23 01:27:42 AM	System	-170001	[HTTP]: GET-->/elkServices.wsdl
Wed 2013/10/23 01:27:42 AM	System	-170001	[HTTP] Socket not active#2
Wed 2013/10/23 01:27:42 AM	System	-170001	[HTTP] Closing socket  w/failure
Wed 2013/10/23 01:27:42 AM	System	-170001	[HTTP] 192.168.1.23:57857->80
Wed 2013/10/23 01:27:42 AM	System	-170001	[HTTP]: GET-->/sepServices.wsdl
Wed 2013/10/23 01:27:42 AM	System	-170001	[HTTP] 192.168.1.23:57858->80
Wed 2013/10/23 01:27:42 AM	System	-170001	[HTTP]: GET-->/zwaveServices.wsdl
Wed 2013/10/23 01:27:55 AM	System	-170001	[HTTP] 192.168.1.129:51483->80
Wed 2013/10/23 01:27:55 AM	System	-170001	[HTTP]: GET-->/WEB/INDEX.HTM
Wed 2013/10/23 01:27:55 AM	System	-170001	[HTTP]: GET-->/WEB/itouch.css
Wed 2013/10/23 01:27:55 AM	System	-170001	[HTTP] 192.168.1.129:51484->80
Wed 2013/10/23 01:27:55 AM	System	-170001	[HTTP]: GET-->/WEB/udi.css
Wed 2013/10/23 01:27:55 AM	System	-170001	[HTTP]: GET-->/WEB/jtemp.js
Wed 2013/10/23 01:27:55 AM	System	-170001	[HTTP]: GET-->/WEB/jquery.js
Wed 2013/10/23 01:27:55 AM	System	-170001	[HTTP] 192.168.1.129:51485->80
Wed 2013/10/23 01:27:55 AM	System	-170001	[HTTP]: GET-->/WEB/common.js
Wed 2013/10/23 01:27:55 AM	System	-170001	[HTTP]: GET-->/WEB/cookie.js
Wed 2013/10/23 01:27:56 AM	System	-170001	[HTTP]: GET-->/WEB/camTypes.js
Wed 2013/10/23 01:27:56 AM	System	-170001	[HTTP] Closing socket normally
Wed 2013/10/23 01:27:56 AM	System	-170001	[HTTP] 192.168.1.129:51486->80
Wed 2013/10/23 01:27:56 AM	System	-170001	[HTTP]: GET-->/WEB/jjson.js
Wed 2013/10/23 01:27:56 AM	System	-170001	[HTTP]: GET-->/WEB/flot.js
Wed 2013/10/23 01:27:56 AM	System	-170001	[HTTP]: GET-->/WEB/isyajax.js
Wed 2013/10/23 01:27:56 AM	System	-170001	[HTTP] 192.168.1.129:51487->80
Wed 2013/10/23 01:27:56 AM	System	-170001	[HTTP]: GET-->/WEB/jstorage.js
Wed 2013/10/23 01:27:57 AM	System	-170001	[HTTP] Closing socket normally
Wed 2013/10/23 01:27:57 AM	System	-170001	[HTTP] 192.168.1.129:51488->80
Wed 2013/10/23 01:27:57 AM	System	-170001	[HTTP]: GET-->/WEB/hashch.js
Wed 2013/10/23 01:27:57 AM	System	-170001	[HTTP]: GET-->/WEB/udlogo.png
Wed 2013/10/23 01:27:57 AM	System	-170001	[HTTP]: GET-->/rest/config/
Wed 2013/10/23 01:27:57 AM	System	-170001	[HTTP]: GET-->/WEB/bg_menu.gif
Wed 2013/10/23 01:27:57 AM	System	-170001	[HTTP] 192.168.1.129:51489->80
Wed 2013/10/23 01:27:57 AM	System	-170001	[HTTP]: GET-->/apple-touch-icon-114x114-pr
Wed 2013/10/23 01:27:58 AM	System	-170001	[HTTP]: GET-->/apple-touch-icon-114x114-pr
Wed 2013/10/23 01:27:58 AM	System	-170001	[Auth] 192.168.1.129:51489->80, Num=3
Wed 2013/10/23 01:27:58 AM	System	-170001	[HTTP]: GET-->/apple-touch-icon-114x114.pn
Wed 2013/10/23 01:27:58 AM	System	-170001	[Auth] 192.168.1.129:51489->80, Num=4
Wed 2013/10/23 01:27:58 AM	System	-170001	[Auth] 192.168.1.129:51489->80, Num=5
Wed 2013/10/23 01:27:58 AM	System	-170001	[HTTP]: GET-->/apple-touch-icon-precompose
Wed 2013/10/23 01:27:58 AM	System	-170001	[Auth] 192.168.1.129:51489->80, Num=6
Wed 2013/10/23 01:27:58 AM	System	-10108	Check log
Wed 2013/10/23 01:27:58 AM	System	-170001	[Auth] 192.168.1.129:51489->80, Num=7
Wed 2013/10/23 01:27:58 AM	System	-170001	[HTTP]: GET-->/apple-touch-icon.png
Wed 2013/10/23 01:27:58 AM	System	-170001	[Auth] 192.168.1.129:51489->80, Num=8
Wed 2013/10/23 01:27:58 AM	System	-170001	[Auth] 192.168.1.129:51489->80, Num=9
Wed 2013/10/23 01:27:58 AM	System	-170001	[HTTP] Closing socket normally
Seems that even on iOS 6 it's asking for random stuff also, and the ISY handles it just fine. Not sure what the problem is.
Partick, when you click on the icon on the homescreen, does it ask for your username/password? It does for me, everytime, seems to be a bit of a bother. I don't normally use this method, I use a dedicated App for communication with my ISY.
Just figured adding more information never hurts.
Knight.
Hi Michel and Knight:
I've since upgraded to iOS 7.0.3 on my iPhone and iPad.
Now, when I click on a Home Screen shortcut (of http://10.0.2.202/WEB/INDEX.HTM) on my iPhone, I'm prompted for my ISY Login and Password.
After entering the Login and Password, it works as expected. (no longer hangs on Load Config)
I was hoping to be able to provide a copy of my Error Log for you, but after upgrading my MacBook Air to Mac OS 10.9, I'm not able to save error logs anymore (or any ISY logs, for that matter).
Patrick
Patrick
Glad to hear it's working!
I'm curious, when you were on 7.0.2, did it prompt for username/password?
Knight.
fox7-
I am on OS 10.9 on my 13" MBAir and have no problem (or no more problems than in 10.8 ) saving ISY logs. What problems are you seeing?
What version of Java are you running? I'm at: (build 1.7.0_45-b18)
What level is your Java security set to? I'm at: High (minimum recommended)
Hi Knight:
Using iOS 7.0 or 7.0.2 and clicking on a Home Screen shortcut, both resulted in the Load Config message (was never prompted for username/password). iOS 7.0.3 will prompt for username/password without the Load Config message.
Hi Xathros:
Using Mac OS 10.9, I did the following:
- accessed my ISY Admin page with User ID and password
- from the Tools menu, select Error Log
-> am presented with a Save Log To... dialog
-> the default filename is 'ISY Error Log.v4.05__Wed 2013.10.23 10.19.41 AM.txt'
-> the default path presented is inside 'PluginProcess.app'
- I change the path to my Desktop
- click on the Save button
The 'ISY Error Log...txt' file is not saved to my Desktop (or anywhere else, that I can see).
I'm running Java 7 Update 45 (build 1.7.0_45)
My Java Security is set to Medium.
Patrick
Hi Xathros:
Patrick
OK, I am working with another user with an identical problem. Join the discussion for this on: viewtopic.php?f=25&t=12505&p=96131#p96131
Hi Xathros:
As was suggested in the other topic, I can confirm that using FireFox v24.0 (instead of Safari v7.0) does allow one to save log files without any problems, under Mac OS 10.9.
Patrick
Hi Xathros:
Patrick
Are you able to do more than one save per console session?
Hi Xathros:
Yes, using FireFox v24.0 under Mac OS 10.9, I'm able to save more than once, without any problems.
For example, filenames from 3 saves just now:
ISY Error Log.v4.0.5__Fri 2013.10.25 11.23.46 PM.txt
ISY Error Log.v4.0.5__Fri 2013.10.25 11.23.59 PM.txt
ISY Error Log.v4.0.5__Fri 2013.10.25 11.24.17 PM.txt
Patrick
