Programs/sensors No Longer Working
f.demello
Not sure what has happened but in the last 3 months I have been getting no texts on triggers from various open/close & leak sensors.  I changed some of the batteries and upgraded to 4.5.1 but still the same (see screenshot).  Nothing has changed in my programs.  I have no idea where to even start.  Any help will be greatly appreciated
Have you run test notifications to see if the messages are still being sent out, identifying whether the problem is in the programming or the email system?
I am getting texts. I did notice my text group was set to regular e-mail all of a sudden (didn't set it up that way).  But just did a test of one of the open/close sensors and it did not send anything.  if you look at the screenshot I am not getting any of the daily runs I used to.  What would cause all of them to stop?  Thank you
Post one of your programs that is responsible and people can take a look at the logic.
Right click on the program in the program tree and select "copy to clipboard"
Try removing power from the ISY for about 10 seconds then plug it back in.   Are you also using the 4.5.1 UI?
Will do. Updated the UI on 7/9.  ISY Firmware 4.5.1. Not sure how to double check the UI version
This is a simple open close program (2 parts) that worked for years:
Shed Timer - [iD 0014][Parent 0001]
        Send Notification to 'Frank' content 'Door Activation'
        Send Notification to 'Abby' content 'Door Activation'
        Wait  5 minutes
Shed Trigger - [iD 0015][Parent 0001]
        Status  'Open-Close / Shed-Opened' is On
        Run Program 'Shed Timer' (If)
Thank you
In the admin console, click on HELP | ABOUT.  That will show you the version of the ISY firmware as well as the UI.
If the UI in not 4.5.1 then, clear your Java cache, including applications and then download the 4.5.1 version of the Admin console from here
 http://forum.universal-devices.com/topic/19162-release-451-is-now-official/
both the firmware and UI should be the same release.  Let me know if that solved your issues.
        Wait  5 minutes
Thank you
Does your "Status 'Open-Close / Shed-Opened" show 'On' in it's device status page?
Got it.  Both 4.5.1
Enabled = ON
Ran the If/Then statements and I received the text.  I had just changed the batteries in the sensor.  Do these sensors die?  Not that old (1-2 years). I also suspect all my leak sensors are not working as well (have 7).  Will have to test
The sensor sends out a heartbeat signal every 24 hours, you should have a program to monitor the sensor heartbeat. That way you'll know if the battery is low and/or if the sensor signal is being received.
As with any RF only device you need to have a dual band device within close proximity to receive the RF signals. An external dual band device such as a on/off module, lamplinc etc will provide better RF coverage than a device mounted inside a wall
Edited by Techman
I just added an automatic reset and try again to my leak detectors low battery programs.
I missed a heartbeat from one Leak detector and after checking the battery to be very fresh yet, changed my programs to still notify me, but start again, with a 23 hour Wait period and then start timing again.
If I had a battery failure I would then get a nuisance notification every two days. Not too bad for a nuisance repeat cycle.
If you are away there is not much you can do with a low battery anyway.
I worked perfectly for 2 years where it is currently.  My leak sensor programs do have the heartbeat program but I don't in my 2 open/close sensors (although I just changed both batteries)
  • 4 weeks later...
  • 4 months later...
With a link count of 0 after a restore, I would suspect its the PLM.
  • How old is the PLM, more than 2.5 years?
  • Is the PLM's LED on?
Paul
PLM blue light on. Rx flashing blue  Note: I recently unplugged the PLM/ISY and plugged back in from something I saw on the internet. Still getting a 0 count.
        Wait  5 minutes
Thank you
Is no one going to comment on his two programs?  Is it me or do they not seem to make sense?
Your "Shed Trigger" program runs the "If" of your "Shed Timer" program but there is nothing in the "If" portion of your "Shed Timer" program so I would presume nothing would happen (or it would always run false/else?).  Also, in your "Shed Timer" program why do you have a 5 minute wait at the end of the "Then" portion?
      377k
