Another Insteon MSII Query
I'm aware that there is little or no data from Smarthome regarding this sensor.  (I think they're missing a bet.  If the data were available to us, we'd likely purchase more of the sensors.)  I'm  looking for anyone who has experimented with (and hopefully recorded the results of) Motion Sensitivity and/or Battery Low threshold.   I need to tweak these settings and am looking for a starting point.
Thanks.
JLOB
Don't want to hijack your thread but on a similar note, the MS IIs are on sale at aartech.ca for a few more days, and I am wondering if there is any particular firmware versions I should be avoiding?
Hijack away.  I wish I had an answer for you.  Based on your comment, I'm gonna pick up a couple of more on the belief that we'll get some data soon.  It IS a good product.
J.
so, what do you use if MSII are not good, as original MS are no longer sold, are they?
19 hours ago, Michel Kohanim said:
@larryllix,
Yes, you should avoid all versions!
Michel,
    Would you kindly support that statement with just a little more detail?
Jlob,
Here is some limited information:
https://forum.universal-devices.com/uploads/monthly_2019_06/Report5.JPG.0bffdcba5aa49eb54b6ea2b377b21c66.JPG
Sorry it has  been  a while since I tried to link to a older post.  This is just a portion of it.
Edited by ELA
Michel,
So, just as you responded to the user regarding why you thought the MS II was than stellar, I received a low-battery notice for one of mine.   I also had one last Friday and was pleased.  The unit had been in service for about six months and I was wondering how long it would take to see the report.  Since I dutifully changed the battery on Saturday, I was NOT pleased to see the second notice.  Now either I’m missing something relative to resetting a battery indicator, or I’m beginning to see why you’re not enamored with this Insteon item. Any thoughts?
Thanks.
JLOB
Edited by JLOB
23 minutes ago, Michel Kohanim said:
Hi @JLOB,
Please try right mouse click on the low bat node | Query.
Michel,
I actually did that yesterday on a whim.  This morning, when there was no new alert, I wondered if it were an anomaly or an actual fix. Thanks for the confirmation.  THAT'S the type of data I'd like to see consolidated somewhere vis-a-vis the MS II.
J.
20 hours ago, Michel Kohanim said:
Hi @JLOB,
I thought I had done that the other day and was happy that the alert stopped.  Premature, as it were.  I got the alert again this morning.  Looking at your note again, I'm not sure I know where/what the "low bat node | Query" is.  Can you be more specific towards a soon-to-be octogenarian?
Thank you.
JLOB
Michel,
Actually, I thought I had responded to this the other day.  Apparently, I didn’t “send”.  I didn’t see anything that resembled “Low Bat node”, but then again I’m not sure where the “the navigation bar/device tree” is!  Can you offer any help?
Thanks.
JLOB
37 minutes ago, JLOB said:
Michel,
Thanks.
JLOB
See the list of devices on the left? That is your device tree, found under the "Main" tab in admin console.
I get that.  What I don't have is the "Low bat node" item.  My ISY is 994I.  I thought that should handle the Insteon devices.
Thanks.
JLOB
https://drive.google.com/open?id=14lk_1sloGMhjgMNAFrZNJ8ysEyuO7pRr
If you scroll down in the MS II options, there is a setting to create a battery node. (none or one)
Don't know if this node will work like the MS I sensors in resetting battery status as mine are USB powered.
My options are "One" or "Two".  Verbiage says it will set up a second node.  Not at all sure what this is or if I need/want one?
J.
J.
The second node is an Off node.  Very much like how there's a wet and a dry node on leak sensors, it's just inverted.
J.
Why don’t you right click the main sensor node and select group device. Maybe you have a low battery node but it didn’t get moved to the correct folder. Grouping the device should make it visible with the other nodes (if you do have one).
4 hours ago, Michel Kohanim said:
@JLOB,
As per @Chris, you just have to query the sensor node (if the battery node is not there).
I've done that several times.  I keep getting the the battery alert e-mail each day.  Getting frustrated.  Thanks though.
J.
J.
Why don't you post your program doing that here, and maybe somebody can find a hole in it?
Right click and the program in the tree and select "copy to clipboard". Paste in a post.
There's not much of a program.  It just queries the sensor.  The underlying problem is that the sensor doesn't reset with the new battery.
Kitchen Motion Low Battery - [ID 008D][Parent 0001]
        Time is  4:00:00AM
    And 'Kitchen / Kitchen Miscellaneous Sensor' Battery Level <= 10%
        Send Notification to 'XXX XXX' content 'Sensor Battery-1'
J.
