"Not Implemented" error message
I have largely been doing other things and the status of my ISY and home automation has been working fine. After months of not logging into my admin console, I had a reason to do so. First off I needed to upgrade my Java, which I did. Now when I log in I get a "Not Implemented" error message. I can open the initial devices list and clicking on a device successfully opens it. When I click on "Programs" I again get a "Not Implemented" message, and things bog down and eventually lock up.
Maybe to start, what does a "Not Implemented" error signify, and what is my likely cause? Next, what do I need to do? My backup is pretty current, other than a couple devices I was able to successfully add today, before the "Programs" snafu.
I find myself questioning Java in all this.
Chris
Edited by glacier991
Typo by spellcheck.
My UI version, as your reply likely suspected, does not match my firmware version (  4 something version for the UI and  5.0.13 version for the firmware. Now, and this is likely a noon like question..how to I fix my UI version to make them match?
Here you go:
