I upgraded to the Zwave Dongle 500. When I try to include an Eaton RF9601 switch I always receive the error "The Z-wave network failed to securely include your new device." I excluded it, I gave hard reset to the switch, repair link, heal network and I still haven't been able to add it. I would appreciate some help
JReyes
To install it, the device should be about 2 feet from the ISY. After installation you can move it back to its original location. Like suggested above, you may need to build out the mesh.
  • 1 year later...
Hello all;
I get the same error, with AeoTec MultiSensor 6 devices on V1.14, ISY on 5.3.0 and the device less than 10" away.
It doesn't matter, if I reset the sensor. I always have to Exclude before Add.
It gives the error, but adds the device. I don't want to install them in their location, 20' in the air...
Any ideas? cheers
I get the same error 3 trying to add a secondary controller to my ISY ZWave network. I have the units on top of each other, so its not the distance.  I am running 5.3.3. Any ideas greatly appreciated
On 6/24/2021 at 5:30 PM, TriLife said:
Hello all;
Any ideas? cheers
I think the issue is with ISY 5.3.0 not supporting Security 2 yet, as indicated in the pop up window for Z-wave (see attached.
In any case, as mentioned by many others and just confirmed in my installation, connecting the AeoTec MS in non-secure mode significantly speeds up the response time and seems to strengthen the meshing.
Unless you have a very strong case for encryption, I'd skip it.
Cheers.
      379.8k
