ISY on Polisy v5.0.4_13 Is Now Available
Hello everyone,
This is a minor release that fixes the following issues:
- More  case sensitivity issues:
-- Backup/Restore
-- SMTP
-- Variables
- PGC Node Servers were not being installed properly
Instructions:
sudo pkg upgrade udx
sudo pkg upgrade isy
sudo service udx restart
sudo service isy restart
I had to restart installed PG3 nodeservers but no other issues with the upgrade.
SMTP works :-)
Might have spoke to soon
Test mail from a group works perfect
When I try to send a custom message - no joy
test send smtp - [ID 0003][Parent 0001]
        Send Notification to 'Default' content 'test1.1'
Nothing appears to send to any of the 3 destinations
I tried creating a second message this morning and that message works, so I have something wonky in my message. Sorry for the call out
Edited by bgrubb1
@Michel Kohanim,
I just recently attempted to log into the ISY on Polisy via the Admin Console and received the following error message:
XML Parse Error http://xx.xx.xx.xx:8080/desc
The Admin Console shell loaded with some menu items missing (only File menu was there), but I never got the login window.  Same error whether I used Cloud or Local.
I stopped and restarted the ISY service and this corrected the problem.  I had logged in this morning without issue and I'm not aware of anything changing between then and now.  This is the first time I've seen this error.
Mark
1 hour ago, Michel Kohanim said:
@mbking,
Can you please send me your ISY's error log?
Sent
Hi all, I'm trying to setup smtp on my Polisy and when I click Recipients i get an error per attached. I did clear my java cache but it didn't help.
I seem to remember I had the same problem on my prod ISY but I'm not sure what I did to get it to work.
Any idea what I'm doing wrong?
Thanks in advance!
mike
Update fixed.
Used this workaround which I used on the ISY.
1. Click on "Recipients" bar
2. Dismiss "Invalid Email Address" error
3. Delete button at bottom is now active; press this.
4. Add button is now active.
Edited by mmb
Update
Unfortunately I keep getting this error. All the latest updates and procedures have been done.
Thanks for any suggestions.
I got that error after the update.  It went away after a full upgrade, update and a reboot.
However, I continue to get an smtp error message even though my test messages are sending properly.
Update
I continue to get the UXT error after a reboot but it goes away until the next reboot.
I also continue to get an SMTP error despite the email being sent properly.
Edited by mmb
Update
Just realized that emails work with out any problem and no error message. It was a text message that I was sending along with the email that was causing the problem.
Thanks Gary
UPDATE: Just an observation. If a text Recipient is included in the groups name list I will get the errors and the email won't be sent.
Edited by garybixler
I am using
XXXXXXXXXX@mms.att.net
and receiving texts fine Did you use a comma between ?
...Barry
Edited by bgrubb1
It does place a comma between automatically. Also tried a text separately. But I think I lost my Group name file in the process. Nothing can be saved. Not important at this point. Will probably need to open a ticket.
Thanks Gary
I've noticed that the INIT=1 value I set for one of my State Variables reverts to 0 when the ISY service is rebooted.  I assume those values should be persistent.
Mark
I came to the party a little late.  I followed the various post and I am running ISY on Polisy.  There must have been some updates as it reports ISY version 5.0.4_28.  Going to do some testing soon.  Thanks for your hard work UDI !
Good to hear constant micro updates.
I haven't made the jump yet as it means rebuilding a PLM so I can trust it and I have had so many compound LAN and modem problems that I was avoiding adding any complexity to my system before trusting other components.
@Michel Kohanim, Is there documentation on how to transition from an ISY-994i Pro/PLM 2413S to ISY on Polisy with a PLM USB?
I've successfully gotten ISY on Polisy to show up on the ISY Finder and can login into the 5.0.4 Admin Console.
Not sure if I can simply restore from my ISY-994i 5.3.3 back up to  Polisy 5.0.4 or something else is involved
Mark
In case you'd like a faster answer than you'll get from Michel on Saturday...
ISY on Polisy isn't ready for production use yet.  Its available in ALPHA form for testing and bug reporting. There isn't a Z-wave interface yet.  There are still many bugs being reported.   I don't know for sure, but I don't think restore from backup works yet.
The documentation you asked about in your first sentence doesn't exist yet, and so far I don't think it's even been tested on large scale as yet.
Edited by MrBill
22 minutes ago, markthomas said:
@MrBillok, thank you for the update.
It appears the restore does work now, as reported in this same thread.
