ISY on Polisy v5.0.4_13 Is Now Available
15 minutes ago, larryllix said:
It appears the restore does work now, as reported in this same thread.
I read that thread differently than you do...  I don't see where it says Restore from ISY-994 installations works correctly...
I see where it says a sub-item of "Case Sensitivity issues:" was "Backup/Restore" items.  That's different than the traffic light turning Green.
Quote
- More  case sensitivity issues:
-- Backup/Restore
-- SMTP
-- Variables
- PGC Node Servers were not being installed properly
I had read that the same way @MrBill but since it IS an alpha (after making a backup) I tried to restore a backup from my ISY994i to Polisy ISY and surprisingly, it took it! The result? My programs all appeared but none of my devices. Not surprising since I had unplugged my test PLM and, of course, it does not yet support Zwave. I would not recommend it at this point without further instructions from @Michel Kohanim. Happy ending, I restored ISY on Polisy back to my test configuration without incident.
Edited by DaveStLou
I hope we will be able to restore a backup, then restore modem, so that we can convert to a USB modem.
Hello everyone,
The restore only works from Polisy to Polisy. The reason 994 to Polisy does not work is the difficulty in converting binary files (INSTEON and Z-Wave records) from big endian to little.
  • Like 3
Speaking of transitioning, is there a good way to send variables from an ISY994 to the ISY on a Polisy or vis versa, so they're in sync?  Since virtually my entire house state is variable driven, being able to bring them over would let me slowly transition programs and devices in a good way over time, rather than having to just spend a weekend and bring everything over.
  • 4 weeks later...
Struggling to get any Insteon devices to work. When 'Link Management' 'New Insteon Device' I enter the device identifier (triple checked) - and get this error:
I have a USB PLM hooked up to POLISY - running:
'Tools' 'Diagnostics' 'PLM Info' shows:
Seems to be the cause..  POLISY is not seeing the PLM
Insteon support is enabled:
I have tried the PLM in both USB ports.
A 'sudo usbconfig list' appears to list the PLM:
Is there anything else I can try? POLISY has been rebooted a couple of time - and also a full power off and back on. Same results.
@MWareman,
What's the output of uname -a? I suspect you are missing the driver for FTDI because your OS version is still 12. If that's the case:
sudo pkg update && sudo pkg upgrade
cat /usr/local/etc/udx.d/static/update13.sh | sudo bash
sudo shutdown -r now
Nope - I'm at 13:
[admin@polisy ~]$ uname -a
FreeBSD polisy 13.0-RELEASE-p4 FreeBSD 13.0-RELEASE-p4 #13 releng/13.0-n244760-940681634ee: Wed Aug 25 16:44:58 UTC 2021     ec2-user@bsdev.isy.io:/usr/obj/usr/src/amd64.amd64/sys/POLISY  amd64
[admin@polisy ~]$
Package cache is up to date:
[admin@polisy ~]$ sudo pkg update && sudo pkg upgrade
Updating FreeBSD-base repository catalogue...
pkg: https://pkg.isy.io/FreeBSD-base/FreeBSD:13:amd64/latest/packagesite.pkg: Not Found
FreeBSD-base repository is up to date.
Updating udi repository catalogue...
Fetching meta.conf: 100%    163 B   0.2kB/s    00:01
Fetching packagesite.pkg: 100%  108 KiB 110.4kB/s    00:01
Processing entries: 100%
udi repository update completed. 399 packages processed.
All repositories are up to date.
udi repository is up to date.
Checking for upgrades (0 candidates): 100%
Processing candidates (0 candidates): 100%
Checking integrity... done (0 conflicting)
Your packages are up to date.
[admin@polisy ~]$
I had previously run the 13 upgrade - but running it again:
[admin@polisy ~]$ cat /usr/local/etc/udx.d/static/update13.sh | sudo bash
The following package files will be deleted:
        /var/cache/pkg/FreeBSD-kernel-polisy-13.0p4~fc5930b9ca.txz
        /var/cache/pkg/FreeBSD-kernel-polisy-13.0p4.txz
The cleanup will free 16 MiB
Deleting files: 100%
All done
Updating ports repo to 13
The most recent versions of packages are already installed
No packages matched for pattern 'FreeBSD-*-12*'
1 packages requested for removal: 0 locked, 1 missing
Nothing to do.
Update APULED and RESETSW
/boot/kernel /usr/home/admin
x apuled.ko
x resetsw.ko
/usr/home/admin
python38 already installed
python3 already installed
py38-cryptography already installed
py38-netifaces already installed
py38-pip already installed
py38-pycryptodome already installed
py38-yaml already installed
py38-dateparser already installed
py38-holidays already installed
py38-certbot already installed
py38-aiohttp already installed
py38-zeep already installed
py38-sqlite3 already installed
upgrading nodeserver requirements
updating Backup
Requirement already satisfied: polyinterface>=2.0.28 in /var/polyglot/.local/lib/python3.8/site-packages (from -r requirements.txt (line 1)) (2.1.0)
Requirement already satisfied: xmltodict>=0.12.0 in /var/polyglot/.local/lib/python3.8/site-packages (from -r requirements.txt (line 2)) (0.12.0)
Requirement already satisfied: paho-mqtt in /var/polyglot/.local/lib/python3.8/site-packages (from polyinterface>=2.0.28->-r requirements.txt (line 1)) (1.5.1)
Requirement already satisfied: markdown2 in /var/polyglot/.local/lib/python3.8/site-packages (from polyinterface>=2.0.28->-r requirements.txt (line 1)) (2.4.0)
Requirement already satisfied: netifaces in /usr/local/lib/python3.8/site-packages (from polyinterface>=2.0.28->-r requirements.txt (line 1)) (0.11.0)
Requirement already satisfied: python-dotenv in /var/polyglot/.local/lib/python3.8/site-packages (from polyinterface>=2.0.28->-r requirements.txt (line 1)) (0.18.0)
updating DarkSky
Requirement already satisfied: requests>=2.0 in /usr/local/lib/python3.8/site-packages (from -r requirements.txt (line 2)) (2.25.1)
Requirement already satisfied: chardet<5,>=3.0.2 in /usr/local/lib/python3.8/site-packages (from requests>=2.0->-r requirements.txt (line 2)) (4.0.0)
Requirement already satisfied: idna<3,>=2.5 in /usr/local/lib/python3.8/site-packages (from requests>=2.0->-r requirements.txt (line 2)) (2.10)
Requirement already satisfied: urllib3<1.27,>=1.21.1 in /usr/local/lib/python3.8/site-packages (from requests>=2.0->-r requirements.txt (line 2)) (1.26.7)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.8/site-packages (from requests>=2.0->-r requirements.txt (line 2)) (2021.5.30)
updating ELK
Requirement already satisfied: polyinterface>=2.0.34 in /var/polyglot/.local/lib/python3.8/site-packages (from -r requirements.txt (line 1)) (2.1.0)
Requirement already satisfied: elkm1_lib==0.8.8 in /var/polyglot/.local/lib/python3.8/site-packages (from -r requirements.txt (line 2)) (0.8.8)
Requirement already satisfied: pyserial-asyncio<0.5.0,>=0.4.0 in /var/polyglot/.local/lib/python3.8/site-packages (from elkm1_lib==0.8.8->-r requirements.txt (line 2)) (0.4)
Requirement already satisfied: netifaces in /usr/local/lib/python3.8/site-packages (from polyinterface>=2.0.34->-r requirements.txt (line 1)) (0.11.0)
Requirement already satisfied: paho-mqtt in /var/polyglot/.local/lib/python3.8/site-packages (from polyinterface>=2.0.34->-r requirements.txt (line 1)) (1.5.1)
Requirement already satisfied: python-dotenv in /var/polyglot/.local/lib/python3.8/site-packages (from polyinterface>=2.0.34->-r requirements.txt (line 1)) (0.18.0)
Requirement already satisfied: markdown2 in /var/polyglot/.local/lib/python3.8/site-packages (from polyinterface>=2.0.34->-r requirements.txt (line 1)) (2.4.0)
Requirement already satisfied: pyserial in /var/polyglot/.local/lib/python3.8/site-packages (from pyserial-asyncio<0.5.0,>=0.4.0->elkm1_lib==0.8.8->-r requirements.txt (line 2)) (3.5)
updating ISY-Inventory
Requirement already satisfied: requests in /usr/local/lib/python3.8/site-packages (from -r requirements.txt (line 2)) (2.25.1)
Requirement already satisfied: chardet<5,>=3.0.2 in /usr/local/lib/python3.8/site-packages (from requests->-r requirements.txt (line 2)) (4.0.0)
Requirement already satisfied: idna<3,>=2.5 in /usr/local/lib/python3.8/site-packages (from requests->-r requirements.txt (line 2)) (2.10)
Requirement already satisfied: urllib3<1.27,>=1.21.1 in /usr/local/lib/python3.8/site-packages (from requests->-r requirements.txt (line 2)) (1.26.7)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.8/site-packages (from requests->-r requirements.txt (line 2)) (2021.5.30)
updating Kasa
Requirement already satisfied: polyinterface>=2.1.0 in /var/polyglot/.local/lib/python3.8/site-packages (from -r requirements.txt (line 1)) (2.1.0)
Requirement already satisfied: deprecation in /var/polyglot/.local/lib/python3.8/site-packages (from -r requirements.txt (line 2)) (2.1.0)
Requirement already satisfied: python-kasa in /var/polyglot/.local/lib/python3.8/site-packages (from -r requirements.txt (line 3)) (0.4.0.dev3)
Requirement already satisfied: netifaces in /usr/local/lib/python3.8/site-packages (from polyinterface>=2.1.0->-r requirements.txt (line 1)) (0.11.0)
Requirement already satisfied: paho-mqtt in /var/polyglot/.local/lib/python3.8/site-packages (from polyinterface>=2.1.0->-r requirements.txt (line 1)) (1.5.1)
Requirement already satisfied: python-dotenv in /var/polyglot/.local/lib/python3.8/site-packages (from polyinterface>=2.1.0->-r requirements.txt (line 1)) (0.18.0)
Requirement already satisfied: markdown2 in /var/polyglot/.local/lib/python3.8/site-packages (from polyinterface>=2.1.0->-r requirements.txt (line 1)) (2.4.0)
Requirement already satisfied: packaging in /var/polyglot/.local/lib/python3.8/site-packages (from deprecation->-r requirements.txt (line 2)) (20.9)
Requirement already satisfied: importlib-metadata in /var/polyglot/.local/lib/python3.8/site-packages (from python-kasa->-r requirements.txt (line 3)) (4.6.0)
Requirement already satisfied: asyncclick<8,>=7 in /var/polyglot/.local/lib/python3.8/site-packages (from python-kasa->-r requirements.txt (line 3)) (7.1.2.3)
Requirement already satisfied: anyio>=2 in /var/polyglot/.local/lib/python3.8/site-packages (from asyncclick<8,>=7->python-kasa->-r requirements.txt (line 3)) (3.2.1)
Requirement already satisfied: sniffio>=1.1 in /var/polyglot/.local/lib/python3.8/site-packages (from anyio>=2->asyncclick<8,>=7->python-kasa->-r requirements.txt (line 3)) (1.2.0)
Requirement already satisfied: idna>=2.8 in /usr/local/lib/python3.8/site-packages (from anyio>=2->asyncclick<8,>=7->python-kasa->-r requirements.txt (line 3)) (2.10)
Requirement already satisfied: zipp>=0.5 in /var/polyglot/.local/lib/python3.8/site-packages (from importlib-metadata->python-kasa->-r requirements.txt (line 3)) (3.4.1)
Requirement already satisfied: pyparsing>=2.0.2 in /var/polyglot/.local/lib/python3.8/site-packages (from packaging->deprecation->-r requirements.txt (line 2)) (2.4.7)
updating LiFX
Requirement already satisfied: lifxlan>=1.2.5 in /var/polyglot/.local/lib/python3.8/site-packages (from -r requirements.txt (line 1)) (1.2.7)
Requirement already satisfied: pyyaml>=3.12 in /usr/local/lib/python3.8/site-packages (from -r requirements.txt (line 2)) (5.4.1)
Requirement already satisfied: polyinterface>=2.0.34 in /var/polyglot/.local/lib/python3.8/site-packages (from -r requirements.txt (line 3)) (2.1.0)
Requirement already satisfied: bitstring in /var/polyglot/.local/lib/python3.8/site-packages (from lifxlan>=1.2.5->-r requirements.txt (line 1)) (3.1.7)
Requirement already satisfied: ifaddr in /var/polyglot/.local/lib/python3.8/site-packages (from lifxlan>=1.2.5->-r requirements.txt (line 1)) (0.1.7)
Requirement already satisfied: python-dotenv in /var/polyglot/.local/lib/python3.8/site-packages (from polyinterface>=2.0.34->-r requirements.txt (line 3)) (0.18.0)
Requirement already satisfied: paho-mqtt in /var/polyglot/.local/lib/python3.8/site-packages (from polyinterface>=2.0.34->-r requirements.txt (line 3)) (1.5.1)
Requirement already satisfied: netifaces in /usr/local/lib/python3.8/site-packages (from polyinterface>=2.0.34->-r requirements.txt (line 3)) (0.11.0)
Requirement already satisfied: markdown2 in /var/polyglot/.local/lib/python3.8/site-packages (from polyinterface>=2.0.34->-r requirements.txt (line 3)) (2.4.0)
updating MQTT
Requirement already satisfied: pyyaml>=5.3.1 in /usr/local/lib/python3.8/site-packages (from -r requirements.txt (line 2)) (5.4.1)
updating MagicHome
Collecting git+git://github.com/fahrer16/flux_led (from -r requirements.txt (line 2))
  Cloning git://github.com/fahrer16/flux_led to /tmp/pip-req-build-5lmxhjat
  Running command git clone -q git://github.com/fahrer16/flux_led /tmp/pip-req-build-5lmxhjat
Requirement already satisfied: polyinterface>=2.0.0 in /var/polyglot/.local/lib/python3.8/site-packages (from -r requirements.txt (line 1)) (2.1.0)
Requirement already satisfied: markdown2 in /var/polyglot/.local/lib/python3.8/site-packages (from polyinterface>=2.0.0->-r requirements.txt (line 1)) (2.4.0)
Requirement already satisfied: python-dotenv in /var/polyglot/.local/lib/python3.8/site-packages (from polyinterface>=2.0.0->-r requirements.txt (line 1)) (0.18.0)
Requirement already satisfied: netifaces in /usr/local/lib/python3.8/site-packages (from polyinterface>=2.0.0->-r requirements.txt (line 1)) (0.11.0)
Requirement already satisfied: paho-mqtt in /var/polyglot/.local/lib/python3.8/site-packages (from polyinterface>=2.0.0->-r requirements.txt (line 1)) (1.5.1)
updating MyQ
Requirement already satisfied: requests>=2.21.0 in /usr/local/lib/python3.8/site-packages (from -r requirements.txt (line 2)) (2.25.1)
Requirement already satisfied: chardet<5,>=3.0.2 in /usr/local/lib/python3.8/site-packages (from requests>=2.21.0->-r requirements.txt (line 2)) (4.0.0)
Requirement already satisfied: idna<3,>=2.5 in /usr/local/lib/python3.8/site-packages (from requests>=2.21.0->-r requirements.txt (line 2)) (2.10)
Requirement already satisfied: urllib3<1.27,>=1.21.1 in /usr/local/lib/python3.8/site-packages (from requests>=2.21.0->-r requirements.txt (line 2)) (1.26.7)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.8/site-packages (from requests>=2.21.0->-r requirements.txt (line 2)) (2021.5.30)
updating Ping
Requirement already satisfied: polyinterface>=2.0.29 in /var/polyglot/.local/lib/python3.8/site-packages (from -r requirements.txt (line 1)) (2.1.0)
Requirement already satisfied: netifaces in /usr/local/lib/python3.8/site-packages (from polyinterface>=2.0.29->-r requirements.txt (line 1)) (0.11.0)
Requirement already satisfied: python-dotenv in /var/polyglot/.local/lib/python3.8/site-packages (from polyinterface>=2.0.29->-r requirements.txt (line 1)) (0.18.0)
Requirement already satisfied: markdown2 in /var/polyglot/.local/lib/python3.8/site-packages (from polyinterface>=2.0.29->-r requirements.txt (line 1)) (2.4.0)
Requirement already satisfied: paho-mqtt in /var/polyglot/.local/lib/python3.8/site-packages (from polyinterface>=2.0.29->-r requirements.txt (line 1)) (1.5.1)
updating Push
updating RokuMediaPlayer
updating Sonos
Requirement already satisfied: soco>=0.17 in /var/polyglot/.local/lib/python3.8/site-packages (from -r requirements.txt (line 1)) (0.22.6)
Requirement already satisfied: polyinterface>=2.0.29 in /var/polyglot/.local/lib/python3.8/site-packages (from -r requirements.txt (line 2)) (2.1.0)
Requirement already satisfied: paho-mqtt in /var/polyglot/.local/lib/python3.8/site-packages (from polyinterface>=2.0.29->-r requirements.txt (line 2)) (1.5.1)
Requirement already satisfied: markdown2 in /var/polyglot/.local/lib/python3.8/site-packages (from polyinterface>=2.0.29->-r requirements.txt (line 2)) (2.4.0)
Requirement already satisfied: netifaces in /usr/local/lib/python3.8/site-packages (from polyinterface>=2.0.29->-r requirements.txt (line 2)) (0.11.0)
Requirement already satisfied: python-dotenv in /var/polyglot/.local/lib/python3.8/site-packages (from polyinterface>=2.0.29->-r requirements.txt (line 2)) (0.18.0)
Requirement already satisfied: xmltodict in /var/polyglot/.local/lib/python3.8/site-packages (from soco>=0.17->-r requirements.txt (line 1)) (0.12.0)
Requirement already satisfied: ifaddr in /var/polyglot/.local/lib/python3.8/site-packages (from soco>=0.17->-r requirements.txt (line 1)) (0.1.7)
Requirement already satisfied: requests in /usr/local/lib/python3.8/site-packages (from soco>=0.17->-r requirements.txt (line 1)) (2.25.1)
Requirement already satisfied: chardet<5,>=3.0.2 in /usr/local/lib/python3.8/site-packages (from requests->soco>=0.17->-r requirements.txt (line 1)) (4.0.0)
Requirement already satisfied: idna<3,>=2.5 in /usr/local/lib/python3.8/site-packages (from requests->soco>=0.17->-r requirements.txt (line 1)) (2.10)
Requirement already satisfied: urllib3<1.27,>=1.21.1 in /usr/local/lib/python3.8/site-packages (from requests->soco>=0.17->-r requirements.txt (line 1)) (1.26.7)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.8/site-packages (from requests->soco>=0.17->-r requirements.txt (line 1)) (2021.5.30)
updating Sun
Requirement already satisfied: astral>=2.1.0 in /var/polyglot/.local/lib/python3.8/site-packages (from -r requirements.txt (line 2)) (2.2)
Requirement already satisfied: tzlocal>=2.0.0 in /var/polyglot/.local/lib/python3.8/site-packages (from -r requirements.txt (line 3)) (2.1)
Requirement already satisfied: pytz in /usr/local/lib/python3.8/site-packages (from astral>=2.1.0->-r requirements.txt (line 2)) (2021.1)
updating Timedata
Requirement already satisfied: python-dateutil>=2.7.3 in /usr/local/lib/python3.8/site-packages (from -r requirements.txt (line 2)) (2.8.1)
Requirement already satisfied: six>=1.5 in /usr/local/lib/python3.8/site-packages (from python-dateutil>=2.7.3->-r requirements.txt (line 2)) (1.16.0)
updating UnifiPresence
Requirement already satisfied: polyinterface>=2.0.19 in /var/polyglot/.local/lib/python3.8/site-packages (from -r requirements.txt (line 1)) (2.1.0)
Requirement already satisfied: xmltodict in /var/polyglot/.local/lib/python3.8/site-packages (from -r requirements.txt (line 2)) (0.12.0)
Requirement already satisfied: netifaces in /usr/local/lib/python3.8/site-packages (from polyinterface>=2.0.19->-r requirements.txt (line 1)) (0.11.0)
Requirement already satisfied: markdown2 in /var/polyglot/.local/lib/python3.8/site-packages (from polyinterface>=2.0.19->-r requirements.txt (line 1)) (2.4.0)
Requirement already satisfied: python-dotenv in /var/polyglot/.local/lib/python3.8/site-packages (from polyinterface>=2.0.19->-r requirements.txt (line 1)) (0.18.0)
Requirement already satisfied: paho-mqtt in /var/polyglot/.local/lib/python3.8/site-packages (from polyinterface>=2.0.19->-r requirements.txt (line 1)) (1.5.1)
updating Virtual
Requirement already satisfied: markdown2 in /var/polyglot/.local/lib/python3.8/site-packages (from -r requirements.txt (line 2)) (2.4.0)
updating WeatherFlowPoly
Requirement already satisfied: urllib3>=1.23 in /usr/local/lib/python3.8/site-packages (from -r requirements.txt (line 2)) (1.26.7)
updating WirelessTag
Requirement already satisfied: polyinterface>=2.0.27 in /var/polyglot/.local/lib/python3.8/site-packages (from -r requirements.txt (line 1)) (2.1.0)
Requirement already satisfied: netifaces in /usr/local/lib/python3.8/site-packages (from -r requirements.txt (line 3)) (0.11.0)
Requirement already satisfied: markdown2 in /var/polyglot/.local/lib/python3.8/site-packages (from polyinterface>=2.0.27->-r requirements.txt (line 1)) (2.4.0)
Requirement already satisfied: python-dotenv in /var/polyglot/.local/lib/python3.8/site-packages (from polyinterface>=2.0.27->-r requirements.txt (line 1)) (0.18.0)
Requirement already satisfied: paho-mqtt in /var/polyglot/.local/lib/python3.8/site-packages (from polyinterface>=2.0.27->-r requirements.txt (line 1)) (1.5.1)
Done, please reboot: shutdown -r now
[admin@polisy ~]$
Nothing updated at all - but I am interested in this line:
Rebooted - and still getting 'Not found':
Not sure what to check next...
Thank you!
I've had issues with the Polisy grabbing the right DNS addr's. I have to constantly add them manually. You might check that you have valid DNS addrs in the Polisy configuration.
Via your web browser go to your Polisy and then settings, check the DNS entries.
@MWareman,
Please check that ftdi driver is loaded (kldstat) ... or, you can simply restart isy and it will tell you whether or not it's loaded (sudo service isy restart). If loaded and if INSTEON is enabled, then most probably either the PLM is dead or the cable is bad.
[admin@polisy ~]$ kldstat
Id Refs Address                Size Name
 1   42 0xffffffff80200000  1221330 kernel
 2    1 0xffffffff81422000   6832d8 zfs.ko
 3    1 0xffffffff81aa6000     5c10 nctgpio.ko
 4    2 0xffffffff81aac000     7bf8 superio.ko
 5    1 0xffffffff81d10000      c80 apuled.ko
 6    1 0xffffffff81d11000      a50 resetsw.ko
 7    1 0xffffffff81d12000     8320 uftdi.ko
 8    1 0xffffffff81d1b000     4b60 ng_ubt.ko
 9    6 0xffffffff81d20000     aac8 netgraph.ko
10    2 0xffffffff81d2b000     a238 ng_hci.ko
11    3 0xffffffff81d36000     25a8 ng_bluetooth.ko
12    1 0xffffffff81d39000     e250 ng_l2cap.ko
13    1 0xffffffff81d48000    1ce48 ng_btsocket.ko
14    1 0xffffffff81d65000     3980 ng_socket.ko
15    1 0xffffffff81d69000     2a08 mac_ntpd.ko
[admin@polisy ~]$ sudo service isy restart
Password:
Stopping isy.
Setting permissions for ISY directories/files
udx is running as pid 1216.
you can disable uftdi driver by adding isy_load_uftdi=NO in /etc/rc.conf
Starting isy.
[admin@polisy ~]$
I'll confirm functionality of the PLM and cable by using another device - but it's a brand new PLM.
Edited by MWareman
23 hours ago, Michel Kohanim said:
@MWareman,
Fixed!
Root cause: Bad USB cable.
Thank you for the assist!
OK......  I have this crazy idea :-)  What about, when Polisy is ready for Zwave and / or Polyglot 3 is released, some of us get together with Michel and his team, in  LA,  for a day of exchange of experiences ????
p.s. We would put @Teken and @lilyoyo1 on opposite sides of the table :-)
Edited by asbril
  • Haha 2
Works for me. I think me and @Tekenwould subconsciously take those spots anyway. ?
  • Haha 1
2 hours ago, asbril said:
Who else is game ?
Probably most likely... it all depends on the date.  My wife's been wanting to do San Diego Zoo again and another attraction in San Diego that we missed last time, so it would be a good excuse...  stop in LA and on to San Diego or vice versa....  LOL I just mentioned it as I was typing and she reminded me I've been wanting to do San Fransisco so it's looks like we will have quite a trip SFO,LAX and SAN.
@Michel Kohanim, do you support the idea ?
Of course when we all arrive.... None of us should introduce ourselves or wear nametags for the first part.  Instead we should all have fun figuring out who is who.
  • Haha 2
I am the handsome one :-)
  • Haha 3
35 minutes ago, Michel Kohanim said:
Absolutely! A hackathon of sorts ... lunch/dinner on UD.
Great Michel,
When you get close to ISY on Polisy and/or Polyglot 3, then give us a shout with some possible dates.
      377k
