ISY automatically discovered at https://192.168.1.44:8443 however the username and password need to be set in the settings menu.
I had my Polisy for a year now, didn't do much with it other than the initial linking to my ISY994 and playing with NodeServers which worked great at the time.
Yesterday I did update my Polisy, got into ISY via launcher, was able to sign in using admin/admin, changed the user ID and password, logged out and back in, confirmed PLM was found, all good.
However, in Polisy I get ISY automatically discovered at https://192.168.1.44:8443 however the username and password need to be set in the settings menu. after adding ISY on Polisy. It also still see the old ISY994 info on the dashboard. Tried linking it back to the ISY994 and get the same message now. I'm using Polisy / Settings / Polyglot Settings / ISY Settings to enter IP, port, username, password and https.
Polisy shows version 2.2.13, Frontend Version 2.2.9-5, ISY Version 5.3.0 (which is old ISY994 version form before I tried to connect Polisy to ISY on Polisy 5.1.1)
Am I missing something obvious?
Dirk
Yep, that did the trick.
Dirk
