Install Polyglot v2 on a Raspberry pi 3b+
HI All,
I've been attempting to install the polyglot server from UDI for a couple of days now with no luck.
I've been following the instructions here: https://github.com/UniversalDevicesInc/polyglot-v2
i flashed a new SD (32g)card with Raspberry Pi OS Lite(legacy)
Everything seems to install correctly but when i try to access it at 192.168.88.74:3000, nothing
after some reading/googling if added a .env file to .polyglot dir and now i can reach it vis the web but get
Not connected to server... Try refreshing the page. This will disappear once the connection is re-established.
and if i remove the file it goes back to nothing.
I don't see any errors in the logs either
4/11/2022, 08:27:20 [polyglot] debug: Created PID file: /home/pi/.polyglot/polyglot.pid
4/11/2022, 08:27:24 [polyglot] info: Starting Polyglot....
4/11/2022, 08:27:25 [polyglot] debug: Created PID file: /home/pi/.polyglot/polyglot.pid
4/11/2022, 08:27:27 [polyglot] info: Starting Polyglot....
4/11/2022, 08:27:28 [polyglot] info: Settings: Polyglot Version 2.2.11
4/11/2022, 08:27:28 [polyglot] info: Settings: Retrieved config from database
4/11/2022, 08:27:28 [polyglot] info: Settings: Retrieved config overrides from .env and updated database
4/11/2022, 08:27:28 [polyglot] debug: Checking for DB Maintenence needs...
4/11/2022, 08:27:28 [polyglot] debug: DB Version Found: 2 no maintenence necessary.
4/11/2022, 08:27:28 [polyglot] info: Aedes MQTT Broker Service: Started on port 1883
4/11/2022, 08:27:29 [polyglot] info: MQTT Client Service: Started
4/11/2022, 08:27:29 [polyglot] info: HTTP Interface Service: Started - Address: 192.168.88.74 Port: 3000
4/11/2022, 08:27:29 [polyglot] info: MQTTS: polyglot authenticated successfully.
4/11/2022, 08:27:29 [polyglot] info: MQTTS: Client Connected:
4/11/2022, 08:27:29 [polyglot] debug: Node server Ring [1] added to running config.
4/11/2022, 08:27:29 [polyglot] debug: Node server MyQ [2] added to running config.
4/11/2022, 08:27:29 [polyglot] debug: Node server TimedataPGC [4] added to running config.
4/11/2022, 08:27:29 [polyglot] debug: Node server Climacell [5] added to running config.
4/11/2022, 08:27:29 [polyglot] debug: MongoDB: 4 Node server(s) retrieved from database
4/11/2022, 08:27:29 [polyglot] debug: MQTTC: Subscribed to udi/polyglot/connections/# QoS 0
4/11/2022, 08:27:29 [polyglot] debug: MQTTC: Subscribed to udi/polyglot/frontend/# QoS 0
4/11/2022, 08:27:29 [polyglot] debug: MQTTC: Subscribed to udi/polyglot/frontend/settings QoS 0
4/11/2022, 08:27:29 [polyglot] debug: MQTTC: Subscribed to udi/polyglot/frontend/node servers QoS 0
4/11/2022, 08:27:29 [polyglot] debug: MQTTC: Subscribed to udi/polyglot/frontend/log QoS 0
4/11/2022, 08:27:29 [polyglot] debug: MQTTC: Subscribed to udi/polyglot/ns/# QoS 0
4/11/2022, 08:27:29 [polyglot] debug: MQTTC: Subscribed to udi/polyglot/profile/# QoS 0
4/11/2022, 08:27:29 [polyglot] debug: ISY: 200 - http://192.168.88.62:80/rest/config/
4/11/2022, 08:27:30 [polyglot] info: ISY: Got Version 5.3.0
4/11/2022, 08:27:30 [polyglot] debug: ISY: 200 - http://192.168.88.62:80/rest/profiles/ns/0/connection/
any ideas would be great
Pete
Keep in mind polyglot v2 is deprecated.  You're building a short term solution, but it is a good way to discover node servers if you have hardware already.
I have the hardware and it was working great with polyglot cloud but with that removed I need to either rebuild it locally or find an alternative
The alternative is to purchase a Polisy. The current V2 node servers aren't being updated nor is polyglot V2 itself. You're wasting your time taking this route as it's only a matter of time before this setup breaks as well
yeah, cant afford to spend $350-400 so my ISY knows what the weather is outside
Any news on this? I'm trying to install polyglot v2 and I'm getting the same problem. I'm kind of at a crossroad as to where I want to go with home automation and I don't want to buy a polisy until I'm sure which direction I want to go.
My ISY994 and RPi combo work just fine. I abandoned it for polisy for a few months but resurrected it again until some things settle down. The install was completely new and took some port redefining but works well for again the last few months.
The second link in the second post here will show you how to fix the issue. Did you read that?
EDIT: Actually - read the info at both of those links. Before I bought my Policy, I installed PG2 on an RPi and had the same problem until I found those posts.
Edited by Athlon
