bpwwer Posted September 12, 2022 Share Posted September 12, 2022 Great news! I'll give it a couple of days and then do another release without the extra debug messages and with the dcharger error fixed. 2 Link to comment
Kevin Posted September 12, 2022 Share Posted September 12, 2022 just noticed the you have in your main to grid and main from grid you have kw kwhour kwday kwmonthly. the app only gives you day month and year. your numbers are good just kw and hour will always be 0 log file won't upload I think it has gotten too big. VueTest_9-12-2022_50333_PM.zipVueTest_9-12-2022_50333_PM.zip Link to comment
TJF1960 Posted September 13, 2022 Author Share Posted September 13, 2022 Hi @bpwwer, this node server is working great!. Another outstanding job, Thank You so very much! It is amazing to me how well this turned out given you didn't have a lot to work with. You da man! -Tim 2 Link to comment
apostolakisl Posted September 13, 2022 Share Posted September 13, 2022 @bpwwer I don't suppose the system reports voltage? It doesn't on the companies own app, but asking anyway in case you noticed a number being reported that might be voltage. Link to comment
bpwwer Posted September 13, 2022 Share Posted September 13, 2022 10 minutes ago, apostolakisl said: @bpwwer I don't suppose the system reports voltage? It doesn't on the companies own app, but asking anyway in case you noticed a number being reported that might be voltage. No, I haven't seen anything in the API that suggest it's possible to get voltage data. Link to comment
apostolakisl Posted September 13, 2022 Share Posted September 13, 2022 Seems odd. Such a simple thing to monitor. Sense doesn't seem to monitor it either. Link to comment
tazman Posted September 14, 2022 Share Posted September 14, 2022 I wanted to share why I wanted this node server which was to charge my car using excess solar. I put together a couple of programs to turn the charger on and off and adjust the charge rate up and down accordingly. When the A/C runs I set the charder to 6 amps it's lowest setting which pulls from the grid because I only have 5.2 KWH of solar and I hear it's not a good idea to stop and start the the car charging. 2 Link to comment
apostolakisl Posted September 22, 2022 Share Posted September 22, 2022 On 9/13/2022 at 1:15 PM, bpwwer said: No, I haven't seen anything in the API that suggest it's possible to get voltage data. Does the API give out the 15 minute peak info? They do show it on the phone app. Link to comment
bpwwer Posted September 22, 2022 Share Posted September 22, 2022 2 hours ago, apostolakisl said: Does the API give out the 15 minute peak info? They do show it on the phone app. I believe that would have to be calculated by the node server. Link to comment
apostolakisl Posted September 23, 2022 Share Posted September 23, 2022 9 hours ago, bpwwer said: I believe that would have to be calculated by the node server. I don't think so. How would logging into the website give you the same number as the phone app if it were calculated locally? Link to comment
Kevin Posted September 23, 2022 Share Posted September 23, 2022 2 minutes ago, apostolakisl said: I don't think so. How would logging into the website give you the same number as the phone app if it were calculated locally? You might want to specify what Emporia device you are referring to. I have the energy monitor for my power panels and it dose not show 15min peek information just sec min hour and day week and month. Link to comment
apostolakisl Posted September 23, 2022 Share Posted September 23, 2022 6 minutes ago, Kevin said: You might want to specify what Emporia device you are referring to. I have the energy monitor for my power panels and it dose not show 15min peek information just sec min hour and day week and month. The same 15.2kw shows up on every device I log into. It can't be calculated locally since none of the devices have a locally stored record of the second by second power usage for the whole month. Unless it is downloading the entire month and calculating it in the 1 second it takes to open the page. Link to comment
Kevin Posted September 23, 2022 Share Posted September 23, 2022 8 minutes ago, apostolakisl said: The same 15.2kw shows up on every device I log into. It can't be calculated locally since none of the devices have a locally stored record of the second by second power usage for the whole month. Unless it is downloading the entire month and calculating it in the 1 second it takes to open the page. Sorry. Your right I did not notice that before. I have look at Bob's log files and never saw it there in the install process but the information must be in there some where. Link to comment
bpwwer Posted September 23, 2022 Share Posted September 23, 2022 The actual API from Emporia is not public. I'm using a library that reverse engineered that API. There's nothing in the library for 15 minute peak data. So the API may support getting that info but it's not public and only Emporia knows how to do that. Link to comment
tazman Posted September 24, 2022 Share Posted September 24, 2022 @bpwwerSorry to bother but it seems the on off of the charger is not quite right yet. When the node server tries to turn the charger off in the app it seems like it tries and cycles but turns right back on. The node sever also does not seem to be able to turn it on when it is in the paused stage When it is turned off through the app it shows as paused. Attached is the log file where I tried activating on and off and the operated it through the app. Charger On Off.zip Link to comment
bpwwer Posted September 25, 2022 Share Posted September 25, 2022 18 hours ago, tazman said: @bpwwerSorry to bother but it seems the on off of the charger is not quite right yet. When the node server tries to turn the charger off in the app it seems like it tries and cycles but turns right back on. The node sever also does not seem to be able to turn it on when it is in the paused stage When it is turned off through the app it shows as paused. Attached is the log file where I tried activating on and off and the operated it through the app. From the log, it appears that the Emporia cloud servers are rejecting the commands to turn it on and off. Since the Emporia API is not public, it's very possible that they've changed something so that what used to work, no longer does. I believe that the way the library was created in the first place was by someone sniffing the network to see what the app sends and receives when controlling these things. It does look like there's a bug when it tries to query and update the max charge rate so I've fixed that and pushed out version 1.0.22, but I don't think it wil effect the on/off issue as that's probably going to take network sniffing by someone with an EV charger to debug. Link to comment
tazman Posted September 25, 2022 Share Posted September 25, 2022 @bpwwerThank you what ever you did actully fixed the on and off of the charger! Link to comment
bpwwer Posted September 25, 2022 Share Posted September 25, 2022 Good. I didn't think that bug was the cause, but I'll consider it a win anyways. Link to comment
tazman Posted September 26, 2022 Share Posted September 26, 2022 1 hour ago, bpwwer said: Good. I didn't think that bug was the cause, but I'll consider it a win anyways. Well it worked but then stopped working but I'm not that concerned I will just send myself a notification to turn it on and off when I need it. The fact that it works sometimes tells me it has to be something weird on Emporia's end because I see it execute in the app and the car sends it's notification that charging has stopped then it goes right back on. Link to comment
pjjameso Posted September 30, 2022 Share Posted September 30, 2022 When do you think this will move to production? Link to comment
bpwwer Posted September 30, 2022 Share Posted September 30, 2022 56 minutes ago, pjjameso said: When do you think this will move to production? Now 1 Link to comment
pjjameso Posted October 1, 2022 Share Posted October 1, 2022 Thank you Bob looks great! I have a bunch of errors in the log. Have attached for your thoughts. VUE_10-1-2022_104732_AM.zip Link to comment
bpwwer Posted October 1, 2022 Share Posted October 1, 2022 The initial bunch of errors seem to be because it wasn't able to authenticate with the Emporia cloud service. The last bunch of errors aren't really errors, they're informational that are supposed to display the device information. I'm not sure why it's not showing the actual info but the class types instead. 1 Link to comment
ShawnW Posted December 18, 2022 Share Posted December 18, 2022 Hi Bob. I just wanted to say that I've read this entire thread so that I could learn some things as I've never used a Node Server or Polisy before. Well, I have a set of 4 of the Emporia on/off outlets that log energy usage and I'd like to try this one as my first Node Server. Seems like a fairly complicated one to tackle as a first, but after reading about all your work, I feel I just have to honour it. Thanks for all your work!! Wish me luck! Shawn 1 Link to comment
