Added IR support to isy994i and now all programs say out of memeory
I added IR support to my ISY994i and now all programs say "out of memory". I upgraded to 32 GB of memory and still get "out of memory". The ISY recognizes that it has plenty of extra memory, but still shows "out of memory". I removed all programs and added back one very simple program and I still get "out of memory". Help!
Do you have the PRO add on?
Did you double check the IR board is installed correctly and you got the IR support add on to support it?
Did you update your isy for 4.xxx to 5.xxx
Sounds like mismatched firmware and UI versions... check help About... what version numbers show for each?  they should be identical.
Thanks to all of you. You solved my problem I did an update to 5.xxx and the UI version did not match. I reloaded 4.9.0 and now I am back to normal. Thank you all again!!
  • 4 weeks later...
I am on IoX 5.5.4 and PG3.  Just noticed that 3 of my programs do not load because of "out of memory"  Is this possible?  I have 45 programs and 12 are not enabled.
Check them for errors. Go to Summary Tab in Programs and click on the status column, then all of the out of memory programs will be together. You can then click each one and select edit and look at them. Sometimes if a device or scene or variable was originally in the program and it gets deleted or somehow unassociated, you will see that message. Open the program and you should see an error message within the lines. If not sometimes just hit Update to any line after clicking on it and to cause the program to need to be resaved, and then do a save. This also may restore the program for you.
Doubtful it is truly out of memory. A good habit to do is to Right click on the top programs folder and go to the bottom where it says "copy folder to clipboard" adn then go to a text editor and past. This way you can always open up a copy of the programs next to the AC and see if something got changed etc.
check the programs, they likely didn't import correctly... Out of Memory seems like it's a stock error message..it get used for a lot of conditions that could be expressed better.
