UD Mobile - 404 Errors
Solved by bmercier
11 minutes ago, jwagner010 said:
Same.  Perhaps something wrong with the portal?
@Michel Kohanim, @Javi
I am thinking the same thing, as the issue is not isolated to UD Mobile. I just tried to connect to my remote site using the portal and after signing in to admin console I never got past the "subscription" part.
Just now, Geddy said:
@DennisC or @jwagner010 iOS or Android?
Working fine for me on iOS v1.0.21. At least able to get connection and control devices while remote.
Other Android users are reporting issues with Favorites not loading.
Portal also available/working for me and reports eisy IoX online since last Friday.
@GeddyCan you try connecting with the portal login through the admin console?
19 minutes ago, Geddy said:
@DennisC Worked logging into eisy.
Can you log into portal site and see if your error or event logs will load?
I can log in to portal and retrieve both error log & event log for my remote sites.
UD Mobile still shows 404 errors for both my remote units & admin console login to remote site using portal credentials is not moving pass "starting subscription".
Be back later, off to do some snow removal.....
