Upgrade firmware, now can't sign in.
I upgraded my ISY to the latest firmware, and now cannot sign in.
Solved by lilyoyo1
Did you try a reboot and/or power cycle ?
Thanks for the reply, i realized my opening ask was not particularly polite.  Yes, I have rebooted.  Both the ISY and the windows machine I use to access it.  Also, cleared the Java cache.  I have backups of the set up, I don't think those will allow me to bypass the sign in feature.  Appreciate any suggestions.
Assuming when you say ISY, you are referring to an ISY994 unit. What firmware did you upgrade to and did you download a new copy of stat.jnlp after clearing Java cache?
ISY firmware has not been updated in some time, so know what you started with and what you upgraded to will help us help you.
Edited by DennisC
Corrected spelling
If you upgraded from 4.xx to the latest firmware, the instructions on the firmware page states that the password was reset to default
Thanks all.  I did not appreciate the reset to default.  I'm assuming it's admin, and yep that worked.  Thanks for the assist.   I went from 4.8 to 5.3.4
I hope you meant to type that you did not anticipate the reset to default.
After all there is an entire section in the upgrade instructions on the topic:
Quote
Important User/Password changes:
-      If your current version is 5.0.7 or earlier, then after installing 5.0.8 or later your userid and password will be reset back to the system default.
-      If you restore a backup created from 5.0.7 or earlier, your userid and password will be reset back to the system default.
-      If you downgrade from version 5.0.8 or later to version 5.0.7 or earlier then after installing version 5.0.7 or earlier, you will have to Factory Reset the ISY and optionally install a backup taken in that version or earlier.
Security was upgraded, there was no way to decrypt your old credentials then re-encrypt.
