Eisy connection to PLM
Looking for a document that shows the connection to Eisy for the PLM?  I've migrated the database successfully from my ISY994i
Solved by DennisC
Most appreciated Dennis.  My current ISY994i is working so I will wait for the USB to come out this month.  That eliminated my confusion!  I wasn't sure my old PLM was considered a serial device.  Thank you!
It can be confusing to some users.
Yes it is a serial connection but on a RJ45 network cable and connector. Used for serial communications.
Remember, PLM can fail, it might be a good idea to have a spare around. Or, possibly order the cable so you can upgrade now and keep the USB PLM as a spare.
Yes, but you have to cut off the RJ45 and crimp on a new one.
See the following post.
https://forum.universal-devices.com/topic/40305-serial-plm-to-usb-adapter-alternative/
Thanks. I'll just get what UD recommends (post 2 above). I don't care about the looks. It's hidden away. I just thought if the cable I referenced eliminated the the adapter, then I would go that route.
It does eliminate the need for an adapter to go from RJ45 to DB9 to USB. Just the issue is you then need to alter the RJ45 to only use the wires needed on the PLM or you risk issues. I think it's been mentioned elsewhere that something could happen, but forget where.
With the UDI kit you'll use the proper pinout for the RJ45 to DB9 adaptor. From there you then use the Serial to USB cable to connect to the eisy.
Hi,
I have a similar question. I too have 2413S PLM with RJ45 connector. If I buy the Serial PLM kit from UDI store, which cable would connect the PLM to the Eisy? I do not see any cable which has RJ45 on one end and USB on other.
4 minutes ago, ArunGupta2014 said:
None of these cables will connect the 2413S to the eisy. These cables DO NOT have RJ45 to USB connection.
That is exactly what the cable set was designed to do. Look at the photo again. You have to use all the cables and connector included in the kit.
The RJ45 cable plugs into the PLM, the other end goes into the serial converter, and the remaining cable goes from converter to USB and plugs into eisy.
