March 23, 20242 yr Would like to see supoprt for: 4 Channel ZigBee Relay Switch • Manufacturer Name - MHCOZY • Model - ZG-005-RF • Link - https://www.amazon.com/dp/B09XGMQ449?ref=ppx_yo2ov_dt_b_product_details&th=1 • Key/desired function support – Support for all four relays. Currently, relay 1 configures and works.
April 10, 20242 yr Sengled A19 Zigbee Color Bulbs Ability to tune bulbs 2000K-6500K https://www.amazon.com/dp/B07HL5GPPF?ref=emc_s_m_5_i_atc&th=1
April 10, 20242 yr 1 hour ago, jpoje said: Sengled A19 Zigbee Color Bulbs Ability to tune bulbs 2000K-6500K https://www.amazon.com/dp/B07HL5GPPF?ref=emc_s_m_5_i_atc&th=1 While not exactly what you are looking for, the bulb can be set manually using UD Mobile in the Device's Dashboard (coming soon to favorites). Click the menu next to the Hue and/or Saturation properties and select the Hue or Saturation Sliders as the View Type.
April 26, 20242 yr Centralite by Ezlo Temperature and Humidity Sensor https://www.centralite.com/products/temp-and-humidity-sensor/ Temp and humidity readings Edited April 26, 20242 yr by SMorgan
April 26, 20242 yr 4 hours ago, Michel Kohanim said: @SMorgan, are you on 5.8.3? With kind regards, Michel I am on 5.8.0. I see 5.8.3 was posted yesterday. I'll give that a shot
April 27, 20242 yr 2 hours ago, SMorgan said: I am on 5.8.0. I see 5.8.3 was posted yesterday. I'll give that a shot Same results on 5.8.3
April 29, 20242 yr Update after going to 5.8.3; Originally posted on Posted February 25 MOES ZS-B-US2-WH-MS Still is only added as a single node (not 2)
May 15, 20242 yr I would be interested in the IHSENO 4 button Zigbee remote (Amazon) - you can get 4 for under $30 - https://www.amazon.com/gp/product/B0CC4YTQ9Y/ref=ox_sc_act_image_1?smid=ALB5EKCIKNPII&th=1 Edited May 15, 20242 yr by JTsao
May 29, 20242 yr I bought 4 of the above Zigbee remotes, added 1 and it shows up as a on-off switch with no apparent functionality
July 15, 20242 yr On 5/11/2024 at 10:45 AM, SteveSBE said: Support for Somfy Zigbee Shade Motors. +1 for the Somfy Zigbee Shade Motors
July 18, 20242 yr @efett, Can you please let us know what's not working? Please submit a ticket: https://www.universal-devices.com/my-tickets With kind regards, Michel
August 27, 20242 yr SONOFF Zigbee Switch, SNZB-01P Wireless Push Button https://www.amazon.com/dp/B0CL9JTMWF?ref=ppx_yo2ov_dt_b_fed_asin_title Control multiple devices by single press, double press, and long press Currently, I've been able to pair this button with EISY, but only the double press action seems to be received.
December 1, 20241 yr Sonoff ZBMINIR2 on/off switch. Currently able to be added as a Zigbee device, on/off works, but no ability to configure/mange device settings such as detached mode, inching mode, trigger mode, power reset state. My use case is to sense a local switch for Hue bulbs to toggle on/off state without powering off bulb entirely (originally wired it as a local failsafe switch/if we ever sell the house and revert to "dumb" wiring). A whole lot cheaper than another insteon switch with a disconnected load. https://www.zigbee2mqtt.io/devices/ZBMINIR2.html https://sonoff.tech/product/diy-smart-switches/zbminir2/ Edited December 1, 20241 yr by Scott Korvek detail
December 30, 20241 yr More sonoff devices- Water leak sensor is recognized as a water leak sensor class device by IoX with multiple parameters but water leak detection events are not received. https://sonoff.tech/product/gateway-and-sensors/snzb-05p/
January 6, 20251 yr Tuya Zigbee Temp and Humidty Sensor. Model ZG-227Z. Can add it, but no data. https://www.ebay.com/itm/205128389391?var=505841800514 Edited January 6, 20251 yr by Chris K
January 6, 20251 yr @Chris K Take a look at your device tree, there should be additional nodes containg the data
January 6, 20251 yr 37 minutes ago, Techman said: @Chris K Take a look at your device tree, there should be additional nodes containg the data Nope. Nothing there.
January 6, 20251 yr Try removing it from your eisy then doing a factory reset on the sensor and a reinstall. Are you using the UDI ZMatter Module, if so are your antennas connected to the correct connector. If the issue still persists then you should probably open a support ticket with UDI https://www.universal-devices.com/my-tickets
April 6, 20251 yr On 2/29/2024 at 1:59 PM, dstanley said: SONOFF Zigbee Human Presence Sensor | SNZB-06P https://sonoff.tech/product/gateway-and-sensors/snzb-06p/ Wonderful USB-C powered device On 2/29/2024 at 2:30 PM, Michel Kohanim said: Should have support for most of these in the upcoming isy release. With kind regards, Michel Was support for this device ever added?
April 8, 20251 yr Edit: @Michel Kohanim it does indeed work! I guess it just took a few to be ready. Thanks! Edited April 8, 20251 yr by skunkiechris
September 8, 2025Sep 8 On 10/25/2023 at 7:22 PM, glarsen said: Sinope TH1300ZB, TH1124ZB, TH1123ZB would be a good addon here! https://sinopetech.com/en These are: 1) floor heat thermostat, 2) 4000 and 3000 watt electric baseboard heat thermostats respectively eisy 5.7.0 w USB Zmatter finds them and lists them as "unsupported work queue request 6 ignored" Sinope also offers dimmers, switches, load controllers, water detectors and other elements in either Zigbee or Wi-Fi I'm looking at buying a whole bunch of TH1400ZB thermostats. eisy 5.9.1 with ZMatter is able to add the device and it shows the current temperature but has no other functionality. It seems impractical to have UD build support for every device in existence. Is there any chance of having a way for developers to build something to support new zigbee devices? For now it looks like I'm probably going to be using their hub and putting something together to scrape from their web site or API.
September 16, 2025Sep 16 On 7/15/2023 at 6:25 AM, MBell said: AquaraSJCGQ11LMhttps://www.aqara.com/en/water_sensor.htmlLeak sensor, battery data.Name: Aqara Water Leak SensorURL: https://www.amazon.com/dp/B07D39MSZSI'd like this also, I have one and it connects but the note identifies itself as "main" with no attributes Edited November 4, 2025Nov 4 by evilpete
