October 8Oct 8 Third reality zigbee smart plug power monitoring not showing upThird Reality, IncModel # 3RSP02028BZhttps://www.amazon.com/THIRDREALITY-Zigbee-Smart-Plug/dp/B0BPY2KRHHIoX v.5.9.1 The device has no problem pairing, and is functional with on / off capabilities, but the power monitoring feature is not available.Note: under Xray: Device channel database object: ELECTRICAL_MEASUREMENT is listed Edited November 4Nov 4 by evilpete
October 22Oct 22 NeoWater Sensor 11Shenzhen NEO Electronic CO.,LTDWater level alarm, reset, battery statusThanks, Tim
October 24Oct 24 Manufacturer Name: InovelliModel #: VZM35 -Blue Series (Zigbee) FAN SWITCHLink to sales/availability site(s) Blue Series Fan Switch • Manual | Inovelli Help CenterKey/desired function support: In a program's device list, include a drop-down option for "Set Configuration" (Along with the On, Off, Fast On, etc.)Set ConfigurationParameter NumberParameter ValueThese switches have 74 configuration parameters but there's no way to set any of them using an EISY.
October 27Oct 27 I cant find a zwave rgbw controller anywhere. I saw this on Amazon: Amazon.com: GLEDOPTO ZigBee 3.0 Pro Mini LED Strip Controller 5 Modes in 1 RGBCCT RGBW RGB CCT WWCW Dimmer DC12-24V APP Voice Control Work with Hu/e ZigBee2mqtt Conbee II Home Assistant Alexa (Hub Required) : Tools & Home ImprovementAnyone got it to work with EISY?Or, @Michel Kohanim can you get this added as a supported zigbee device?Thanks
October 28Oct 28 I have many of these GLEDOPTO LED controllers. They make a handful of zigbee models. They work fine out of the box.
November 3Nov 3 On 10/28/2025 at 6:09 AM, SJK said:I have many of these GLEDOPTO LED controllers. They make a handful of zigbee models. They work fine out of the box.Can you give a pros/cons review?This is something I've been thinking about recently
November 4Nov 4 THIRDREALITY ZigBee Smart ButtonModel # 3RSB22BZhttps://www.amazon.com/dp/B0BJDWR3BC?th=1Receive process button event.IoX v6.0.0I am willing send capture log and/or buy/donate a unit if it will help Edited November 4Nov 4 by evilpete
Tuesday at 09:08 PM5 days Q: should we put together a list on the wiki of functional and nonfunctional zig devices?
Wednesday at 02:34 AM5 days On 11/3/2025 at 6:28 PM, evilpete said:Can you give a pros/cons review?This is something I've been thinking about recentlySure- they are a basic Zigbee3.0 device. They are nothing fancy but work pretty much identically to Philips Hue bulbs. You get an on/off node, an x/y/temp node, and a color/sat node. All work exactly like any other ZB3.0 device.My only con is that if they are reset (or powered off for months, like happened with my exterior flood lights) you end up with a new ID (think this is typical of these kind of devices) which makes reprogramming a pain if they are in multiple scenes. Always remove from network first of course.I recommend these for LED strip drivers. They have few models with varying configs. They are inexpensive- no reason not to get the 5 in 1 version that can do RGBWW+CW for strips. They can be configured to whatever strip type you need- RGB, + WW, +CW, etc. They even have constant voltage modes and single color dimming modes or CW/WW modes. Pretty flexible- cannot go wrong here. Just pick the device that meets your needs. Edited Wednesday at 02:39 AM5 days by SJK model detail
