Support thread for: PG3x v3.2.3 (August 29th, 2023)
Dammit Jim! LOL!!!! WTH?
I should have looked before i took my whole system down.
I guess this is also my fault?
Why I cannot update Tuya.
OKAY!
I can surely see manually controlling my equipment for a few days.
I put in a ticket so now what, we just sit and look at it like a pet rock?
I see everyone else is:
2023-09-03 01:25:49,640 MainThread udi_interface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30
2023-09-03 01:25:51,629 MainThread udi_interface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30
2023-09-03 01:25:53,360 MainThread udi_interface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30
2023-09-03 01:25:55,100 MainThread udi_interface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30
2023-09-03 01:25:56,455 MainThread udi_interface INFO polylogger:set_basic_config: set_basic_config: enable=True
level=30
9 hours ago, bgrubb1 said:
just a note  I upgraded 3.2.2 to 3.2.3  no issues (on a Polisy)
...Barry
I upgraded PG3x on a Polisy to 3.2.3 on Friday and my node servers are fine also.
It looks like I'm in the same situation with all node servers showing disconnected status after the most recent update.  While it appears most of the other reports are 3.2.1/2 -> 3.2.3, I actually updated from 3.1.36 -> 3.2.3 (and IoX 5.6.3 -> 5.6.4).  As instructed, I've re-installed all node servers.  And have attempted a few reboots (both from the admin console UI and power cycling my eISY).
I've submitted a ticket with PG3x logs after performing my most recent reboot.
-Sam
Hello everyone,
We found that a system update is causing issues with node server startup on eisy.
We are working on a permanent fix.
But for now, here's a solution:
  1. ssh to your system (on Windows, you can use putty)
  2. Run these 2 commands:
    • sudo pip3 uninstall aioquic
    • sudo pip3 install aioquic
You can ignore the warnings.
This will reinstall aioquic at the same version (0.9.21). However it does check dependancies. On my system, this uninstalled pyOpenSSL 21.0.0 and reinstalled it at 23.2.0. This solved the problem.
Thanks @bmercier - followed the suggested steps and my node servers are now connected.
One note, on my system, the pip install of the aioquic resulted in more than warnings.  I actually ended up with a number of errors while building wheel for aioquic.  However, pyOpenSSL did update to 23.2.0 as expected.
-Sam
-Sam
Thanks for the feedback.
On my system, I only had warning.
This is the expected output:
[admin@eisy /var/polyglot/pg3/ns]$ sudo pip3 uninstall aioquic
Found existing installation: aioquic 0.9.21
Uninstalling aioquic-0.9.21:
  Would remove:
    /usr/local/lib/python3.9/site-packages/aioquic-0.9.21.dist-info/*
    /usr/local/lib/python3.9/site-packages/aioquic/*
Proceed (Y/n)? y
  Successfully uninstalled aioquic-0.9.21
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
[admin@eisy /var/polyglot/pg3/ns]$ sudo pip3 install aioquic
Collecting aioquic
  Downloading aioquic-0.9.21.tar.gz (153 kB)
     ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 153.4/153.4 kB 1.4 MB/s eta 0:00:00
  Installing build dependencies ... done
  Getting requirements to build wheel ... done
  Preparing metadata (pyproject.toml) ... done
Requirement already satisfied: certifi in /usr/local/lib/python3.9/site-packages (from aioquic) (2023.7.22)
Requirement already satisfied: pylsqpack<0.4.0,>=0.3.3 in /usr/local/lib/python3.9/site-packages (from aioquic) (0.3.17)
Collecting pyopenssl>=22 (from aioquic)
  Obtaining dependency information for pyopenssl>=22 from https://files.pythonhosted.org/packages/f0/e2/f8b4f1c67933a4907e52228241f4bd52169f3196b70af04403b29c63238a/pyOpenSSL-23.2.0-py3-none-any.whl.metadata
  Downloading pyOpenSSL-23.2.0-py3-none-any.whl.metadata (10 kB)
Requirement already satisfied: cryptography!=40.0.0,!=40.0.1,<42,>=38.0.0 in /usr/local/lib/python3.9/site-packages (from pyopenssl>=22->aioquic) (41.0.3)
Requirement already satisfied: cffi>=1.12 in /usr/local/lib/python3.9/site-packages (from cryptography!=40.0.0,!=40.0.1,<42,>=38.0.0->pyopenssl>=22->aioquic) (1.15.1)
Requirement already satisfied: pycparser in /usr/local/lib/python3.9/site-packages (from cffi>=1.12->cryptography!=40.0.0,!=40.0.1,<42,>=38.0.0->pyopenssl>=22->aioquic) (2.21)
Downloading pyOpenSSL-23.2.0-py3-none-any.whl (59 kB)
   ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 59.0/59.0 kB 2.9 MB/s eta 0:00:00
Building wheels for collected packages: aioquic
  Building wheel for aioquic (pyproject.toml) ... done
  Created wheel for aioquic: filename=aioquic-0.9.21-cp37-abi3-freebsd_13_1_release_p7_amd64.whl size=92308 sha256=38f9a1084a60c2ecf26499995128b9a4d2ecaac0462ae4583e52ecc153327630
  Stored in directory: /root/.cache/pip/wheels/ac/a8/24/70b950af1c5ceb452388b3562e6c80b085bc5f71c799f7e813
Successfully built aioquic
Installing collected packages: pyopenssl, aioquic
  Attempting uninstall: pyopenssl
    Found existing installation: pyOpenSSL 21.0.0
    Uninstalling pyOpenSSL-21.0.0:
      Successfully uninstalled pyOpenSSL-21.0.0
Successfully installed aioquic-0.9.21 pyopenssl-23.2.0
There is probably a more direct command to update pyopenssl to 23.2.0 but could not test it.
I also have performed the reinstall of aioquic and also had build errors along the way (log excerpt below). My node servers are also now reconnected and appear to be working as expected.
-Xathros
Quote
   ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 59.0/59.0 kB 1.8 MB/s eta 0:00:00
  Building wheel for aioquic (pyproject.toml) ... error
  error: subprocess-exited-with-error
  × Building wheel for aioquic (pyproject.toml) did not run successfully.
  exit code: 1
  ╰─> [62 lines of output]
      No `packages` or `py_modules` configuration, performing automatic discovery.
      `src-layout` detected -- analysing ./src
      discovered packages -- ['aioquic', 'aioquic.quic', 'aioquic.asyncio', 'aioquic.h0', 'aioquic.h3']
      discovered py_modules -- []
      running bdist_wheel
      running build
      running build_py
      creating build
      creating build/lib.freebsd-13.1-RELEASE-p7-amd64-cpython-39
      creating build/lib.freebsd-13.1-RELEASE-p7-amd64-cpython-39/aioquic
      copying src/aioquic/buffer.py -> build/lib.freebsd-13.1-RELEASE-p7-amd64-cpython-39/aioquic
      copying src/aioquic/tls.py -> build/lib.freebsd-13.1-RELEASE-p7-amd64-cpython-39/aioquic
      copying src/aioquic/__init__.py -> build/lib.freebsd-13.1-RELEASE-p7-amd64-cpython-39/aioquic
      creating build/lib.freebsd-13.1-RELEASE-p7-amd64-cpython-39/aioquic/quic
      copying src/aioquic/quic/events.py -> build/lib.freebsd-13.1-RELEASE-p7-amd64-cpython-39/aioquic/quic
      copying src/aioquic/quic/configuration.py -> build/lib.freebsd-13.1-RELEASE-p7-amd64-cpython-39/aioquic/quic
      copying src/aioquic/quic/__init__.py -> build/lib.freebsd-13.1-RELEASE-p7-amd64-cpython-39/aioquic/quic
      copying src/aioquic/quic/packet.py -> build/lib.freebsd-13.1-RELEASE-p7-amd64-cpython-39/aioquic/quic
      copying src/aioquic/quic/crypto.py -> build/lib.freebsd-13.1-RELEASE-p7-amd64-cpython-39/aioquic/quic
      copying src/aioquic/quic/logger.py -> build/lib.freebsd-13.1-RELEASE-p7-amd64-cpython-39/aioquic/quic
      copying src/aioquic/quic/packet_builder.py -> build/lib.freebsd-13.1-RELEASE-p7-amd64-cpython-39/aioquic/quic
      copying src/aioquic/quic/recovery.py -> build/lib.freebsd-13.1-RELEASE-p7-amd64-cpython-39/aioquic/quic
      copying src/aioquic/quic/rangeset.py -> build/lib.freebsd-13.1-RELEASE-p7-amd64-cpython-39/aioquic/quic
      copying src/aioquic/quic/connection.py -> build/lib.freebsd-13.1-RELEASE-p7-amd64-cpython-39/aioquic/quic
      copying src/aioquic/quic/stream.py -> build/lib.freebsd-13.1-RELEASE-p7-amd64-cpython-39/aioquic/quic
      copying src/aioquic/quic/retry.py -> build/lib.freebsd-13.1-RELEASE-p7-amd64-cpython-39/aioquic/quic
      creating build/lib.freebsd-13.1-RELEASE-p7-amd64-cpython-39/aioquic/asyncio
      copying src/aioquic/asyncio/protocol.py -> build/lib.freebsd-13.1-RELEASE-p7-amd64-cpython-39/aioquic/asyncio
      copying src/aioquic/asyncio/__init__.py -> build/lib.freebsd-13.1-RELEASE-p7-amd64-cpython-39/aioquic/asyncio
      copying src/aioquic/asyncio/client.py -> build/lib.freebsd-13.1-RELEASE-p7-amd64-cpython-39/aioquic/asyncio
      copying src/aioquic/asyncio/server.py -> build/lib.freebsd-13.1-RELEASE-p7-amd64-cpython-39/aioquic/asyncio
      creating build/lib.freebsd-13.1-RELEASE-p7-amd64-cpython-39/aioquic/h0
      copying src/aioquic/h0/__init__.py -> build/lib.freebsd-13.1-RELEASE-p7-amd64-cpython-39/aioquic/h0
      copying src/aioquic/h0/connection.py -> build/lib.freebsd-13.1-RELEASE-p7-amd64-cpython-39/aioquic/h0
      creating build/lib.freebsd-13.1-RELEASE-p7-amd64-cpython-39/aioquic/h3
      copying src/aioquic/h3/events.py -> build/lib.freebsd-13.1-RELEASE-p7-amd64-cpython-39/aioquic/h3
      copying src/aioquic/h3/connection.py -> build/lib.freebsd-13.1-RELEASE-p7-amd64-cpython-39/aioquic/h3
      copying src/aioquic/h3/__init__.py -> build/lib.freebsd-13.1-RELEASE-p7-amd64-cpython-39/aioquic/h3
      copying src/aioquic/h3/exceptions.py -> build/lib.freebsd-13.1-RELEASE-p7-amd64-cpython-39/aioquic/h3
      running egg_info
      writing src/aioquic.egg-info/PKG-INFO
      writing dependency_links to src/aioquic.egg-info/dependency_links.txt
      writing requirements to src/aioquic.egg-info/requires.txt
      writing top-level names to src/aioquic.egg-info/top_level.txt
      reading manifest file 'src/aioquic.egg-info/SOURCES.txt'
      reading manifest template 'MANIFEST.in'
      adding license file 'LICENSE'
      writing manifest file 'src/aioquic.egg-info/SOURCES.txt'
      copying src/aioquic/_buffer.c -> build/lib.freebsd-13.1-RELEASE-p7-amd64-cpython-39/aioquic
      copying src/aioquic/_crypto.c -> build/lib.freebsd-13.1-RELEASE-p7-amd64-cpython-39/aioquic
      running build_ext
      building 'aioquic._buffer' extension
      creating build/temp.freebsd-13.1-RELEASE-p7-amd64-cpython-39
      creating build/temp.freebsd-13.1-RELEASE-p7-amd64-cpython-39/src
      creating build/temp.freebsd-13.1-RELEASE-p7-amd64-cpython-39/src/aioquic
      cc -pthread -Wno-unused-result -Wsign-compare -Wunreachable-code -DNDEBUG -O2 -pipe -fstack-protector-strong -fno-strict-aliasing -fPIC -DPy_LIMITED_API=0x03070000 -I/usr/local/include/python3.9 -c src/aioquic/_buffer.c -o build/temp.freebsd-13.1-RELEASE-p7-amd64-cpython-39/src/aioquic/_buffer.o -std=c99
      In file included from src/aioquic/_buffer.c:3:
      /usr/local/include/python3.9/Python.h:11:10: fatal error: 'limits.h' file not found
      #include <limits.h>
      1 error generated.
      error: command '/usr/bin/cc' failed with exit code 1
      [end of output]
  note: This error originates from a subprocess, and is likely not a problem with pip.
  ERROR: Failed building wheel for aioquic
Failed to build aioquic
ERROR: Could not build wheels for aioquic, which is required to install pyproject.toml-based projects
Edited by Xathros
Quote
39 minutes ago, bmercier said:
Hello everyone,
Followed these suggestions and all nodes are connected and working. Did return some errors after re-installing aioquic?
Do let us know if you all need anymore logs?
I am also having the same problem with all Polyglot Current Status: Disconnected.... HELPimage.thumb.png.fe9abc32cdf590880abae799edc7d792.png
The temporary fix was listed several posts up.
polisy one node server cane back up cannot install any node servers,
eisy completely down on all node servers!!!
All nodes servers are still down re-install all node servers does nothing!
i am leaving for Bodega Bay and my house is down!
one sprinkler was ON all night.
so idk who else is experiencing this but i am not happy
I have never ssh from my Mac have no idea how to do it..... Can you give me some suggestions from Terminal to make sure I do it, right
Hello GSutherland,
Open the Terminal app on you Mac.  It's a native app provided with MacOS.
Type: ssh admin@<the-ip-address-of-your-eisy> (and press return)
Password is admin unless you have changed it.  You wont see the password characters as you type them. (and press return)
From there, enter the commands that bmercier posted above.  (followed by the return key) There may be errors or warnings reported, don't worry.
When completed, type: exit (and press return)
Then, return to the PG3x dashboard and start your noderserver(s)
Hope this helps.
-Xathros
Edited by Xathros
THAT WORKED GREAT>>>>>Thank You for your time
@everyone,
Apologies for the weekend fire. This is now fixed in udx-3.5.1_4. In short, there were some python packages that depended on the newer version of pyopenssl. Now, udx makes sure those packages are installed.
1. Admin Console | Configuration tab | Upgrade Packages, or
2. Click on the power button once
3. Wait for the reboot notification in the Admin Console
- Admin Console | Configuration tab | Reboot, or
2. Click the power button 5 times
Did the update packages, then rebooted.
Now every time I open the admin console I get a need to reboot window.
Removing power from the eisy stopped the reboot notices, but I'm still showing 3.2.3
@Michel Kohanim I upgraded to latest version on eISY a few days ago snd all is working well. Should I perform another update or simply wait for next update?
@bgrubb1
 Did you install any node servers after you updated? I had one node server installed on my Development Polisy and it is running after 3.2.3. Try to install a new node server and they do not run.
Eisy all Nodes 17 of my Node servers all show basic configuration in their log and all of them are down.
I am in Bodega Bay "the birds" 60 years and art
Upgrade wasn't straight forward, waited for the beeps and then waiting for the reboot to happen I saw MQTT errors scrolling in the tail of log so fast it could not keep up.  I don't have the MQTT node server installed either.  ISY was not responsive, could not open PG3x or AC.  After an hour of this I rebooted from command line.  Everything came up and everything seems ok.
Edited by btreinders
